Old 07-14-2011, 03:55 AM   #23296
edteamslr
edteamslr's Avatar
Oddometer: 198
Originally Posted by Dracothius View Post
So I've got a few questions regarding the WR. Can it handle 50k, if so can it handle 100k(miles)? How is it's subframe? Can it handle being fully loaded? Can it handle a passenger on the road and on limestone roads? NO this is not my main use for the bike but I need it to be able to do it. I do plan on riding it quite a bit and carrying my wife on the bike every so often. It seems like a really nice bike but if it can't handle these requirements I would have to go bigger. Thanks, just looking for info on the bike and seeing if it could fill the role I need it to fill.
It's only a matter of time before someone will need to ask how big your wife is in order to answer the question. The subframe is steel and strong enough to withstand being loaded up with extra fuel and camping kit and shaken violently for weeks on rough roads (not sure what the highest mileages are on this forum for WR users but I suspect it is more than 50k miles by now). The weakness to your scenario is around whether the bike has enough power to propel the two of you in a way that doesn't drive you mad. Yes, it can take a pillion but the two of you end up sitting very closely together (with you on the narrow front, I assume) and makes the bike feel like it has half the horsepower. Which isn't very much when you've got only about 25 to begin with. The bike's suspension is also rather 'boing-gy' to begin with and while the rear spring is capable of carrying another person, I have no idea what maxing-out the rear shock will do to the handling. Don't expect miracles. So I would say - yes it can, ideally for very short periods of time but don't expect miracles or cross-continent, 2-up adventures on it.
[as a bike that mainly for you, you just may end up buying one and loving it. that's what happened to me]
edteamslr is offline   Reply With Quote
Old 07-14-2011, 03:58 AM   #23297
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,676
Originally Posted by trav72 View Post
Please document the install. I've been very interested in the Lynx setup but haven't seen anyone show install photos.
I have the first one in the US for the WR250 and did a write up of the install.
Here is the link...
http://wr250rforum.forumotion.com/t2...install-wr250x
Mr. Fisherman screwed with this post 07-14-2011 at 05:03 AM
Mr. Fisherman is offline   Reply With Quote
Old 07-14-2011, 06:06 AM   #23298
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,636
Originally Posted by Jäger View Post
Or, on this bike, just give the back of the tire a good solid thump. Don't take much.
This.
MoBill is offline   Reply With Quote
Old 07-14-2011, 06:58 AM   #23299
crash a-ron
mmm...burnt steel
Oddometer: 322
One..... Freaking... Rock. The Golden BB.
Wow! Any chance you'll show us some photos of your chain? It had to be really hot as it was cutting through that rock.
Is chain condition a common factor when folks swingarms start getting eaten?
Aaron
2013 R1200GS Triple Black
2006 Beta Rev3 (funnest bike ever!)
1995 VMC sidecarcross rig
Seattle, Washington
crash a-ron is offline   Reply With Quote
Old 07-14-2011, 09:56 AM   #23300
Jäger
Osons
Jäger's Avatar
Oddometer: 791
I can go take some pics if you want. But it looks remarkably ordinary. If you're looking for a discolored chain, you'll be disappointed. If I get motivated, I will go out and do the measurement Yamaha specifies between links to determine how much it stretched. I keep meaning to do that, but with my bike back on the road and summer perhaps finally here, everytime I wander out to the garage I seem to end up going riding instead (that is, the last two whole days).
My problems had everything to do with that evil rock, I believe. I will theorize that munched swingarms are generally the result of chains being set too tight on bikes that get a lot of time on roads where the rear suspension goes through it's full range of travel - take a look at where the wear occurs. I will further theorize that 12 tooth sprockies get blamed for this because their smaller diameter means that excessive tension has a greater effect - and the corollary is that a 14 tooth front sprockie will give you a bit of an additional buffer from damage if your chain is too tight.
But... I'm just guessing.
Jäger is offline   Reply With Quote
Old 07-14-2011, 10:06 AM   #23301
bhd1223
bhd1223's Avatar
Oddometer: 294
Originally Posted by MoBill
This
Yes, I tried that but it kept sliding back. When I loosen axle nuts I LOOSEN them. From now on I'll be leaving it rather snug when making adjustments. I noticed even slightly snug allows the wheel to slide backwards.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 07-14-2011, 10:28 AM   #23302
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,712
Whacking the tire/wheel doesn't inspire a lot of confidence, for me at least. I'm sure the screwdriver system would work (although I'm not sure I want to put that kind of stress on one link), for me it's just a lot simpler to sit behind the bike, squeeze the chain with my left hand (thumb pulling upper chain down, fingers pulling lower chain up, trying to get the chain runs to touch the swingarm) and tighten the axle nut with my right hand. I KNOW the wheel is snug against the axle blocks that way.
Funny story, well, maybe funny...
When we were racing (son rode, I wrenched) I was spending lots of time on tires/wheels/chains between races. It was a busy, hectic time and at some point I began to realize I was having...chest pain. Tried to ignore it for awhile, but it was getting worse so I called and was scheduled for an EKG, pretty promptly. Perfectly normal. Hmmm. A big race season was nearing the end, and I was putting on a new rear tire. I sat down to adjust the chain after replacing the wheel and suddenly figured out the source of my chest pain: I'd gotten into the habit of pushing the wheel against the axle blocks with..........my chest. Stopped doing THAT method, chest pain went away.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 07-14-2011, 11:16 AM   #23303
SkidMarx
SkidMarx's Avatar
Oddometer: 1,976
Maybe a bungee around the tire and the shock. Haven't tried it, but it's worth a try.
'90 XT350
'08 WR250R
GLDS
SkidMarx is online now   Reply With Quote
Old 07-14-2011, 11:47 AM   #23304
bhd1223
bhd1223's Avatar
Oddometer: 294
Maybe that's why my shoulder has been hurting. Where's when I need it?
Just to be clear I don't whack tires, just push and put pressure on them.
Old 07-14-2011, 12:10 PM   #23305
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,971
small on bike bag recommendation??
Outside my little trips every now and again, most of my riding is tight, whooped out, technical and bouncy riding. I try to be as fast and light as possible.
A tank bag is out of the question, since I need to be able to get up on tank to throw bike into some of the corners.
I usually use my Hydrapak Laguna bag. Its has a three Liter bladder, that I usually only fill with 1.5 liters. In the bag section, I carry some minimal tools, tire air gauge, and in a dry bag, my water, cellphone, and cash.
I would like to try and go back to using just my CamelPack classic...and get the tools and wallet/cell/cash off my back.
So, I am looking at either a number plate style bag, or one I could secure to my Automotive Machine Supply rear rack..but if I go that route..it has to be small and not hit me when doing the whoops.
Any suggestions appreciated. Links also helpful.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 07-14-2011, 12:21 PM   #23306
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
http://www.wolfmanluggage.com/Enduro...ddle_bags.html
Put'em on and forget about'em.......you can even stuff a jacket/water bottle inside in addition to your tools......they'll carry way more than you need yet you won't even know they're there.............and this way there's no tail bag hitting you in the ass when you scoot back on downhills or bounce through the whoops....
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 07-14-2011, 12:26 PM   #23307
Oh2RideMore
Oddometer: 1,286
Thumbs down hid bulb review, one year later
So a year later my impression of adding HID bulb to the factory bulb holder on wr250r is DONT DO IT. The shallow basket of the WR does not make a good light pattern, and allows the heat from the bulb,higher than a halogen bulb, to erode/burn off the reflector coating on basket. Looking for a replacement now, thinking of a lynx fairing with built in hid support. If anyone has a factory glass reflector, please PM me. I did find a replacement made in italy for 55 $ online, but unsure of the thickness on reflector coating.
http://www.fourstrokesonly.com/headlights.html
2008 WR250R(Anywhere)
2009 Versys
Oh2RideMore is online now   Reply With Quote
Old 07-14-2011, 12:29 PM   #23308
HardWorkingDog
Harvey Mushman
Oddometer: 1,712
... most of my riding is tight, whooped out, technical and bouncy riding. I try to be as fast and light as possible. A tank bag is out of the question, since I need to be able to get up on tank to throw bike into some of the corners...
At least I'm not the only one who doesn't want a tank bag . Worked great on my street bike, but no way for the way I ride my WRR.
I'm leaning towards a number plate bag--this one, specifically:
Don't have any experience with the bag or the company, but I like what I see on his website. He answered a couple questions I had promptly...Noticed that Rydnseek uses an ersatz number plate bag as well, seems to work for him.
"Coffee first..."
Old 07-14-2011, 12:34 PM   #23309
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
After riding KTMs for so many years I must say I'm REALLY impressed by the "stock" WR250R headlight......it's actually pretty darn good........my 02 KTM 520EXC offers the equivalent of a match on low beam and Bic lighter on high beam .......it's pretty useless..........and you really can't upgrade the stock headlight on the KTM without also upgrading the stator......yet another positive for the little bike
Old 07-14-2011, 12:41 PM   #23310
Oh2RideMore
Oddometer: 1,286
more focused light beam would be good
I would love to get some led spots or a focused beam projector headlamp for the WR, but have not found one for a good price. Coming from the dual beam deep basket reflectors of the vstrom, the WR just does not put out enough light. More like a flood than a defined beam. Show us those pics of the lynx light pattern.
2009 Versys
Times are GMT -7.   It's 04:49 PM.
