03-26-2011, 07:16 PM
#46 |
Oddometer: 233
so I bought a Zumo 550 to use with the G4, question since the GPS has the highest priority with the G4 does that mean if I use the Zumo's built in XM I won't be able to use the intercom??? wanna know before I spend money on XM antenna
thanks Dan |
03-28-2011, 04:35 PM
#47 | |
Riding is my passion
When you connect the G4 and the Zumo 550, you are connecting on a "mono" headset connection. Basically, the GPS voice commands and if you sync your cell to the GPS will come over this connection. You can force it to play stored MP3's on the Zumo over this BT connection, but the music quality lacks over this type of connection. The best option he found was either using a cord from the audio out of the Zumo to the input on the G4 or just buy a small BT transmitter that you plug into the audio output of the Zumo cradle and basically transmits your music and GPS instructions over A2DP. You can then sync this BT transmitter with the G4 and have your music wirelessly over BT. Even before the 3.0 update, we could get my Dad's G4 to accept both the Zumo's 550's mono connection for phone calls and then a A2DP music from the XM, but when a call came in, it would break the music connection and would never resume until you restarted either the BT device or G4. This was very frustrating and a major PITA. I haven't had a chance to see with this new 3.0 update if both should work together better, but that was my understanding also.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU BlueLghtning screwed with this post 03-28-2011 at 04:42 PM |
03-28-2011, 05:23 PM
#48 | |
60 easy payments!
Oddometer: 340
Darren '09 BMW F800GS '82 Honda CM250C <- Wife's Learner |
03-29-2011, 01:41 PM
#49 | |
Oddometer: 147
Getting the G4 volume correct can be a chore, as the MP3 volume can be set from the phone but the phone call volume requires the noise canceling to sense ambient noise for the sensitivity. Sync the phone first, after the engine is running to get the G4 volume set for phone use, and then start the MP3 and adjust the MP3 player volume from the phone volume control (otherwise the volume will not match when switching between the two). |
03-29-2011, 03:30 PM
#50 | |
- Web Bike World Scala G4 3.0 update
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
03-30-2011, 08:08 AM
#51 |
Oddometer: 36
VOX with 3.0 upgrade
To anyone that has done the upgrade, how does the VOX now work? I happen to like the VOX of my autocom and I don't want to lose that level of functionality if I go BT. Thanks
04-02-2011, 04:01 AM
#52 | |
Oddometer: 1,028
Speak Italian?
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 |
04-02-2011, 12:20 PM
#53 |
Oddometer: 233
Vox sensitivity
As far as the Vox sensitivity I confused....I have it on meduim and its not working...if I want to set it to activate easier do I set i on high or low???
thanks Dan |
04-02-2011, 05:46 PM
#54 |
Oddometer: 186
Is there anyone out there that has done the C3 Scala? Before I spend $400 it would be nice to get some feedback. THKS
2008 1200GS 2011 F650GS 1978 750 Triumph 2006 BMW K1200S (sold) 2007 Ducati 1098S Tricolore(sold)Replaced with 2002 Foggy Monster |
04-02-2011, 06:56 PM
#55 |
Oddometer: 2,490
I am not sure I know what a c3 scala is. They have a G4 and a Q2 as far as I know.
04-03-2011, 09:45 AM
#56 | |
Oddometer: 83
gear i have. iphone 4 Scala g4 (Earbud moded) zumo 550. If i did the iPhone > Zumo > Scala. i could not listen to my MP3's in the iphone. I tried the Iphone > scala | zumo > scala. And i was never happy with this setup, I want to think it is the fact that the iphone is not connecting as a pure MP3 player and it si also connecting as a phone device too. I have a ipod bluetooth adapter, that i think might make this combination work, but i need to test it. I finaly dropped the zumo altogether, and was the most happy with just iphone > scala. With just iphone>scala, MP3 palyback and phone control worked %95 og the time. there were a few times where, i lost all phone control, and a simple onn/off of the scala would fix everything. Intercom and vox (vox set to low) worked even better than the older q2's i once had. But I did seem to have about a 10 second delay making a intercom connection when playing music. we even added an older q2 into the mix and had a conference intercom session with all 3 riders. |
04-06-2011, 08:48 PM
#57 |
Itchntogo
Oddometer: 27
04-07-2011, 05:12 AM
#58 |
Oddometer: 233
04-07-2011, 03:28 PM
#59 | |
Just Beastly
Oddometer: 6,454
I have not failed to be heard well, and I have not had one instance of anything but my voice triggering the VOX. No wind noise, etc. I don't recall the setting, middle-ish if I remember. Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. |
04-08-2011, 12:29 PM
#60 |
Oddometer: 12
I don't have the G4 yet, but I am wondering how hard is it to hear music with the wind noise through a full face helmet. Do you need to have the volume up fully. Will it be hard on the ears? I have tried ear buds in the past, but at highway speeds the wind noise overtakes the volume. Typically, I just have sponge ear plugs to deaden the wind noise.
