Old 05-26-2011, 11:17 AM   #1
duck OP
PsyKotic Waterfowl
duck's Avatar
Oddometer: 9,971
Dr. L. Duck Hubbard explains: Splientology (BMW K75, K100, K1, K1100)
I wrote this up for motobrick.com. I thought there might be some inmates who would find it useful/informative so I'm posting it here too.
First off, what the heck are "splines?" The dictionary definition is: Any of a series of projections on a shaft that fit into slots on a corresponding shaft, enabling both to rotate together.
In laymans terms that means some long gears in one rotating part that are paired with and fit into some corresponding grooves on another rotating part in order to transmit power.
From front to back 2 valve K bikes have three sets of splines:
- Clutch/transmission
- Transmission/drive shaft
- Drive shaft/final drive
4 valve K bikes have four sets of splines:
- Transmission/ front half of drive shaft
- Front half of drive shaft/rear half of drive shaft
- Rear half of drive shaft/final drive
CLUTCH/TRANSMISSION INPUT SPLINES: This set of splines transmits power from the engine via the clutch to the transmission.
Clutch friction plate splines:
Transmission input splines:
TRANSMISSION OUTPUT/DRIVE SHAFT INPUT SPLINES: This set of splines transmits power from the transmission to the drive shaft which spins inside the swing arm.
Transmission output splines located at the right rear of the transmission:
2 valve K bike drive shaft splines:
4 valve K bike drive shaft splines:
FINAL DRIVE INPUT SPLINES: The drive shaft output splines transmit power to the final drive via these splines.
2 valve K bike monolever final drive input splines:
4 Valve K bike paralever final drive input splines:
SPLINE WEAR: In general spline wear is caused by splines sliding back and forth against each other under load. If not kept properly lubed then this wear occurs much more quickly due to metal to metal contact while siding under load.
Here's some driveshaft output splines from a 52k bike that have been kept well-lubed and are in pretty good shape:
Here's some drive shaft output splines from a monolever 2 valve K bike that show lots of wear:
(Those aren't cobwebs. It's fibers form the paper towel I used to clean the grease off of the splines for the picture.)
The wear pattern is often referred to as "the mountain effect" because worn splines look like this:
WHICH SPLINES SHOULD I CARE ABOUT AND KEEP WELL_LUBED? Well, all of them really. However, the ones that are most susceptible to wear are the ones that slide under load.
For both 2 and 4 valve K bikes the clutch friction plate slides along the transmission input splines as you let the clutch out. Therefore, these splines are subject to wear and should be kept well-lubed. A common symptom of them requiring lubrication is difficulty downshifting or "false neutrals" (ending up in between gears) when downshifting, usually on 4->3 or 3->2 shifts. If you're new to rding K bikes then this symptom may be hard to recognize.
When lubing the transmission input splines be sure to take a close look at the clutch plate splines for the mountain effect. Usually those splines start to wear faster than the transmission input splines but when they start getting bad they also start to cause wear on the transmission input splines. Given how much effort it takes to get in there, if there's any significant mountain effect on the clutch splines then I'd recommend replacing the clutch friction plate with a new while you have things apart.
For both 2 and 4 valve K bikes the drive shaft input splines are held in place on the transmission output splines by a circlip inside the splines so those rarely, if ever, wear out.
On 2 valve K bikes the monolever final drive design causes the drive shaft output splines to slide back and forth along the final drive input splines as the suspension travles up and down so these too are subject to wear if not kept properly lubricated. (Some people claim this is a "design defect" of the monolever rear end. However, since properly maintained final splines can last 100,000 or more I consider it more of a maintenance issue.) The only good way to detect wear on these is by visual inspection which requires removing the final drive.
On 4 valve K bikes, the drive shaft output splines have a circlip that holds them in place on the final drive so those are not as subject to wear and will usually last the the bike's lifetime. The intermediate splines are robust and don't seem very prone to wear.
WHAT SHOULD I LUBE MY SPLINES WITH? Any lubricant containing a fair amount of molybdenum disulfide (a.k.a. "moly") is good for lubricating sliding metals. Here's a few of the more popular moly lubes favored by K bike owners:
Honda Moly 60 Paste: This is a "grease" containing 60% moly available at Honda car and motorcycle dealers as well as some other auto parts stores and Fleabay vendors. A 3 oz. tube of it costs <$10 and will last most people a lifetime. The Honda Part number is 08734-0001.
50/50 mix of Honda Moly 60 and Wurth SIG 3000 Spline Grease: This is one of the lubes recommended by one of the top BMW "gurus" in the country, Paul Glaves. The Honda provides the Moly and the Wurth 3000 is uber-sticky stuff which keeps the moly around longer so your splines stay well-lubed and you don't have to lube them as often. Based upon Glaves' recommendation on the MOA forum that's what I use these days. The only place I've found it for sale online is here.
GD 525: This is a product from Texas-based Guard Dog Moly and is another recommendation from Paul Glaves. I haven't tried this but if Paul Glaves says it works that's good enough for me. It also doesn't require mixing like the Honda Moly 60/SIG 3000 lube.
HOW OFTEN SHOULD I LUBE MY SPLINES? There isn't a hard and fast answer to this one other than "enough to minimize the wear." You probably can't do it too often though.
2 valve K bike monolever final drive splines: Many owners recommend lubing these splines every time you replace the rear tire. Another approach would be to do them every 10,000 miles. That's what I do. When you remove the final drive without draining it it gets rather messy unless you keep it upright. I use Mobil 1 synthetic gear oil on 20,000 mile intervals so that way I'm sure the splines stay well-lubed but only have to do it once without draining the gear oil from the final drive.
Clutch/transmission splines: BMW hardened the transmission input splines in 1990 and the recommended service interval was changed to every 40,000 miles. Before that it was annually I think but that's overkill if you're not logging a lot of miles. I don't have right answer but every 20-25,000 miles on a pre-90 bike and every 40,000 miles on later bikes sounds reasonable to me. However, if you ever start experiencing sticky downshifting then I'd get it done soon because that sticky downshifting is caused by metal to metal contact. (On the first K bike I logged any miles on, a K75RT, I didn't know about the downshifting thing and wrote it off to just being a klunky transmission. About 8,000 miles later I was left stranded when my splines stripped. It was an expensive learning experience.)
4 valve K bike paralever final drive and drive shaft splines: I do it every 20,000 miles when I change the final drive gear oil. That might be overkill though.
HOW MUCH SPLINE LUBE SHOULD I USE? On the drive shaft and final drive splines you can't use too much. Any excess will spin off harmlessly onto the interior of the swing arm.
There is the VERY mistaken notion about that you need to be sparing with the cluthc plate/transmission spline lube because if you use too much it will spin off onto the clutch friction surface. This is only partially true. If the lube comes out of the front of the splines then it can indeed spin off onto the clutch friction surface. However, if it comes out the back of the splines then, due to the raised collar on the rear of the clutch friction plate then it will just spin off harmlessly onto the inside of the bellhousing. So the best approach is to clean all of the old grease out of both sets of splines and lube the hell out of only the transmission input splines before putting the transmission back on.
It this picture below I used Mobil 1 synthetic bearing grease for demonstration purposes only because it's red and more visible in the picture. It's a clutch plate assembly pushed onto transmission input splines. The very fact that you can see that excess lube from the side demonstrates that it is well behind the rear clutch plate friction surface and will just spin off onto the bellhousing.
And here's how much of the Honda/Wurth 50/50 lube that I used when assembling my K75F:
Finally, if you pull your bike apart and the splines appear to be rusty then don't be alarmed. It's probably just the old red spline grease that BMW used to use.
Thanks for reading,
Dr. L. Duck Hubbard
By the way, if you enjoyed this post then please go to Amazon.com and buy my book, Splyanetics. It will teach you how to be a happy successful person and provide you with enough disposable income to own and ride a BMW K1600GTL.
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR
IBA #17739 (SS1K, BBG, 50CC)
http://home.comcast.net/~smithduck/BMW_Tours.htm
duck screwed with this post 05-26-2011 at 12:11 PM
duck is online now   Reply With Quote
Old 05-26-2011, 04:52 PM   #2
drneo
mmm... delicious
drneo's Avatar
Oddometer: 140
Nice write up! I'll second the Honda Moly 60 lube - it's a little expensive, but worth it.
Ridin through life on a '82 Honda GL500 Silverwing
check it out at: trainwiththom.com
drneo is offline   Reply With Quote
Old 02-07-2012, 09:12 AM   #3
GypsyWriter
GypsyWriter's Avatar
Oddometer: 1,023
Just wanted to say thanks (months later) for the great write-up, I'll be putting this one into my Favorites for future use.
Sarah
2012 R1200GS Rallye - Gypsy
2003 R1150GSA with DMC sidecar
Ask A Self-Publisher
"Don't be careful, be awesome." - Cornfed
GypsyWriter screwed with this post 02-08-2012 at 05:13 AM
GypsyWriter is offline   Reply With Quote
Old 02-07-2012, 08:48 PM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,356
I see no purpose in spreading excessive lube on the transmission input splines. Or any of them, for that matter - the sliding driveline splines can take a lot. I'm not completely sold that all you're doing is making a mess inside the bell housing. Glopping it on goes against the way I was taught to lube transmission splines, so that's a very difficult one to let pass.
Also, don't forget to thoroughly clean the splines before re-greasing. Metal particles grinding between the two surfaces will definitely hinder longevity!
Old 02-08-2012, 08:55 AM   #5
Tosh Togo
Oddometer: 1,594
Yes indeedy...too much of the good stuff can lead to new problems. Why is it that MORE is nearly always perceived as being "better"?...
You're dead-nuts on about old grit in the new clean lube. Dirt + lubricant = abrasive paste, and even the most mundane roadside crud is a lot harder than any metal parts.
Tosh Togo is offline   Reply With Quote
Old 02-08-2012, 09:06 AM   #6
GypsyWriter
Oddometer: 1,023
So what problems are we talking about here?
Sarah
Old 02-08-2012, 09:55 AM   #7
Wirespokes
Wirespokes's Avatar
Oddometer: 7,356
The danger is dust (metal, abrasive, mineral...) combining with grease to form cutting compound, which will then grind away your splines. You also don't want to chance the grease (now flung all over inside the bell housing) dripping down onto the clutch.
That's all you need - grabby splines, slippy clutch.
Old 02-08-2012, 02:23 PM   #8
Beamer Bum
Beamer Bum's Avatar
Oddometer: 177
Grabby Splines and Slippy Clutch? Sounds like porn star alias.
Working for my next trip
http://advrider.com/forums/showthread.php?t=721872
Beamer Bum is offline   Reply With Quote
Old 02-08-2012, 08:44 PM   #9
Tosh Togo
Oddometer: 1,594
Old 02-08-2012, 09:12 PM   #10
GypsyWriter
Oddometer: 1,023
Syfy. Ever should have cancelled that gem.
Sarah
Old 04-24-2012, 11:29 AM   #11
ericrat
Oddometer: 871
Bump
I am bumping this thread because I seriously hope I don't need it. My girl is immobile in St. Petersburg, FL. I am in Ohio.
Anyone in the St. Pete area have a spare K75 transmission?
St Pete Cycle service in tearing into now. I am probably over-reacting.
Will advise.
Eric
ericrat is offline   Reply With Quote
Old 05-01-2012, 07:26 AM   #12
helion42
helion42's Avatar
Oddometer: 225
I figure this also applies to older airheads as well? I'm trying to figure out how much grease to use on the final drive/wheel splines. When I cracked it open, the PO had put a ton of grease in there.
I bought some moly 60 - Only the end of the splines is exposed, so I hafta smear it on the exposed end and push the other mating side on it to push it down the splines. How much to ensure a good coating?
helion42 is offline   Reply With Quote
Old 05-02-2012, 01:28 PM   #13
ricochetrider
a certain something
ricochetrider's Avatar
Oddometer: 1,456
Off on a tangent, I have a 1988 K100 RS.
Is it a 4 valve or 2 valve model?
ricochetrider is offline   Reply With Quote
Old 05-02-2012, 02:19 PM   #14
richarddacat
high on honeysuckle
richarddacat's Avatar
Oddometer: 2,585
2 valve.
1990 saw all 4 cylinder K engines with 4v, and 100 HP in RS and LT trims. The K100 4v was updated to a 4v 1100cc engine in RS and RT models, and the new LT luxury models. The LT had an electrically adjustable windshield and factory installed sound system. The 1100 models also had paralever rear suspension.
01/92 K100RS 4-valve production ended. K1100RS production started 11/92.
* 05FJR/74R90s *
If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles.
richarddacat screwed with this post 05-02-2012 at 04:45 PM
richarddacat is offline   Reply With Quote
Old 05-02-2012, 04:33 PM   #15
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,809
It's best to clean the old lube and crud out if you can.
Where's the old stuff going to go when you put on new grease, then pack it down with the wheel splines?
Only one place I know of, and if you pack enough of it in there, you get final drive oil leaking out.
It happened to my airhead.
And +1 on the complaints about that heavily greased clutch spline. That just looks wrong to me, I don't care how much you know about spline greasing.
caponerd is offline   Reply With Quote
Times are GMT -7.   It's 09:20 PM.
