05-09-2011, 03:37 PM
#5521 | |
Oddometer: 20
I'm mostly just frustrated after reading all the posts from guys who walked in a bought a Tiger while I've been waiting 4 months. |
05-09-2011, 03:42 PM
#5522 |
Bring us some fresh wine!
Oddometer: 2,328
Very timely. I'm looking to do the same kind of thing since it looks like it might be a few weeks until Motech gets its act together with the top rack. I ordered the Givi universal mounting plate for monokey cases (which I use successfully on my 1050 Tiger) and I will try to see if I can mount it directly as you have, or if that doesn't look doable, to have a plate fabricated to put the Givi mount onto which then bolts onto the bike using the 4 mount points that are already there. It doesn't seem like the stock plastic rack can really take any significant weight since there's not really anything underneath it. Are you mounting it using the stock holes drilled into the rear subframe or are you just mounting it to the stock rear rack? |
05-09-2011, 03:46 PM
#5523 |
Planning Next Ride
Oddometer: 230
$12 rear rack
I wanted a wider rear rack that would support things like tents and dry bags a little better but I could also use my Givi adapter plate (see above post) for when I want a top case.
The aftermarket is still pretty scarce on racks and I didn't feel like spending the money on a Touratech or Happy Trail quite yet so decided to go the cheap route. I bought a 14" by 17" black plastic cutting board at Target for $12: ![]() I figured out the pattern I wanted to go around the love handles: ![]() I used a fine tooth finishing blade in my table saw, some files, and a sanding block to get it cut out and smoothed up. The plastic melts pretty good when you're cutting, but it worked out. ![]() For mounting just the rack, I used 40mm SS button head bolts, fender washers, and 1/2" tall nested spacers sandwiched between washers. ![]() Here's the rack mounted w/o the Givi plate: ![]() ![]() ![]() I replace the two rear bolts with 50mm long socket heads and the Givi plate mounts on. Much sturdier now that it's sitting on top of the new rack: ![]() At some point I'll get out the drill and jigsaw and make some tie down holes or slots if I think I need them.
"In the end, it's not the years in your life that count. It's the life in your years." ~ A. Lincoln '11 Triumph 800XC ABS / '94 Honda XR650L / '06 Yamaha YZ125 / '07 Ural Gear-Up Thanks to my 2013 Sponsors - Motorex and Leatt What Next Wander Tour http://advrider.com/forums/showthread.php?t=853663 |
05-09-2011, 03:48 PM
#5524 |
Oddometer: 2,328
Nice, that clears it up. Thanks!
05-09-2011, 03:50 PM
#5525 | |
Planning Next Ride
Oddometer: 230
05-09-2011, 05:25 PM
#5526 | |
Not (w)reckless
Oddometer: 96
05-09-2011, 05:31 PM
#5527 | |
Oddometer: 9,700
- Mark |
05-09-2011, 06:57 PM
#5528 |
Bike Addict
Oddometer: 1,980
dare I bring up using Heidenau K60/Scout tires for this bike...? We love them!
Cheryl & Leslie's 44 day Tiger 800XC Alaska ADV OUR BLOG 2010 F650GS Cross Country RR '13 BMW F800GS |
05-09-2011, 08:00 PM
#5529 |
WANDRN
Oddometer: 235
They look nice, where do you buy them?
05-09-2011, 10:19 PM
#5530 | |
Far, far from the Garden.
Oddometer: 2,554
05-09-2011, 10:22 PM
#5531 |
Oddometer: 144
05-09-2011, 10:43 PM
#5532 |
WANDRN
Oddometer: 235
05-09-2011, 11:20 PM
#5533 |
I'd rather be riding
Oddometer: 2,570
05-10-2011, 06:15 AM
#5534 |
Adventure Commuter
Oddometer: 2,492
He said since it had such few miles on it he was going to wait to see what developed...
Chip `92 Yamaha TDM 850 “Discoveries are often made by not following instructions, by going off the main road, by trying the untried.” - Frank Tyger "Life begins at the end of your comfort zone." - Neale Donald Walsch |
05-10-2011, 07:03 AM
#5535 | |
Every ride is an ADV
Oddometer: 496
When I picked mine up there was some residue on the cylinder, which concerned me. The dealer said it was just an anti-corosion product. They cleaned it off and it hasn't returned. Fortunately it didn't look like yours does. I hope it isn't going to be a problem.
"If more is better, then two much must be just right" Gene '12 T100 110th Anniversary '12 NC700X/D |
