Old 06-21-2011, 02:44 PM   #61
tomotosoup
looney4bikes
tomotosoup's Avatar
Oddometer: 47
Some dudes opinion.
Originally Posted by karna View Post
1. Fueling under 3k ? is it better or worse then SuperDuke?
2. Can you smooth the power delivery on the stock exhaust ? with PCV? or Autotune?
3. Would it be possible to use the Motoholigan box on a stock exhaust ?
4. Whats the Fuel range stock exhaust vs Akras?
5. Any Known issues ? or deal Breakers
6. Any high Mile guys out there ? is that a problem on SMR ?
1. The SMR has no fueling issues that I'm aware of.
2. Your saying the power delivery is not smooth on a stock SMR? That is subjective, but I respect your opinion. Those two devices would only be used if you needed to load a custom map, the only reason you might need a custom map is if you modify the bike (i.e. Air Intake, Exhaust; back pressure), you adjust fuel delivery for those mods accordingly, which would require Dyno time along with a knowledgeable tuner to create the map and load it. The stock bike will allow an alternate map to be loaded "the Akra Map" which basically increases fuel supply across the range. Any KTM dealer can load this map on your bike. This map was created for the most common mod... Akra pipes.
3. Best check with Aaron (the maker of the box), thats a huge adjustment in your fuel/air delivery with no compensation in exhaust flow. His contact info is in my How-To site (on page 1 of this thread) if you don't already have it.
4. I don't believe your fuel range is gonna change with any exhaust, stock or after market, until you change your mapping. Ball Park is gonna be 150 to a tank, give-or-take.
5. Other than the bike being over-priced, nothing I can think of. (again subjective)
6. I've put in 7 hr days on mine, no biggie. The SMT seat bolts right on for 200 beans, much more comfy so I've heard.
Disclaimer: I'm no expert, this is just my 2 cents based on my experiences thus far with the bike.
Cheers
tomotosoup is offline   Reply With Quote
Old 06-21-2011, 04:46 PM   #62
theturtleshead
Tits on a fish
theturtleshead's Avatar
Oddometer: 799
Yup
What he said!
Cali to Medellin 6hour 30 minutes suspension on the comfort settings!
No ass ache at all
Al
theturtleshead is offline   Reply With Quote
Old 06-21-2011, 06:22 PM   #63
mrjemm
Clumsy Oaf
mrjemm's Avatar
Oddometer: 350
Please excuse my lack of "R"ness. I suspect non "R"s weren't exported to the US, as I only see mention of these and "T"s...
Anyway, mine's alot closer to your lot than one of those ugly barges, so I'm going to gatecrash this party.
I would like to ask though, about this Akra map- is it likely to be necessary with Wings? They say no re-mapping is required, but, well, you know.
Curious about an apparent contradiction in your response there, Soupy. You say the map increases fuel supply, but then say it doesn't affect range. Due to less throttle being necessary? Or so small as to not make any difference?
Also, as I can recall, the R seat looks like mine (v flat to rear), and I am finding this one one of the more comfy KTM seats so far- having had 2x 950As (03 original plank and 04 slightly flattened) that were EVIL, a 950SMR that I never spent enough time in, and a 640E standard perch that ends up killer (also have comfort one, that's best of lot, but not on at mo).
Other things about the non "R", that may be the same, are that so far I find it a bit flighty/twitchy at the front, maybe a damper would help. I have crap traction at rear (perhaps susp set up and/or new tyres)- some scary moments. And the engine isn't "grunty" like the carbies were; need to run up through the range quick, which means changing gears gets in the way.
Compared to my old 950 SMR, it's nowhere near as intuative or playful. Feels much bigger. And it's not the power that unnerves me. Trading that for a Tuono is still my biggest biking mistake.
So far, still riding much slicker and nippier on the 640E!
mrjemm is offline   Reply With Quote
Old 06-21-2011, 06:39 PM   #64
mrjemm
Clumsy Oaf
mrjemm's Avatar
Oddometer: 350
Originally Posted by theturtleshead View Post
Treat it with respect and you,ll be fine,Go at it like an English lover and surprise surprise you,ll get a jerky reaction!
Al
You been talking to my lady?
Old 06-21-2011, 07:44 PM   #65
tomotosoup
looney4bikes
tomotosoup's Avatar
Oddometer: 47
Allow me to clarify
Howdy Mate, welcome to the party.
Regarding Wings exhaust, the owner of that company told me that if I used the smallest set of DB Killers (quietest) I would NOT have to re-map. If I used the louder (larger DB Killers) I should load the Akra map. When you buy a set of Wings they come with 2 sets of DB Killers. Nuf said.
If you re-read, you will see I said changing the exhaust will not effect the range of a tank of gas. (Which was the question) The exhaust has no effect on the amount of fuel delivered. Changing the map will. The Akra map does compensate for a free flowing exhaust by adding fuel across the board, and yes, that will effect mileage. How much I'm not sure. My guess is its not a lot.
Old 06-21-2011, 11:22 PM   #66
karna
karna's Avatar
Oddometer: 43
re:Advice
Thanks for the input.... Its really insightful... I can't wait to get my damn bike this week. 150 per tank... is that Miles ? if so thats impressive... my Hyper barely got 90 miles per tank
Cheers
karna is offline   Reply With Quote
Old 06-22-2011, 12:44 AM   #67
tomotosoup
looney4bikes
tomotosoup's Avatar
Oddometer: 47
Fuel
Yes thats miles. Don't get too excited, 150 would be every drop of a completely full tank, just casual commuting. I might have been a little generous with that # in hindsight. 130 might be more realistic. It's odd because of the way the bike handles reserve. The odo starts counting up from zero, one day I got to the pump with 32 miles on reserve. I thought great thats my magic number. Then a few months later I ran out of gas on the way to work at 24! Reserve seems to come on around the 105 to 110 area, and after my incident I don't trust it much more than 15 miles, so I'm in the habit of getting 125 to 130 between fuel stops. FYI my bike is on the stock fuel map.
Old 06-23-2011, 11:16 AM   #68
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,244
My 990 SM-R gets 110 miles per tank.
That's with Akra cans and Akra map,
constant acceleration, deceleration and gear changes,
on twisty roads only (because that's all we've got), and
rarely ever in 5th or 6th gear, AND rolling into the gas station on nothing but fumes
(if that helps any).
I've never ridden it on a straight highway in top gear for any distance,
so I can't help with that type of mileage.
According to www.motorcyclespecs.co.za :
Fuel tank sizes:
990 Supermoto R.................. 15L
990 Supermoto T................... 19L
990 Supermoto (Europe)...... 19L
KTM MIKE . . . . . . . KTM EQUIPPED SINCE 1999
three 640's (sold), two 950's (sold),
530 EXC Supermoto, 690 SMC, 990 SM-R
ktmMike screwed with this post 06-23-2011 at 12:38 PM
ktmMike is offline   Reply With Quote
Old 06-23-2011, 11:32 AM   #69
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,244
Mr Jemm,
I was hoping a non-R 990 Supermoto rider would find us.
Will you please give me the part numbers of the left and right
"spoilers" mounted on the sides of gas tank including different color choices if any exist?
Are they painted, or are they raw polypropylene finish with decals added,
like many KTM side covers, fenders, and the like?
ktmMike screwed with this post 06-23-2011 at 01:27 PM
Old 06-23-2011, 11:55 AM   #70
theturtleshead
Tits on a fish
Oddometer: 799
That being said, my R gastank holds about 3.9 gallons as I understand it.
I think the T has a larger tank, and I have no idea what size gastank is on a
European model 990 Supermoto (non R / non T).
That,s funny! Never even knew about 6th gear,just goes to show how many highways there are around theses parts.
Al
Old 06-23-2011, 12:40 PM   #71
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,244
Laugh OK Turtle
Al
So tell the man how many miles (or kilometers)
you get per tank
Old 06-23-2011, 01:03 PM   #72
theturtleshead
Tits on a fish
Oddometer: 799
Mmm ooh-er
you get per tank
Ha!
Tricky one that.Well I filled up in Cali,then again just outside Pereira,then one more just one the outskirts of Medellin.Left Cali at 7am on the dot got into Medellin at 1,30pm.
So two tank fulls in 6.30mins
I,m guessing it,s not much help
Al
Everything is klm,s here but my head and speedo still work with miles
Old 06-23-2011, 01:56 PM   #73
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,244
I felt that with some tires, but not others.
No such feeling with plain Pilot Power front.
I like plain Pilot Powers, 31 psi front and rear, and all standard suspension settings for my body weight of 160 lbs.
Good rear traction for me with this set up.
(I experimented with suspension settings quite a bit.
You can feel a change with EACH CLICK. Very sensitive.
Every combination led me back to standard).
(Now if I were going to ride it where all the roads are straight, like Colombia,
I would probably choose the comfort settings).
ktmMike screwed with this post 06-23-2011 at 02:06 PM
Old 06-23-2011, 04:38 PM   #74
theturtleshead
Tits on a fish
Oddometer: 799
Slim Jim
Ah that might be all fine and well for you slim types Mike,but us 195lbs types do need our comfort
Al
Old 06-24-2011, 05:30 AM   #75
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,244
Pissed Cage nut
Tomoto,
With all the rain, I finally had a little time to go through your
http://www.ladowntownnews.com/SMR/index.htm
in greater detail.
What a professional effort! Excellent job!
I see you went through the same cage nut fiasco that I did.
I wonder if the factory tank installer ever figured out how much trouble
he has caused by using a power tool where a hand tool should
have been used gently (I guess that's how he did it).
ktmMike screwed with this post 06-26-2011 at 06:51 AM
Times are GMT -7.   It's 10:39 AM.
