06-02-2011, 09:02 AM
#1366 |
Master of none
Oddometer: 10
I got everything fabricated and painted and mounted up a pair of 30's on my Griso
![]() ![]() This is the lowest setting on my hardwired hi-beam bypass dimmer and the headlight is off, just the marker light is on. ![]() My camera wont handle the lights when they are on 100%, just go outside and stare into the sun for a while and you'll get the same effect as looking into the lights on full power.
'07 Guzzi Griso, '96 Guzzi 1100 Sport, '75 BMW R75/6-for sale |
06-02-2011, 09:26 AM
#1367 |
The Road Scholar
Well, I just ordered a Model-30 to install in the nose of my sidecar to see how it handles being inset into the bodywork like that.
There will be some air gap around it due to the size of the well and the diameter of the lamp, so that should allow some cooling, the question is whether it will be enough. On the existing 35watt H3 bulb PIAA lamps the manufacturer actually wrapped the OD of the lamp housings with a closed-cell foam to fill in the extra space around the lights, and the bulbs are not overheating. So if I leave the gap open I am hoping that the lower power Model-30 will be alright. I will report back after I get a chance to try it. I also ordered one the new waterproof LED voltmeters to install on the other bike. I will give a review of it as well.
Karl Kugler www.theroadscholar.net 2005 BMW R1200RT w/Hannigan-LT sidecar 2002 BMW R1150RA In Memoriam: Harley, 1993-2010 You will be missed. |
06-02-2011, 02:02 PM
#1368 |
Wheelies R Bad
Oddometer: 214
06-02-2011, 03:42 PM
#1369 |
Oddometer: 63
anyone figure out a way to mount a solo light somewhere between the forks? mabye on the fender or .... ? photos?
06-02-2011, 03:44 PM
#1370 | |
OMGWTFFTW
Oddometer: 1,235
The signal wire allows you to monitor a voltage other than your power source. In my case I am just monitoring my battery voltage so the +power and signal are shorted together. FL Pepper screwed with this post 06-02-2011 at 03:53 PM |
06-03-2011, 09:43 PM
#1371 |
Oddometer: 7
Just to clarify, the 44 has more of a flood pattern and the 30 has more of a spot pattern?
06-04-2011, 03:21 AM
#1372 | |
Purveyor of Light
Oddometer: 3,667
Beam patterns can be seen on the website for the particular product under detailed description.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
06-04-2011, 06:06 PM
#1373 | |
The Road Scholar
The signal wire allows the display to shut down when the ignition is turned off, therefore eliminating any battery drain when the bike is not running. It is basically like having a built-in relay circuit for the display to shut the unit down when the bike is turned off. Yes, the drain will be minimal if you just wire it to stay on all the time, but it IS a nice feature to have added in. Not having lights/digits glowing on your bike will also make it stand out less when it is parked at night; which can have its own advantages at times... ----- I didn't realize how short the wires were going to be on the V/M. Personally, it would be very nice if the unit could be supplied with 3-foot wires so that it could be connected to the battery terminals without having to splice extra wire in. Every splice is another potential place for failure in the future... How much extra would it cost to have the manufacturer add an extra 2-3 feet of wire to the units??? The incremental cost couldn't be all that much. As it is, I will probably run the included wire into the headlight shell so that the splices are protected from the elements, and then run the connecting wires to the battery and a switched circuit from there. ----- I have yet to see how viewable the digits will be in direct sunlight, but my initial impression is that it is a nice compact unit and not too bright for wrecking night vision. Still have not decided between velcro or permanent adhesive mounting. The ability to add a zip tie or two would be a nice feature as well. Hint, hint...
06-07-2011, 09:12 AM
#1374 |
Gamer
Oddometer: 1,025
I want to give a big bump to John and Sharon. I bought a pair of Model 30s last year and have been very pleased with them. Recently, one of the lights failed. I contacted John, who told me to mail it back to Sharon for repair. The light was back in two weeks, fixed, no charge. Great service, guys, you know how to take care of your customers.
06-07-2011, 10:33 AM
#1375 | |
The Road Scholar
Glad to hear that he stood behind the product! Do you have an estimate of how many miles/hours the light had on it before it went out? Type of conditions it was used in? (temps/vibes/etc?) Just trying to get a little more information to build up some data points on reliability/longevity. Thanks!
06-07-2011, 10:57 PM
#1376 | |
Wheelies R Bad
Oddometer: 214
06-08-2011, 10:44 AM
#1377 |
Gamer
Oddometer: 1,025
You can see a picture of how I mounted the lights below. I took the picture yesterday. I got the lights last December and had ~800 miles, much commuting in cold NYC weather, predominately on the road, before the light failed. As I understand it from John, the failure was related to the HIDs I previoiusly installed, rather than cold weather or hard riding. I do not understand the mechanics of the interference btwn HIDs and LEDs and am hoping this will not repeat. I can tell you that HID/LED combo is stunningly brilliant. Here's the pic:
06-08-2011, 11:41 AM
#1378 | |
Need more time to ride.
Oddometer: 785
Umm yeah, that may take some explaining because that makes no sense at all. Not to mention an 800 mile "on road" life span.? As long as the lights see a constant 12Volts +/- and they are gounded correctly they shouild be fine,.
'08 DL1000 (with some stuff |
06-08-2011, 05:38 PM
#1379 |
Oddometer: 2,875
Something to do with a voltage drop while the HIDs are firing up? I know they draw insane amps for a few seconds...
I don't know how low voltage would harm LEDs, though. I'd call it an unusual defective light, personally. Good on Sanjoh for agreeing and taking care of you!
We had part of a Slinky. But I straightened it. |
06-08-2011, 10:02 PM
#1380 |
OMGWTFFTW
Oddometer: 1,235
ADVmonster LED lights at the Gap
Here's me and my lights caught by Killboy last month.
![]() When I have them fired up, people do get out of my way. |
