05-27-2011, 01:12 PM
#31 | ||||
Oddometer: 4,902
05-27-2011, 01:24 PM
#32 | |
Android GPS Software
Oddometer: 1,700
Most of y'all have a set of experiences in your mind about how these devices work. Your experience tells you that a map application uses the cell radio and GPS to determine location. Just trust me when I tell you it doesn't need to. It is trivial to query the hardware for location updates from any 1 of 3 sources on the phone. Network, GPS, and WIFI all offer clues. I will only be requesting info from GPS because that is the only likely candidate on the trail and it should keep power consumption down. This is why those Apps generally consumer a lot of power. A lot is going on here that won't help us out on the trail.
05-27-2011, 01:29 PM
#33 |
Guest
Oddometer: n/a
subscribed! good luck on getting this project on it's feet.
05-27-2011, 04:04 PM
#34 | ||||||||||||||||||||||||||||||||||||||||||
Oddometer: 4,902
Sounds like you're right on track craftycoder. Although your terminology is off a bit. For instance while your differential between the cell and the GPS is right on, the GPS is still using radio tech.
Global Positioning System
Check this how it works link out. Pretty decent explanation. GPS Calculations As opposed to the radio frequencies of cell phones. Below are the ones used in the U.S. Frequency bands used in the United States
05-27-2011, 06:31 PM
#35 |
Can u smell the It's Its?
Oddometer: 307
Hi Crafty,
This is good stuff. Keep on going! When you request info from GPS only, how do you know it isn't using (or attempting to use) the cell phone or wifi signals to reduce the time the real GPS needs to home in? Is it a specific function call or call parameter? Daniel
Greatest Road iPad/iPhone app for bikers - find and rate great roads as recommended by other bikers |
05-27-2011, 06:37 PM
#36 | |
Oddometer: 1,700
I am just about finished getting the Vector OSM maps to render properly in perspective mode with the compass off 0 degrees. This is a big step in the right direction. I tested the map tiles in perspective mode following my driving (changing direction automatically such that the top of the map was my direction of travel) this afternoon and all looked nominal.
05-27-2011, 07:09 PM
#37 |
Oddometer: 4,902
Wheww
if it weren't for programming guys like you I'd still be navigating by the stars! |
05-27-2011, 07:13 PM
#38 |
Oddometer: 1,700
Personally, I think the cartographers deserve most of the credit. I just love maps though. They make me feel like a kid, imagining getting into adventures in the foreign lands I'm looking at on the paper.
05-27-2011, 07:14 PM
#39 |
Oddometer: 307
Here in SF there's so much fog we needed to invent an alternative.
05-27-2011, 07:20 PM
#40 | ||
Oddometer: 4,902
The hours and hours spent pouring over all kinds of maps when I was a kid gave me an appreciation for the work put into it. Imagine the effort back in first days. Now with all of the advancements and building off the work of the old timers I suppose it's easy for some to just take it for granted. Whenever I meet someone like that i suggest a week retreat into the wilderness... well what we have left... without any sort of modern convenience... well except for the soft tissues.. that would be just too much to ask of the ladies... ![]() Quote:
![]() That is one of the few places I've not been in the lower 48 |
05-29-2011, 09:20 AM
#41 |
Oddometer: 1,700
I did my first 2 wheel test of the software today. I did a 60 mile ride on a bicycle. Vector maps, in perspective mode, network radios shut off (airplane mode). Quite a bit of the course was under dense canopy. Pretty bumpy in places as well. I learned that it is important to fix the application in Portrait or Landscape mode because the bouncing confuses the accelerometer, the software had that feature already so that was a road side fix. The phones GPS tracked well in all locations. Speed seemed pretty accurate, but I don't have a calibrated speedo to verify, not that it really matters. Endurance wise, the app used 80% of my battery in 3 hours (it was not plugged in at all). There was also one area where the maps I rendered were not very good at all. I need to verify, but I believe the problem is in the source map file rather than the renderer, though that is just wishful thinking. All in all, a great first cycle test.
05-29-2011, 11:17 AM
#42 |
Tracking this. Was the remote (PS controller) going to control pan/zoom etc functions, maybe some phone function as well???
05-29-2011, 12:47 PM
#43 | |
Oddometer: 1,700
I want to clarify that the remote is still just an idea. I have all the skills to implement it, except for producing an inexpensive weatherproof housing for it. I'm pretty sure I can find someone to do that portion so I may do it. The phone GPS was pretty good, so I don't exactly see the need to add an auxiliary GPS receiver at the moment. More testing will need to be done. The most compelling reason to create the remote though is so we can weatherproof our phones and still have access to map functions. That seems pretty important to me. |
05-29-2011, 01:31 PM
#44 | |
To be able to answer phone calls without stopping, touching the screen etc,to be able to reply to text messages without typing, and of course music player functions.... I like where you're going with that. if you want any help I'm in for what it's worth. If you remember, we talked about the gas station map idea a while back... |
05-29-2011, 01:55 PM
#45 |
Oddometer: 159
Looks like this will be a great app. Looking forward to it.
