05-21-2011, 07:17 PM
#1 |
adventurer
Oddometer: 424
Mitas Tyres
wow that was one of the hardest tyre changes Ive done. I just hope I dont get a flat out bush as Im sure ill need a pub near by. On the positive side I did have My Ballard Tyre Levers and all the extras that My shed offers. all the best Beetle.
05-21-2011, 08:07 PM
#2 |
All round nice guy
Oddometer: 5,928
Over 50, I'm still working on replying :-)
And beet they are pricks cold but. Ok hot
F5 is for wussies Command R is where the actions at! |
05-21-2011, 08:21 PM
#3 |
Dinosaur
Oddometer: 21
Agreed
I recently was gifted with a hole appearing in the side of my E08 Rear. Figured "Well, cant exactly fix that." So i rode the 50k;s home whilst leaning up over the headlight.
75% of the side wall was torn by the time I got home but it was still on the bead. Completely. Make sure you get her nice and wet round the edges before slipping on a new one. |
05-21-2011, 09:10 PM
#4 |
Nipple boy
Oddometer: 4,101
05-21-2011, 10:41 PM
#5 | |
Big Adventurer
Oddometer: 1,780
Sorry to use car tyres to illustrate.... but the top one went at about 150 k... and that was the sidewall (untouched) by the time I stopped. The bottom one went at 170 kph on the main straight at Winton. The tread did a bit of damage to the car. The first one was a puncture. The second one was old rubber. I won't use a tyre that's over 5 years old now. ![]()
A man should only do the work that is required of him. To do more is a form of greed. |
05-22-2011, 02:25 AM
#6 |
adventurer
Oddometer: 424
06-08-2011, 03:54 AM
#7 | |
caretaker
Oddometer: 279
E-09
what was the dimension of the rim ? ... Mitas screwed with this post 06-08-2011 at 04:12 AM |
06-08-2011, 03:06 PM
#8 |
Trans-Global Chook Chaser
Oddometer: 2,697
If it's a std DR650 it would be 17" - The DR rears are well known to be tight at times.
I've put a few of each E0-7 & E0-9 on the 18" rear of my 640 with no problems, similar to fit to any other tyre. Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
06-08-2011, 03:39 PM
#9 |
XS650 Allroads Traveller
Oddometer: 5,503
Running a E-07 [18"] on one of my XS' & the bloody thing won't wear out!
down to the centre 'bar' in the middle of the tread, what's the legal limit one of these tyres? Cheers Baza
1981 XS650SH "Tourer" [ For Sale - when / maybe?], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' www.aussiegreyghost.smugmug.com Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
06-08-2011, 04:31 PM
#10 |
Oddometer: 1,422
Hate to say it, but are you sure you weren't doing something wrong? Like making sure the tyre slips into the centre of the rim on the opposite side to where you're levering?
The last three of four times I fitted an E0-7 (slightly different tyre of course) it was a piece of cake, even when I was doing it in a ditch with just a couple of short levers and no lubrication of any kind (the only hard part was pumping the blooding thing up again with a tiny hand pump). Every time I've ever had difficulty fitting tyre, I realised eventually that my technique was wrong. |
06-08-2011, 04:34 PM
#11 | |
Oddometer: 1,422
It'll have no grip at all in the dirt, long before it's actually illegal. |
06-08-2011, 04:46 PM
#12 |
1pissanter
Oddometer: 199
Qld Transport says:
"Each tyre fitted to the motor vehicle must have a tread pattern of a depth of at least 1.5mm on every part of the tyre that touches the road, and must not be fitted with cleats or another device likely to damage a road." Same for NSW
KTM 69TE
watch this pace ![]() grimripper screwed with this post 06-08-2011 at 04:56 PM |
06-08-2011, 07:39 PM
#13 |
Oddometer: 310
You spring for a new tyre beet ,, What gives
![]() B |
06-08-2011, 08:53 PM
#14 | |
--< oLd 'n SlOw >--
Oddometer: 848
The faster you go, the less it hurts..... ![]() Looking for interest in the 2013 ride www.motorcyclingagainstcancer.org.au |
06-08-2011, 08:57 PM
#15 |
Oddometer: 335
Lupine and I had been trying ti fit a new EO-9, I think, to his DL1000. Ended up cutting the bead with an angle grinder to get the old one off. Was interesting to say the least. Was lucky we didn't set the fire alarms off in the cycle shop where he works.
Time decides who you meet in life, your heart decides who you want in your life, but your behaviors decide who will stay in your life. |
