Old 05-02-2011, 07:18 AM   #31
xr400r
xr400r's Avatar
Oddometer: 2,424
I don't understand the benefit of 50cc.....why not just make a 450, a 500.
I thought E3 was open class......
xr400r is offline   Reply With Quote
Old 05-02-2011, 07:31 AM   #32
Visigothic OP
Visigothic's Avatar
Oddometer: 174
I never understood that either but its probably 510cc like the 530. Why not call it a 510? Beats me. Then there are all the factory BB kits 570 etc. Why not make it a 570cc like the Husa and get a true BB?
Visigothic is offline   Reply With Quote
Old 05-02-2011, 07:37 AM   #33
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,518
the carb versus EFI is a bit of a red herring discussion. It boggles my mind that the motorcycle industry hasn't gotten it right considering EFI is ancient technology - and it seems to be pretty flawless on the street bikes.
But your point is well taken, I won't be buying an EFI off-road bike until they have gotten a few years worth of trouble free implementation. But as soon as they do, I'll be all over it.
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
Kyler is online now   Reply With Quote
Old 05-05-2011, 05:54 AM   #34
LukasM
Oddometer: 4,900
Not sure about the US but the Austrian site already has all the official info.
It still has the same displacement as the 520/525/530 EXCs always did (510cc, 95x72), and yes it has Keihin EFI (probably the same system as the Husaberg FE models).
Technical Details
Engine
Engine type Single cylinder, 4-stroke
Displacement 510.4 cc
Bore/stroke 95/72 mm
Compression ratio 11,8:1
Starter/battery Kick- and electric starter / 12V 4Ah
Transmission 6 gears
Carburetor Keihin EFI, flow restrictor 42 mm
Control 4 V / OHC with rocker levers
Lubrication Pressure lubrication with 2 oil pumps
Gear ratios 14:36 17:32 19:28 22:26 24:23 26:21
Primary ratio 32:76
Final drive 14:50 (13:50)
Cooling Liquid cooling
Clutch Wet multi-disc clutch, Brembo hydraulics
Ignition Keihin EMS
Chassis
Frame Central double-cradle-type 25CrMo4
Subframe Aluminium
Handlebar Neken, Aluminium Ø 28/22 mm
Front suspension WP-USD Ø 48 mm
Rear suspension WP-PDS shock absorber
Suspension travel front/rear 300/335 mm
Front/rear brakes Disc brake Ø 260/220 mm
Front/rear rims 1.60 x 21''; 2.15 x 18'' Excel
Front/rear tires 90/90-21''; 140/80-18''
Chain X-Ring 5/8 x 1/4"
Silencer Aluminium
Steering head angle 63.5°
Wheel base 1,482±10 mm
Ground clearance 345 mm
Seat height 970 mm
Tank capacity, approx. 9.5 l
Weight, without fuel, approx. 111.5 kg
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 05-05-2011, 02:22 PM   #35
Visigothic OP
Visigothic's Avatar
Oddometer: 174
Talking 2012 500 exc changes!!!!!
Here is some more info
new engine the newly developed engine, the 500 EXC KTM engineers have created a new dimension: the engine was designed from the ground up and is now even more compact, lighter and stronger than before. Less oscillating masses and a balance shaft to reduce vibration. new exhaust muffler The new and improved muffler of the 500 EXC is not only more volume and a new design, it also reduces the noise level in the future, more stringent standards. new cylinder head new cylinder head was in the OHC cylinder head of the new engine,the 500 EXC all channels and the combustion chamber have been redesigned. The new camshaft, four valves actuated by rocker arms. Inlet side, high-quality titanium valves are used. The as yet oblique cylinder head cover makes service work. new cylinder and piston new cylinder and piston, the cylinder of the 500 EXC is specifically designed for the new engine configuration on. The new, 15% lighter forged pistons minimize the oscillating mass and improves stability at high speeds. New nitrided piston rings provide maximum wear resistance. new crankshaft new crankshaft, The main focus of the crankshaft of the new KTM 450 EXC put the engineers on the reduction of oscillating masses. Thanks to the new, lighter connecting rod and the new, lighter pistons, they were able to achieve minimal vibration and maximum speed stability. new motor housing the new engine case of the 500 EXC weighs nearly 2 kg less than its predecessor and is also more resistant to damage from rocks or fall. This was achieved by using a high-strength, elastic aluminum alloy and by the change from sand casting to die casting. new balance shaft new balance shaft, the new, more compact balancer shaft, the 500 EXC vibrations not only eliminated, but also serves to drive the water pump. This intelligent multi-functionality with the compactness and low weight of the new engine in the 500 EXC. new oil new oil circulation circuit, the new engine of EXC 500 is equipped with a common oil system for the engine and gearbox and two oil pumps. A pressure pump lubricates the engine, a vacuum pump sucks oil from the crankcase and lubricates the transmission, and thus the clutch. This results in conjunction with a steel membrane in the housing, a vacuum that increases the power of the engine. EFI / EMS new engine EFI / EMS new Keihin The newly developed system provides management with electronic fuel injection for spontaneous response of the engine. . With an optional Map Select Switch can be activated for different engine characteristics.
new clutch new clutch used the newly developed coupling of the 500 EXC with a sturdy steel basket and gear-friendly shock damping for the first time a plate spring instead of the usual coil springs, which reduces the operating force considerably. The hydraulic actuation of Brembo ® offers a sensitive modulation of the clutch.
Visigothic screwed with this post 05-05-2011 at 09:45 PM Reason: oops
Old 05-05-2011, 02:28 PM   #36
spagthorpe
spagthorpe's Avatar
Oddometer: 13,670
Damn, that is a sexy beast. I guess black rims are out of vogue again.
spagthorpe is offline   Reply With Quote
Old 05-06-2011, 12:34 AM   #37
DRjoe
DRjoe's Avatar
Oddometer: 4,243
Feck the old rfs I want that engine.
Old 05-06-2011, 01:06 AM   #38
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,739
so when will the 2012 bikes be here in oz???
You suck. And your mother dresses you funny.
Life is one lap with no restarts and the Finnish line is unknown......keep going!
mickd is offline   Reply With Quote
Old 05-06-2011, 04:19 AM   #39
Super Enduro R
Super Enduro R's Avatar
Oddometer: 115
The first bikes are due in the UK next month
KTM 500EXC-F
Ive bought one !
Super Enduro R is offline   Reply With Quote
Old 05-06-2011, 04:20 AM   #40
Super Enduro R
Oddometer: 115
The 6 days has black rims
Old 05-06-2011, 05:14 AM   #41
BikePilot
BikePilot's Avatar
Oddometer: 10,901
Originally Posted by Sparrowhawk View Post
EFI & kickstart, a rare combo these days.
Rare except for every current full size japanese MX bike made I expect the FI will work fine, its a japanese FI system and the same supplier makes systems for numerous other things that work just fine (and for that matter the blue ktm's have very nice FI).
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 05-06-2011, 05:26 AM   #42
rjharris
rjharris's Avatar
Oddometer: 410
Looks to me like they are using the EFI, head design, rear shock, etc...from the late model 09 to 11 Husabergs. Crankcase too.
Piston still goes up and down instead of the 70 degree design Cool bike!
2008 Yamaha WR250R
2009 Harley Roadglide
2010 Husaberg FE 570
2012 Yamaha Super Tenere
I like Big Tanks and I cannot lie!
rjharris is offline   Reply With Quote
Old 05-06-2011, 05:38 AM   #43
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 356
KTM 2012 off-road model range & specs brochure in English @ Google Docs:
https://docs.google.com/viewer?a=v&p...thkey=CPqDq6ED
Stable: KTM 950 SE // finnduro.com
FinnDuro is online now   Reply With Quote
Old 05-06-2011, 08:53 AM   #44
Visigothic OP
Visigothic's Avatar
Oddometer: 174
oil capacity?
Has anyone heard how much oil this new motor holds? The 530 held a skimpy 1.3 liters total. It would be nice if this thing holds at least 2.0 liters total for longer camping trips and service times etc. It just makes good "common sense" but the last time we've seen that was in 1776.
Old 05-06-2011, 02:58 PM   #45
header
Chris
header's Avatar
Oddometer: 1,683
Yeah because this bike was developed with the intention of people camping off it .I think the only bike ever built for crazy ADV's like us was KTM's 640adv which was close to the mark but still off a little.
Its an enduro bike so I seriously doubt it'll hold more than a liter and a half.
KTM 530exc
Header's journal
525exc refresh
header is offline   Reply With Quote
Times are GMT -7.   It's 04:31 PM.
