Old 04-28-2011, 08:38 PM   #1486
ta2240
Oddometer: 44
Take the smallest drillbit you have and drill a small hole in the seal, then take a small fine thread wood screw and screw about two threads in the hole then pull on the screw.
Before putting the screw in I would use a shop vac to suck any shavings out of the hole, even if you cant get them out they are really soft and no damage will occur if they get past the bearing.
2007 XR650R
2007 KTM 300XC-W
2011 KTM 530 EXC
ta2240 is offline   Reply With Quote
Old 04-28-2011, 09:40 PM   #1487
Chowdown
Texas Aussie
Oddometer: 140
so my bike has less than 2 hours on it and the end cap/screen has gone missing. Is it the actual spark arrestor or is it just a noise reducer? i wouldnt bother with it if its just for noise, but i do want to ride in the forest and dont want a ticket from a ranger for no spark arrestor..
Originally Posted by rschulte View Post
I wired mine on.
Chowdown is offline   Reply With Quote
Old 04-28-2011, 09:49 PM   #1488
309
Special Purpose
309's Avatar
Oddometer: 5,466
It's for noise. The spark arrestor is down deeper and ain't coming out.
Noise is bad for the sport.
309 is offline   Reply With Quote
Old 04-28-2011, 10:01 PM   #1489
Chowdown
Texas Aussie
Oddometer: 140
thanks. i agree about noise being bad, but i havent been able to tell its any louder than when the screen was in, the stock pipe seems reasonably mellow to me.
Old 04-29-2011, 05:02 AM   #1490
north_of_us
Oddometer: 4
I took out the restrictor inside and somehow my screen also fell out on a ride, guess i didnt screw it back on tight enough. Anyhow noise does slightly increase but still very respectable. I get passed by some of those crotch rockets that are much more loud. Theres also a vid on youtube with a sound test with the above mods, it ranged 94-95 db.
north_of_us is offline   Reply With Quote
Old 04-29-2011, 10:32 AM   #1491
Leverbender
Adventure Now
Oddometer: 37
Loc-Tite (the red kind) works as well.
Leverbender is offline   Reply With Quote
Old 04-30-2011, 08:06 PM   #1492
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,942
Roger that
The Blue is useless
Brown Dog is offline   Reply With Quote
Old 04-30-2011, 08:15 PM   #1493
Brown Dog
Brown Dog's Avatar
Oddometer: 1,942
That is one FINE LOOKING BIKE, Orange Frame & all
It just needs SILVER RIMS to match the SILVER FORKS 3
Old 05-02-2011, 02:38 PM   #1494
malcolmzilla
Oddometer: 57
A pic of the AWD build as it sits, about 60% complete. Taking my time, 1st KTM so familiarizing myself with not only the bike, and setup, decorking, emissions delete, aftermarket armor, suspension, controls and other parts, but also the AWD conversion.
Question: Is the black plastic housing in the coolant lines above the crankcase a thermostat? Can I eliminate it? With factory XCW parts, or an aftermarket line kit? Thanks in advance.
malcolmzilla is offline   Reply With Quote
Old 05-02-2011, 02:43 PM   #1495
malcolmzilla
Oddometer: 57
Also, as above the screen in the exhaust tip is NOT the spark arrestor? It's for noise supression? I wired it on. Cut out the internal restrictor.
Old 05-02-2011, 02:53 PM   #1496
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,038
I thought the consensus was the screen at the tip was more of a dissipator to keep from melting the stock turn signal. I'm sure it helps with noise and may also serve as a secondary spark arrestor. It might also add enough restriction (coupled with the inner restriction) to run stock jetting almost safely.
I think the real spark arrestor is a Krizman (sp?) type way down in the muffler.
Yardstick is online now   Reply With Quote
Old 05-04-2011, 04:46 PM   #1497
oinky1982
Oddometer: 23
don't start with kick
HI every body, my bike start verywell with the e-start, but won't start with the kick any issue ????
when I try to ride at a regular speed like 50mph, it's seem the rpm won't still a the same point it's alway have a small variation, making the bike very hard to drive on road,
oinky1982 is offline   Reply With Quote
Old 05-04-2011, 07:25 PM   #1498
Bora20
Oddometer: 854
Rejet, desmog, regear. Basically make it like the XCW and it will run fine. Do a search on ktmtalk.com on how to fix it.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 05-04-2011, 08:30 PM   #1499
spagthorpe
spagthorpe's Avatar
Oddometer: 14,684
530 changes from 2008-2009? I know they fixed some things with the 2009s, and that would be the way to go, but if you found a 2008 for the right price...
How would you know if it was a burner if buying it used? What could you check?
Anything that would make less than 2009 a deal breaker? I know Ned seemed to like his 2009 a lot more.
spagthorpe is offline   Reply With Quote
Old 05-04-2011, 09:08 PM   #1500
oinky1982
Oddometer: 23
It is already re-jet, de smog, my question his more it his to lean or to rich or wrong carb set up
Times are GMT -7.   It's 06:01 AM.
