Old 05-27-2011, 10:27 AM   #46
crotchrocket3000
b00b
crotchrocket3000's Avatar
Oddometer: 220
Looks amazing, congratulations! Your klicktronic shaft looks a long way out.
crotchrocket3000 is offline   Reply With Quote
Old 05-27-2011, 11:22 AM   #47
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,618
The finished rig looks great !
How much suspension travel do you have in the LLs? Is the rear suspension stock?
bk brkr baker screwed with this post 05-28-2011 at 11:21 AM
Old 05-27-2011, 11:56 AM   #48
Neptune03 OP
Oddometer: 78
Electric shifter shaft
It looks like a Klicktronic but I purchased it from Pingel. I don't think they just rebadged the Klicktronic but make their own (although they sure look alike). Pingle also makes an air shifter but I think those only shift up. Concerning the shaft - it really isn't a long way out (of the shifter body); I extended the shaft length with a couple of coupling nuts with the stock rod end ball joint at the end. I did this for mounting reasons to involved to explain here. There are three markings on the shaft, the middle one is when the unit is at rest (which it is the way I have it set up) and the upper and lower ones are marks to show the recommended maximum throw when shifting. I positioned the pivot point on the shift lever so whether shifting up or down, gears are selected just before the lines are reached. Although this unit works great, I like the Translogic shifter on my Hayabusa much, much better. The shifter unit is more compact, making it much easier to mount and the shift buttons on the handlebar are ergonomically much easier to access. Thanks for your "congratulations"; I sure am having fun with it
Neptune03 is offline   Reply With Quote
Old 05-27-2011, 12:09 PM   #49
Neptune03 OP
Oddometer: 78
Shifter picture
I should have posted a picture of the Translogic shifter with my response above. If I had it to do over again, I would have put this one on the Yamaha too.
Old 05-27-2011, 01:54 PM   #50
Daytonacharlie
2 Wheeled Backpacker
Daytonacharlie's Avatar
Oddometer: 233
Amazing stuff! You're quite the mechanical engineer. I'd love to see it in the metal some day. My son attends FSU and from time to time I come down for a visit from Grayson (near Atlanta).
Great job. How's is it to ride so far?
1996 Triumph Daytona 1200
Daytonacharlie is offline   Reply With Quote
Old 05-27-2011, 02:34 PM   #51
Neptune03 OP
Oddometer: 78
Thanks for the kind words. No special talent just persistent. To you or anyone else passing through Tallahassee, I would enjoy showing off the Yamaha or Hayabusa and going for a ride almost anytime. Just let me know when you will be in the area. I plan on posting a few more pictures and a ride report tomorrow. Stay tuned.
Old 05-27-2011, 03:30 PM   #52
Daytonacharlie
Oddometer: 233
Thanks mate, will do.
dc
Old 05-28-2011, 01:03 AM   #53
3legs
Real men ride sidecars
3legs's Avatar
Oddometer: 1,125
Well done. Looks bloody nice and very professional. Makes my build look absolutely prehistoric (like it's owner).
3legs
3legs is offline   Reply With Quote
Old 05-28-2011, 01:10 AM   #54
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,475
Beautiful Job!!! How does it handle with the big front tire? I was never happy with my 175/15 on the front on the street.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 05-28-2011, 01:47 AM   #55
mb8
mb8's Avatar
Oddometer: 194
In simple terms......FUCKING AWESOME
You certainly have some mechanical/fabrication skills
Orange L0 650 V-Strom
mb8 is offline   Reply With Quote
Old 05-28-2011, 05:53 AM   #56
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,053
Awesome job.
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 05-28-2011, 06:40 AM   #57
Neptune03 OP
Oddometer: 78
Yamaha FZ1 dual sport sidecar build & ride report
I found a boat seat on EBay that I liked. I knew it would be water resistant, it had good lateral support and it looked comfortable. The only problem was that it was white. To rectify that, I purchased a can of adhesion promoter and landau black leather and vinyl paint from Eastwood Automotive. The adhesion promoter cleans and softens the vinyl preparing it for the paint. I wasn’t sure how well it would work but I am really surprised. The paint didn’t make the seat stiff and so far it is holding up very well.
The other reason I liked this seat is that the front portion of seat folds up and back. On a boat this allows the “captain” to stand up to see better while docking or stand to absorb the shock while pounding over waves. For sidecar use, it makes room for the passenger to stand up over the really rough stuff or move around (hang off) in turns or on off-camber terrain.
This shows the radiator guard and the back side of the flush mounted turn signal. The only problem with mounting the radiator in front of the passenger is the heat. It’s not real bad, and will be welcomed in cooler weather, but during the heat of Florida summer adds a little simmer to the ride.
Well, I have ridden somewhere between 400 – 500 miles of dirt and pavement since finishing the bike and I am having a blast. There is a section of graded dirt road about five miles long not far from the house. The road has no real tight turns but a bunch of fast sweepers of varying tightness. It also has a variety of surfaces consisting of soft sand, hard red clay, red clay with a thin layer of sand on top and gravel. While building this thing, I would go to bed at night dreaming about pitching it into the corners with the back end swung out and throwing dirt. I have to say, the reality is even better than the dreams. All I can keep saying is, “that it is a blast”. The power, speed and aggressiveness that I missed while riding the F650GS with Ural, is there in buckets on this bike. I know the speedometer is not correct because of the larger tires, but on the short straight sections I have glanced down and seen 100 on the speedometer and the corners are taken somewhere between 50 – 80 on this section of road. The bike is also very stable, going about 10 mph you can just whip the bars to the left and the backend will slide around doing a 180 and powering away in the other direction with no problems. I have noticed that when doing this, because there is not a lot of clearance between the tire and chain, the chain slightly rubs the tire. I believe it is happening because centrifugal force throws the chain into the tire and maybe there is some flexing of the tire’s sidewall. That is the only time it does it and the contact is very light.
I love watching World Rally Car Racing and am amazed at how much control they have on gravel, dirt and sand surfaces (WRC is very popular in Europe and they run very modified Citron, Subaru and other four wheel drive cars with big power that fly through the woods at incredible speeds over a variety of terrain). The tires I have on my bike and sidecar are the same tires they use and now I understand a little better how they can do it. I was shocked by how much traction I got off road and how quickly it stops on soft surfaces. My only concern is how long they might last on pavement. I have the Hayabusa with RDS for street use, but to connect the dirt roads around here a pretty good amount of tarmac will have to be run. I’ll just have to wait and see how well the Rally Tires hold up.
Between the taller tires and the adjustable shock links I installed, the bike is much taller than stock but it still has the stock rear shock. I thought that it would be way too soft but I have been pleasantly surprised. I haven’t been on really rough stuff yet but even over the washboard roads I have been riding, the back end seems to respond very well. The thing I was most concerned about was the sidecar’s suspension. I assumed that the shock on the single sided VFR swingarm would be way to stiff, but it seems perfect and provides a good ride for the passenger. The one area I need to address is the front end. Over washboard surfaces, especially while cornering fast, it seems like the shocks are not responding quickly enough so the ride is harsh. I have about ¾ inches of sag and the shocks seem to be using all their travel but the ride is still jarring. I don’t know if the problem is the springs, the shock’s compression dampening or the weight of the wheel, tire and swingarm. Bill suggested that I see how much weight is on the front end then remove the shock’s spring so I can see how much travel I am getting and finally call Progressive to see what they can recommend.
My Hayabusa, and the two bikes I had before that, have all had center hub steering which is AMAZING, so this is the first bike I have owned with leading link forks. Compared to the other outfits I had with standard telescopic forks (before the center hub ones), the leading links are like night and day. The steering effort is very light, there is no pull to the right or the left and there is absolutely no head shake at any speed on pavement. What I do notice is that on dirt roads the front end is easily deflected by ruts and other irregularities. I just ordered a VW steering damper from EBay so will have to see if it eliminates this problem.
Overall I am very pleased with how it handles and performs. I know its performance is not even a fraction as serious as Scott Whitney’s (HogWild) outfit, but for a street bike that was home built it is about perfect for my needs. I look forward to kicking up the dust around Tallahassee, riding the beautiful forest roads in North Carolina and maybe someday riding some of the Trans American Trail.
At some point I hope to post some videos of the Yamaha in action but until then I hope you enjoyed my build post. I sure had fun building it and look forward to seeing where all those dirt roads go that I couldn’t explore on the Hayabusa. If you have any other questions about my experience riding the thing or the build, please do not hesitate to ask.
Old 05-28-2011, 06:57 AM   #58
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,640
It sounds like a hoot to drive. Great build thread.
Thank you for taking the time to show it off to us.
Very impressive.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 05-29-2011, 05:48 PM   #59
ronvan
ronvan's Avatar
Oddometer: 49
Awesome!
ronvan is offline   Reply With Quote
Old 05-29-2011, 07:40 PM   #60
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,894
This is why I got into hacks !!!..AMAZING stuff brother !!!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Times are GMT -7.   It's 09:11 AM.
