Old 05-30-2011, 07:40 PM   #1351
DNTOUCH
Need more time to ride.
DNTOUCH's Avatar
Oddometer: 786
Originally Posted by sanjoh View Post
Here it is.
DC needed
So i am to guess then that i should take the 1.8 amps and figure it out.?
Which equals 21.6 watts..
'08 DL1000 (with some stuff
DNTOUCH is offline   Reply With Quote
Old 05-30-2011, 10:59 PM   #1352
dacrazyrn
ED RN Adventurer
Oddometer: 495
Times that by 2 and round up.
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me?
“When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama
Life is Risk Management
'09 BMW F800GS-Fate Honeyed GSabelle
dacrazyrn is offline   Reply With Quote
Old 05-31-2011, 05:50 AM   #1353
DNTOUCH
DNTOUCH's Avatar
Oddometer: 786
Why?
Old 05-31-2011, 05:50 AM   #1354
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Why?
It gets you to 44.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 05-31-2011, 06:25 AM   #1355
DNTOUCH
DNTOUCH's Avatar
Oddometer: 786
Ok ,,, so i'm not good at math i never tried to be, but by looking online i found that you take amps x voltage (AC or DC) = wattage.
So are you saying that to get the model name thats what was done,,,, or i did the math wrong and by taking the 1.8 amps he has listed on the site i am coming up with the wrong wattage.?
I just rolled out of bed so hopefully that makes sense.
Old 05-31-2011, 06:55 AM   #1356
JDLuke
JDLuke's Avatar
Oddometer: 8,644
You're overanalyzing this.
You got the right calculation and you performed it correctly. At 1.8 amps these lamps by rights will burn 1.8(Amps) * 12(Volts) to get you 21.6 Watts per lamp.
You received a mildly snarky response suggesting that if you double it and round up you'll get to the model number (21.6 * 2 = 43.2, round up and you get 44) . There's not much more to it than that.
I have no idea if the model numbers are related to power consumption in real life, or if it's just an amusing coincidence.
Old 05-31-2011, 09:05 AM   #1357
univibe88
Slidell4Life
univibe88's Avatar
Oddometer: 2,381
Because they are meant to be used in pairs. That's why doubling the numbers gets you to the model # 44.
List of my old bikes that no one cares about
Current bikes go here to make others jealous
"I like my ride plans like my women...loosely put together with a chance of getting wet."
univibe88 is offline   Reply With Quote
Old 05-31-2011, 09:34 AM   #1358
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
Why does it matter what the model number means? Most model numbers mean little if nothing anyhow. They are awesome lights and I am sure to be ordering a few more sets for my other bikes shortly.
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 05-31-2011, 10:16 AM   #1359
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,583
John
I gave the Spring promotion code to a friend and when they tried to order this morning, your site said the code was expired or invalid. I thought it was good through the end of May
Help Stop McNugget Rage
WeeBee is offline   Reply With Quote
Old 05-31-2011, 12:07 PM   #1360
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
I'd like to see a bit larger diameter LED light with on-road beam pattern (fog and driving light) and proper cut-off, similar to BMW/Hella 14W accessory LED's but more powerful.
I'd mount both driving and fog light, the '44' is bright but beam is so focused.
I think ~100lumens/Watt is state of the art right now.
tallguy-09 is offline   Reply With Quote
Old 05-31-2011, 04:27 PM   #1361
TheKentuckyWonder
Oddometer: 7
Can you use one dimmer for two different lights (ie a 30 and 44) or will that cause one to be much brighter than the other?
What type of LED are they - semiled or CREE?
TheKentuckyWonder is offline   Reply With Quote
Old 05-31-2011, 05:01 PM   #1362
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Yes, you can use as many lights as you wish, up to 96watts or 8 amps for each dimmer.
That is a great question! The technical explanation of why they appear the same could be it's own topic!
Can someone with a model 30 and a 44 post a pic?
Cree
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 06-01-2011, 08:13 AM   #1363
Ricky Chuck
Red Green Rulz!
Ricky Chuck's Avatar
Oddometer: 490
Originally Posted by Ricky Chuck View Post
OK, just BB pics during the day in the garage, but you can see where I initially have the leds, using some existing holes in my shield. Gets them up about as high as I am able, but I have decided to move them down on my lower fork under the headlight, to get some triangle effect, and to keep my blinkers visible. The Memphis clamps will be in soon so hopefully that will close the chapter. Dimmer and high beam override options work on the wireless fob, just need a place to fasten it. Once I have them on the forks I will suck it up and put on the Xpel yellow covers and see what it does, since NO ONE apparently has done this yet ROFL.
Not a great pic, but you can see the 44 (left side looking at pic) and 30 on right. 44 is brighter, due to extra led? :) Using one dimmer
Ricky Chuck is offline   Reply With Quote
Old 06-01-2011, 08:23 AM   #1364
Rhombic
Typical KLR *****
Rhombic's Avatar
Oddometer: 192
Those are really bright lights. Would you have a pic with both the LED's and the turn signals on? They aren't being washed out by the LED's are they?
Typical KLR owner now on a '92 R100GSPD
No longer talk at all about what a good man ought to be; be such.
Marcus Aurelius
Rhombic is offline   Reply With Quote
Old 06-01-2011, 08:43 AM   #1365
Ricky Chuck
Red Green Rulz!
Oddometer: 490
Good question, and it has been debated here. I have moved them down to the lower forks since this pic was taken...that was an opportunistic mount location since there were some matching holes in the shield I put on. My opinion is like yours, it would wash out the turn signals if they were on when you needed to signal, which is why I moved them, even though I liked them being high. I have some leds above the turn signals that flash counter to the turn signals, so there are more things going on, but still going with the lower mount area. Can get a pic if no one else posts one.
Times are GMT -7.   It's 02:23 AM.
