06-26-2011, 08:45 PM
#106 |
Wannabe Far-Rider
Very glad you don't have any lasting damage to the body! No such thing as a 'low' speed crash, unless its in first gear on dirt, they all hurt a little.
Hope you get the bike figured and taken care of...
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
06-27-2011, 10:59 AM
#107 |
Slacker
Oddometer: 29,453
Okay, all the name calling and general dickery will be dealt with in a manner you don't want to see. Knock it off.
The finishers medal is satisfyingly heavy... Neduro on Dakar The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them. -Furious D |
06-27-2011, 05:00 PM
#108 | |
Oddometer: 68
06-27-2011, 07:15 PM
#109 |
Oddometer: 781
Re BMW / Showa
BMW like other manufacturers run zero defect contracts with suppliers, this was well covered over at the Hubb forum some time ago. If the problems were as a result of Showa design / manufacturing then you could rest assured there would be a recall as it would be to Showa's cost not BMW. As for forks being "off the shelf" fork lowers in particular are machine specific & not a standard item. Axle & caliper mountings are a good part of the reasons for this. The general conclusion is that the forks are a BMW design manufactured by Showa to order. Re parts A check and cross reference reveals there are now 3 part No's for each of the complete fork legs. A new Part No will appear for the black 2011 fork lowers at some point. All fork legs & lowers are interchangeable over the entire production period of F & G Models 1999 to 2010. The fact they are interchangeable indicates the mountings etc are all common & the Part No change is for some other reason, possible a casting change. The axles, LHS & RHS wheel spacers, Yokes & Fork Brace are also common to the entire F & G Series & the original parts are shown as superseded in the fiche Details are below F650GS & Dakar 2000 - 03 Model R13 08 36312345823 SPACER BUSH (LHS) 09 36317650586 FLOATING AXLE, FRONT (superseded by 36317705569) 11 36317661196 SPACER BUSHING, EXTERIOR - ZNS (superseded by 36317705571) 01 31422345799 FORK BRACE, BLACK, LOWER (Yoke) (superseded by 31427726772) 02 31422345800 FORK BRACE, SILVER, UPPER (Yoke) (superseded by 31427726765) 07 31427667279 STABILIZER BAR WITH THREADS (superseded by 31427729244) 01 31427678481 LEFT FORK SLIDER 01 31427678482 RIGHT FORK SLIDER 01 31427676377 FORK LEG LEFT - SILVER (superseded by 31428520347) 01 31427676381 FORK LEG LEFT - SILVER 01 31427676378 FORK LEG RIGHT - SILVER (superceded by 31428520348) 01 31427676382 FORK LEG RIGHT - SILVER F650GS & Dakar 2003 - 07 Model R13 08 36312345823 SPACER BUSH (LHS) 09 36317650586 FLOATING AXLE, FRONT (superseded by 36317705569) 11 36317661196 SPACER BUSHING, EXTERIOR - ZNS (superseded by 36317705571) 01 31422345799 FORK BRACE, BLACK, LOWER (Yoke) (superseded by 31427726772) 02 31422345800 FORK BRACE, SILVER, UPPER (Yoke) (superseded by 31427726765) 07 31427667279 STABILIZER BAR WITH THREADS (superseded by 31427729244) 01 31427678481 LEFT FORK SLIDER 01 31427678482 RIGHT FORK SLIDER 01 31427676377 FORK LEG LEFT - SILVER (superseded by 31428520347) 01 31427676381 FORK LEG LEFT - SILVER 01 31427676378 FORK LEG RIGHT - SILVER (superceded by 31428520348) 01 31427676382 FORK LEG RIGHT - SILVER G650GS 2008-09 Model R131 08 36312345823 SPACER BUSH (LHS) 09 36317705569 FLOATING AXLE, FRONT 11 36317661196 SPACER BUSHING, EXTERIOR - ZNS (superseded by 36317705571) 11 36317705571 SPACER BUSHING, EXTERIOR - ZNS3 01 31422345799 FORK BRACE, BLACK, LOWER (Yoke) (superseded by 31427726772) 02 31422345800 FORK BRACE, SILVER, UPPER (Yoke) (superseded by 31427726765) 07 31427667279 STABILIZER BAR WITH THREADS (superseded by 31427729244) 01 31427678481 LEFT FORK SLIDER 01 31427678482 RIGHT FORK SLIDER 01 31427676377 FORK LEG LEFT - SILVER (superseded by 31428520347) 01 31427676381 FORK LEG LEFT - SILVER 01 31427676378 FORK LEG RIGHT - SILVER (superceded by 31428520348) 01 31427676382 FORK LEG RIGHT - SILVER Model R131 2010+ MaxBMW has no PN for Forks or fork brace only listing consumables, axle, yokes & spacers 08 36312345823 SPACER BUSH (LHS) 07 36317705569 FLOATING AXLE, FRONT 08 36317705571 SPACER BUSHING, EXTERIOR - ZNS3 01 31427726772 FORK BRACE, BLACK, LOWER 02 31427726765 FORK BRACE, SILVER, UPPER WayneC1 screwed with this post 07-03-2011 at 12:19 AM Reason: Correct Part No's |
06-28-2011, 12:47 AM
#110 | |
Oddometer: 92
I am pleased though to see Chitowns response as this shows that not all the G's have dodgy forks. Mine has 500km on and I will be checking my forks for any issues however it is reassuring to see that thier one hasnt broken after 2500 moderate offroad miles. I have read the whole thread and will have to reread it however was the fork failure the actual definate cause of the crash or was it an affect of the crash? As one poster notes the axle looks bent (or is it just the angle of the pic), I expect this happened as a result of the crash as I cant see it would have been able to be ridden like that. Bike with only 95 miles on in my opinion would have new tyres that still need to have great care taken especally with a new rider. The earlier fork issues were from memory pre 2003. Since then the F650 single has travelled many thousands of miles in the remaining 7 years of production and I am not aware that the issue reappered on the twin spark models. I also will be interested to see what the dealer and BMW and the traffic authority report back on this, which I assume they are aware and have had an opportunity to investigate ? |
06-28-2011, 01:47 AM
#111 |
Oddometer: 92
Check your forks manufacturing date..
I have looked and my G650GS has a date stamp on the inside of right fork leg, mine was produced in late 2010. So the G does not have old pre 2003 forks on it they are newly manufactured. This isnt to say there might not be an issue but they are not old forks put on the new model. |
06-28-2011, 08:40 AM
#112 |
Oddometer: 3,360
"I am pleased though to see Chitowns response as this shows that not all the G's have dodgy forks. Mine has 500km on and I will be checking my forks for any issues however it is reassuring to see that thier one hasnt broken after 2500 moderate offroad miles.
I have read the whole thread and will have to reread it however was the fork failure the actual definate cause of the crash or was it an affect of the crash? As one poster notes the axle looks bent (or is it just the angle of the pic), I expect this happened as a result of the crash as I cant see it would have been able to be ridden like that." Chitown didn't seem to grasp the concept that (A) non-defective forks never break like that, even when slammed down from a great height or at speed into something solid (B) the OP wasn't going fast and didn't hit anything. You can "check" your forks all day long, and maybe it will help you maintain a mental security blanket to assuage your nagging fear that you may have spent a pile of money on an inferior product that could get you killed. The hard truth is that unless you take them apart and conduct electronic or radiographic NDT, you have no idea if you are the poor Joe who happened to get the bad part. The outrage here is the forks are so very minimally adequate, that the slightest flaw in the casting or machining can result in CATASTROPHIC failure! You might not know any better, but I guaran-damn-tee you that the engineers and management at BMW do... and THAT'S unexcusable! |
06-28-2011, 09:40 AM
#113 |
Oddometer: 68
NHTSA ODI number is : 10409875
It should be available for viewing within 3 business days. |
06-28-2011, 10:12 AM
#114 |
Oddometer: 68
Here is a wider photo of the front wheel, I forgot who requested it.
Obviously there was NO MAJOR IMPACT where I hit anything. ![]()
antiquewidow screwed with this post 06-28-2011 at 12:47 PM |
06-28-2011, 04:07 PM
#115 |
Oddometer: 68
You might not know any better, but I guaran-damn-tee you that the engineers and management at BMW do... and THAT'S unexcusable![/QUOTE] I fully agree that it is UNEXCUSABLE, I bought a BMW due to the fact that they were durable; and it was an enduro meant for country roads etc. Was I ever so wrong. Whether this be a one time incident or the twelve doesnt matter. What does matter is that this happened in the first place. And not only to me but many previous. There is no excuse that a $9400 vehicle with 95 miles meant to be ridden off n on the road should have this type of fork issue at all. Those who pad their pocket at the cost of others lives should be ASHAMED of themselves. To all the G650Gs owners out there, I wrote this board in good faith to for worn you that this has happened to me and to be careful and please check your forks during pre inspection... I did not want to see it happening again. I unlike others was thinking of someone other than myself. I also wanted to write about my first accident (the first down ) - as so many of you have. I am totally disgusted with the pointing of the fingers, the in your window accusations etc that have been directed at me thru this post. Although it was a low speed incident - it was one that has caused tremendous emotional & physical damage to me. No I didnt break any bones but that doesnt make it any easier or any less hurtful. I too loved my BMW G650GS and was very proud to of owned one BUT after this incident and what I have learned -- I will NEVER EVER own another BMW bike again...Especially knowing all that I know now. |
06-28-2011, 07:17 PM
#116 | ||
Oddometer: 2,027
It is also undoubtedly a mistake. Because I can assure you as an engineer, that no one at BMW or anywhere else, knowingly designs a vehicle component which will fail in such a way. Quote:
It has been said that an engineer is someone who can make for one dollar what any fool can make for two dollars. Very very occasionally we stuff up; we introduce some unforeseen failure mode. This is what vehicle recalls are for. No one wants recalls, but we want a world that doesn't do recalls when necessary even less. There's been lots of speculation here about the cause of your failure and quite a bit of blame flinging, but now its got a NHSTA number, you can be assured that if there is an underlying systematic fault, it will eventually result in a recall and replacement of suspect parts. Rather than swearing off of BMWs generally because of your experience, perhaps you should look at the recall rates of the available vehicle manufacturers and swear off of those who have the highest rates? Or perhaps consider how many BMW forks have broken unexpectedly in the manner that yours has versus how many have been mashed or otherwise run down by errant car drivers, and recognise that your own riding and the drivers around you are far greater sources of danger than this very rare catastrophic failure. I can understand a reluctance to ride on the same design of fork before we've reached an understanding of why yours failed, but not an outright rejection of all products from one of the world's better vehicle manufacturers. |
06-28-2011, 08:33 PM
#117 | |
Mr. Tourguide
Oddometer: 2,548
I went down from a 1200 bike to this little 650 and I'm very happy with it.
My motorcycle projects blog My Goodreads Profile This is what I do when I'm not here! |
06-28-2011, 10:34 PM
#118 |
Clear Clowdy Trails
Oddometer: 3,100
I'm a little late in this thread but.... That is not a faceplant, that's a nightmare!
06-29-2011, 12:06 AM
#119 | |
Oddometer: 92
As I own one of these I need to know for my peace of mind please.. I cant see any bike road damage to the right hand side of the bike in the newer pictures shown, I assume the bike toppled to the left? even though the right fork leg broke? |
06-29-2011, 12:24 AM
#120 |
Oddometer: 92
[QUOTE=lemieuxmc;16271901]"I am pleased though to see Chitowns response as this shows that not all the G's have dodgy forks. Mine has 500km on and I will be checking my forks for any issues however it is reassuring to see that thier one hasnt broken after 2500 moderate offroad miles.
Sorry but I stand by this comment, as you point out I have invested my money in this bike and I am looking for reassurance that not all the forks have this fault. Chitowns response clearly proves they are not all faulty. And yep I agree one is unacceptable but it doesnt need to have every G owner that has bought one so far left in a field of FUD. Chitown didn't seem to grasp the concept that (A) non-defective forks never break like that, even when slammed down from a great height or at speed into something solid (B) the OP wasn't going fast and didn't hit anything. The axle on this wheel is bent, you bend your axle on your Suzuki/Harley whatever to that angle and something will give at the weakest point. My concern here would be first, is how did the axle bend. Some have said becuase it had the weight on it..that would hold true if the other side was bent as the left side as far as we can see is still atttached, thus has the full weight of the bike. I am not an engineer so no doubt will be shot down.. but surely the end with the solid held point not the floating point would be the side that bends as the weight pushes the bike to the right which has no support? I would be asking the dealer how was this bike in pre delivery check? was the axle bent (was it even tested?) then if it was this would have put extreme pressure on the fork. Was the bike carted using tie downs anywhere in transit and were they over tightened or poorly placed which may have caused extreme pressure ..enough to bend the axle? Does the owner have picutres of the bike pre accident?, particulaly the right front wheel. |
