Old 06-17-2011, 07:59 PM   #676
milracing
Bike porn addict
milracing's Avatar
Oddometer: 54
Originally Posted by blue&yellow View Post
lots of good advice
some more on how to get a feel for a bike more quickly:
1. Get a feel for the engine and gears: with a warm engine don't use full throttle but s-l-o-w-l-y rev it out in first gear, then in second. Then shift up and down and feel how the engine behaves and responds at different rpm and different gears. Try different gears while keeping a steady speed and so on. A common new rider mistake is to always shift to the highest gear possible since that's what you do in a car, with a motorcycle you will find that it often rides better in a lower gear and with less throttle. The engine will be more responsive and run smoother, don't worry about fuel consumption since bike engines are tuned for higher rpm than cars and sometimes higher rpm will actually improve the gas mileage!
2. Get a feel for the chassis: this is a little exercise that i call "the snake". If you find yourself on a wide straight road with little traffic you want to wiggle the bike from side to side. Keep your vision fixed straight ahead (this is very important!) then start with start with slooowly going from one side of the lane to the other side and back, then do it a little faster, a little faster again, and then a little faster again. Don't ever stop and straighten the bike out just keep on turning back and forth, back and forth.
You will find that to do it slowly you need not even turn the handlebars but merely think about it and you will move. But then the faster you wiggle from side to side the more force you will have to apply at the handlebars, and you are now counter-steering! If you do it really fast (only on good clean asphalt with warm tires) you will find that you are not moving your upper body at all but that your legs and the bike will swing beneath you. This technique of aggressive counter-steering is the fastest way to lean a bike over for a corner or to avoid an obstacle. It is profoundly useful!
3. Get a feel for the brakes: while on an empty road and traveling at the speed limit try getting a feel for the front break. You should squeeze with your knees and straighten your arms and back while at the same time squeeeeeezing the front brake. I recommend also pulling the clutch at the same time if you feel you can manage it. It should take maybe 0.5 second to go from no front brake to maximum front brake, this will allow time for the weight to transfer to the front wheel.
Start easy and then brake harder and harder, be prepared to release the brake if you feel that the front wheel locks up or the rear of the bike is coming up. During this exercise you don't need to use the rear brake at all, the rear brake is the good for small speed adjustments, works well at low speeds and on gravel and can also help stabilizing the bike in a corner. But the harder you need to brake the more front brake you need to dial in and the less rear brake you should use. Pro racers use the rear and front brake under maximum braking but for 99% of road riders it's safer to only rely on the front brake for emergency stops. This does however change a bit if you have a low slung cruiser, then you might have to use both brakes.... So essentially you need to practice braking with your motorcycle.
These three things will help you to more quickly grasp how a motorcycle goes, turns and stops....
great post!!
milracing is offline   Reply With Quote
Old 06-17-2011, 09:42 PM   #677
024
Oddometer: 63
I just keep coming back to this thread. It encouraged me to try a few things out I never would have thought of as practice and helps me think about what I'm doing while riding. A great thread on a great forum.
Mike
2008 DR650 "Daily Rider"
1980 CX500C "Ratbike"
024 is offline   Reply With Quote
Old 06-18-2011, 09:18 AM   #678
milracing
Bike porn addict
milracing's Avatar
Oddometer: 54
Originally Posted by ace View Post
I got one (pounded in to me by an MSF instructor):
Never do the" two finger front brake" thing (its a "bad" habit), use the whole hand every time. it creates a muscle memory habit and even as you grab with only two; things may require full emergency braking with no notice. its best to grab with all four fingers and use necessary pressure. In a dire emergency you want to reflexively react reaching with all four.
IDK. I always use two. I have two fingers on the brake and clutch levers at all times. For me it's uncomfortable to not always have my fingers there. I don't need muscle memory for reaching, I'm already there.
Old 06-18-2011, 09:35 AM   #679
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
I use one finger on some bikes and two on others. (never four)
The key is to practice and get good at it no matter how many fingers you use.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 06-18-2011, 09:52 AM   #680
opaque_machete
girls wanna have fun
opaque_machete's Avatar
Oddometer: 630
+1
Marjorie
'93 XT225
'05 Ninjette
May the forces of evil become confused on the way to your house. -George Carlin
Two Wheel Females.com
opaque_machete is offline   Reply With Quote
Old 06-21-2011, 05:42 AM   #681
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,264
That's what she said
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Old 06-22-2011, 06:35 PM   #682
Mellow802
RIDE VT
Mellow802's Avatar
Oddometer: 41
Great thread. Lots of solid advice. I always rode dirtbikes and I'm comfortable on the trail but road riding sketches me out sometimes people are just way too unpredictable.
Mellow802 is offline   Reply With Quote
Old 06-22-2011, 08:49 PM   #683
daq7
daq7's Avatar
Oddometer: 571
Another important noob thing to know is that a lot of the stuff people tell you is not true.
daq7 is offline   Reply With Quote
Old 06-22-2011, 10:00 PM   #684
opaque_machete
Oddometer: 630
Marjorie
'93 XT225
'05 Ninjette
Old 06-23-2011, 01:57 AM   #685
dbuzz
Citizen of the world
Oddometer: 1,267
Riding a bike is like having a stable of thoroughbreds ... get in the habit of 'stabling' your bike .... a quick clean, a check over and a chain lube (if ya have a chain and not shaft or belt drive) ... It's akin to rubbing the horse down and grooming / feeding at the end of the day ... then all that needs to be done is a tyre check in the morning before you head out for your ride
dbuzz is offline   Reply With Quote
Old 06-23-2011, 03:28 AM   #686
duck
duck's Avatar
Oddometer: 10,403
Liar!
duck is offline   Reply With Quote
Old 06-23-2011, 07:57 AM   #687
zrxmoto
don't wanna be a n00b
zrxmoto's Avatar
Oddometer: 125
It just takes time to get used to it. I love riding around the city and exploring neighborhoods.
It can often seem like people are unpredictable. I would say however that it is very predictable that some people will do something unpredictable. Expect the unexpected. Learn to find those people while you're riding and keep them in your personal radar.
When I'm riding down the street my #1 thing is that I'm enjoying the ride. Riding a motorcycle is fun first and foremost. But I always have my little personal radar going: The guy is front of me is talking on the cell phone, the teenager is looking at her latest text message, the person behind me seems to be in a rush and is tail gating.
Try hard to not let yourself be surprised. Recognize the warning signs and make an intervention. Make sure that things you do to ride the bike: starting, braking, accelerating, etc. are completely automatic. That way you have your full attention to devote to what's going on around you and enjoying that ride down the boulevard.
I'm not one to post and complain about crazy cagers and stupid drivers. As soon as I start doing that I'll back out of the driveway one morning into the path of my neighbor on his Goldwing. I've certainly pulled a bone-headed move or two.
2002 VFR 800
1999 Vulcan Nomad
2007 XR650L
2010 KLX250S
zrxmoto is offline   Reply With Quote
Old 06-28-2011, 09:38 AM   #688
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
Originally Posted by 60pan View Post
This drill trains you for the very common MC sandwich where traffic has stopped & you must make a emergency stop & keeping your feet up make your escape so the next car wont rear end you.
Everyday IS 3/11!
Everybody's always talking out the side of their mouths about our "dependency on foreign oil", what about our dependency on cheap china crap? Who exactly again is killing our dollar?
IheartmyNx is offline   Reply With Quote
Old 06-28-2011, 12:03 PM   #689
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
I don't know where I picked it up, but I don't have to be trained on what's behind me.
I guess it was all those years of working on a road and having rule #1 drilled into me. NEVER, Never ever ever turn your back to traffic...
But then I moved here and it's like all the rules one should know, are thrown right out the window with the "I'll just hire a lawyer" mentality.
I've never seen or thought ppl could do and get away with the things they do here till I saw it with my own two eyes... Man, the stories I could tell.
Bottom line, keep your head moving "Head on a gimbal" and never ever ever assume someone will be looking out for you.
After all, to them that's what lawyers are for.
EDIT: And oh, if I was Mr. Limp Dick Ford Ranger man, I'da assumed a protective position with my truck as a buffer, before the biker...
Thata way, if an errant car was to come it'd hit my truck instead. Fkn people
Everyday IS 3/11!
IheartmyNx screwed with this post 06-28-2011 at 12:15 PM
Old 06-28-2011, 12:22 PM   #690
Lesswheelsmorefun
Oddometer: 35
bikes don't stop quickly in the rain
Lesswheelsmorefun is offline   Reply With Quote
Times are GMT -7.   It's 05:41 AM.
