Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-10-2011, 03:41 PM   #7096
gkgeiger
Every ride is an ADV
gkgeiger's Avatar
Oddometer: 643
Originally Posted by Porky View Post
Has anyone else, besides me, had a problem their throttle. I notice that my throttle is what I would call twichy or abrupt--like there is very little "space" between giving the bike more gas and letting off the throttle. It is difficult to keep a steady speed as it seems like I am either "off" or "on" the throttle. Even bumps in the road cause the "touchy" throttle to give the engine more (or less) gas.
I told the dealer about the problem at the 500 mile service and they (of course) said everything was "normal".
It's normal.
Getting old is not for Sissy's!
Gene
'14 R1200GSW
'12 NC700X/D
gkgeiger is offline   Reply With Quote
Old 07-10-2011, 03:50 PM   #7097
bross
Where we riding to?
bross's Avatar
Oddometer: 4,591
Have you tried adjusting the freeplay in your throttle? I prefer very little to no freeplay, if I have the recommended freeplay, my throttle seems touchy as well. I adjust out the free play and just make sure I can turn the bars lock to lock without affecting the throttle. This seems to give me much better throttle control and reduces or almost totally eliminates the on/off feeling to the throttle. Also makes blipping for downshifts more accurate and easier.
Seems counterintuitive but works for me.
Old 07-10-2011, 04:07 PM   #7098
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,647
It is normal to a certain extent but there are a couple things you can do to make it better:
First, adjust out all the throttle freeplay you can get away with. When finished your adjustment, you will need to start the engine and turn the bars from lock to lock. If your engine revs when the bars hit one side or the other, put some freeplay back. So basically what I'm saying is take out as much freeplay as you can but not so much that the steering affects your rpm.
Second, make sure your bike has the latest tune. When I got my bike I thought it had twitchy throttle and I found it was running the first tune (20479 I think). That tune was obsolete by that time and I used TuneECU to load the latest tune (20495 I think) to the bike which helped a LOT. Double-check the tune numbers on your own as they are different for 800 vs. 800XC as well as ABS vs. non-ABS.
If you still have twitchy throttle, get yourself a copy of TuneECU, a cable, and read read read about mapping. You can use TuneECU to disable the oxygen sensor which may help somewhat and you can also use it to edit the fuel maps which is potentially dangerous unless you know what you're doing.
Or you can wait for the development of BoosterPlug for the T800 (if it ever happens). I had one on my Tiger 1050 and it made a HUGE difference in the driveability of the bike.
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 07-10-2011, 04:38 PM   #7099
dogmoon
dogmoon's Avatar
Oddometer: 313
Engine Light
Originally Posted by The Jerk View Post
As you found, removing the battery cable doesn't do anything to clear fault codes (and that's a good thing; otherwise troubleshooting would be very difficult).
Here's a little primer on the check engine light:
The check engine light (CEL) will come on whenever the ECU has detected some sort of fault in the engine management system. This generally happens because one of the components of the engine management system provides feedback to the ECU that was out of the expected range or perhaps has lost communication with the ECU entirely. The ECU will make a note of the issue by storing a fault code. The fault code contains information about what sensor it was and what the problem was. At the same, time, the ECU turns on the CEL so that you know a fault code has been stored. There is nothing wrong with operating the engine with the CEL lit up, it's just there to let you know that there was a problem and you should get it checked out.
The engine management system can still work fine with a sensor down; just perhaps not as efficiently as normal depending on what sensor is out of commission. In other words, you're not going to hurt anything by continuing to ride it as long as the engine is not noticeably running poorly (i.e. misfiring).
If the problem that triggered the CEL happens to go away on its own after a certain number of cycles, then the ECU will turn the CEL off. But the fault code will still be stored so next time the bike is hooked up to the diagnostic system they can see what the issue was.
You can also check fault codes yourself if you have a program like DealerTool or TuneECU (freeware). This will give you an idea of where the trouble may lie, though you should understand that a fault code about a particular component does not necessarily mean the component itself is bad. It's just a lead on where to start troubleshooting.
Thank you for the infromation that makes me feel at ease somewhat. I am going to call the Dealer Tuesday. The bike ran fine today I put three hundred miles on it, again thanks for the infro. It is now ready for the 500 mile service. What a machine.
Sometimes it takes a whole tank of fuel before you can think straight!
dogmoon is offline   Reply With Quote
Old 07-10-2011, 05:36 PM   #7100
ElNorto
Oddometer: 39
I plan to get one of the G2 throttle tamers to take care of this. Not a big deal on the street but its way too abrupt off road with the amount of power the Tiger has.
http://www.g2ergo.com/g2-tamer-throttle-tube-121.html
ElNorto is offline   Reply With Quote
Old 07-10-2011, 07:50 PM   #7101
akula802
Oil Whisperer
akula802's Avatar
Oddometer: 117
Last week, I moved to Red Lodge, MT for work, and I brought the Tiger with me on a hitch-mount carrier. I'd have ridden it from Minnesota if I didn't need the truck and all the stuff that's in it.
So far she's taken me over Beartooth pass twice, no problem. The XC is a pleasure on the twisties and a riot in the hairpins. More than adequate power to fly around above 10,000' elevation. Today she found her first Montana gravel, a couple of forest service roads as I was out looking for rock outcrops and trout fishing spots. The XC performed beautifully in the softer stuff, and the suspension soaked up all the deep, wide ruts and large rocks I encountered. I only stood up off the seat a handful of times (I'm a slowpoke though).
As a few have mentioned, the kickstand shakes about and rattles over bumps. Slightly annoying but easily fixed I suppose. Other than that, no complaints whatsoever. Great bike. I've already found a few steep, rocky places where I'd fear to tread with it, but my WR will be here soon
"The journey is the destination." --Dan Eldon
Betting the world on a pair of fives
akula802 is offline   Reply With Quote
Old 07-10-2011, 07:51 PM   #7102
TerraUnFirma
Fair/Not Balanced
TerraUnFirma's Avatar
Oddometer: 352
I had the dealer load the latest FI map when I had the bike in for the 500 mile service and that helped a little. Also adjusting out most of the freeplay helped, too. What really got it to where I'm ok with it, especially off-road, was putting a rubber O-ring between the end of the throttle grip and the metal bar-end that the handgaurds mount to. Adds enough friction to take all the abrupt out of the system...you have to consciously move the throttle. Works for me, may or may not for you. I'm used to the feel of it because I've done it to my BMW RT, which I did as more of a cruise control than to solve throttle problems. Don't really need to on the DRZ, it's pretty smooth as is. YMMV.
Cheers!
Tom Stites - Dawsonville, GA -
'11 Triumph Tiger 800XC ABS
'97 BMW R1100RT
'06 Suzuki DRz400s
'08 Yamaha WR250R
TerraUnFirma is offline   Reply With Quote
Old 07-10-2011, 10:35 PM   #7103
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,036
800XC off-pavement
Took the tiger out for a spin on some gravel roads. It seems to do fine, considering its weight. It showed to be relatively well composed. And it sounds great at it. But definitely not the most appropriate tool for the job. To the Tiger's defense: no knobby tires, and tires were fully inflated. On the other hand, on ball bearing gravel roads there isn't much that will hold traction anyway.
On corrugations such as in minutes 0:39 and 2:05 and 2:35 and 3:06 you can hear how it makes a lot of noise, coming from the front and the back of the bike. Not much traction on acceleration either (most bikes won't have any traction at all either). I need to check the adjustments for the rear shock.
I was not pushing it, and I don't think I will take it on too many dirt adventures. I know now it can do it, so there it is. But it feels great on pavement and that's where it will spend most of its life.
Lion
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 07-11-2011, 03:06 AM   #7104
KildareMan
KildareMan's Avatar
Oddometer: 681
Tunes are the same for 800 & XC, in the majority of cases.
Current tunes (as of July 11 anyway) are:
800 NON ABS
Standard exhaust - 20477
Arrow exhaust - 20478
800 ABS
Standard exhaust - 20495
Arrow exhaust - 20493
XC NON ABS
XC ABS
Standard exhaust - 20496
Arrow exhaust - 20494
Taken from TuneECU listing
KildareMan is offline   Reply With Quote
Old 07-11-2011, 03:21 AM   #7105
woodys3b
Oddometer: 150
Please report back when you have this installed. For me, this is one of two flies in the ointment on my Tiger and the more I ride it the more annoying it becomes. The roads I ride have lots of frost heaves and the bike is constantly surging forward and back as I hit them. I'll have it remapped when I can find the time.
woodys3b is offline   Reply With Quote
Old 07-11-2011, 03:28 AM   #7106
woodys3b
Oddometer: 150
The other Fly
I know this has been mentioned before but, what was Triumph thinking with the gear ratios. If this transmission was in a sport bike it would be one of the best in the business. However, it just doesn't suit the Tiger. First is too high and 6th is too low and they are all too close to each other. I've been playing around on my commute and double shifting. 1-3-5-6 from a dead stop and 2-4-6 when making a right turn that doesn't require a full stop. The motor pulls so well down low that it is very easy to ride like this. I just can't double shift fast enough to do it smoothly. Hopefully, this will be something Triumph corrects sometime in the future.
Don't want to paint a negative picture here. My Tiger is far and away the best bike I have owned.
Old 07-11-2011, 03:40 AM   #7107
KildareMan
KildareMan's Avatar
Oddometer: 681
As Jerk has said setting up the throttle cables correctly makes a huge difference. I did a how to on Tiger800.co.uk
http://www.tiger800.co.uk/index.php/topic,1465.0.html
Throttle response will be as smooth as a baby's bum after adjustment.
Old 07-11-2011, 04:41 AM   #7108
ElNorto
Oddometer: 39
The bike was recently serviced and has the latest tune and slack taken out of the cables. It is smoother but needs more range of motion at slower speeds. In normal riding (not drag racing) I only use about an 1/8" of throttle motion to accelerate through the gears. It will be a few weeks before I try the G2 throttle. They don't have one listed specifically for the Tiger 800 but was told they could fix me up if the bars are 7/8".
Old 07-11-2011, 06:56 AM   #7109
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
Airing down and/or different tires makes a HUGE difference!!! Ball bearing gravel roads or not...
fbj913 is offline   Reply With Quote
Old 07-11-2011, 07:01 AM   #7110
Lion BR
Lion BR's Avatar
Oddometer: 4,036
Airing down tires on a bike this heavy can mean bent rims. And it is such a hassle. I'm mostly a dirt rider and I've ridden bikes with all sorts of tire wear, I know thread makes a difference. But not as much as people tend to believe. Thanks for your comments.
Lion BR screwed with this post 07-11-2011 at 07:38 AM
Times are GMT -7.   It's 10:24 PM.
