07-14-2011, 02:17 PM
#121 |
Hydrophobic
Oddometer: 2,401
There is a youtube video of an introduction for the 2012 models (it's almost an hour long if you're looking for it). They mention in the video at one point that the clutch is backward compatible with the XC-F's to 2007. It would be interesting to see if anything else might be backward compatible with the XC-W/EXC's -especially the cam chain tensioner!
2011 KTM 990 Adventure R 2010 KTM 530 EXC 2009 KTM 950 Super Enduro Erzberg Edition |
07-16-2011, 12:13 PM
#122 |
Oddometer: 115
Picked up my new 500 exc 6 days
I might be sleeping in the garage tonight, I think I have turned Objectum-sexual
http://dave-emsley.smugmug.com/Other...339163_5scnrrB ![]() ![]() ![]()
07-16-2011, 10:29 PM
#123 |
Oddometer: 13,676
Beautiful!
07-17-2011, 07:21 AM
#124 |
Oddometer: 441
Sweet!
"Above all, we must realize that no arsenal, or no weapon in the arsenals of the world, is so formidable as the will and moral courage of free men and women. It is a weapon our adversaries in today's world do not have." Ronald Reagan _____________________________
07-18-2011, 08:59 AM
#125 | |
Oddometer: 320
It's Mapletoe
Seriously, a nutless monkey can do your job.. ------------------------ Husaberg FE570 Husky TE610 KTM SE 950R |
07-24-2011, 11:58 PM
#126 |
Oddometer: 174
Almost here
Intel says just 36 more days until "IT" hits the shore; the street legal 2012 500exc.
My only hope is that the US version will be carb'd. ACERBIS!!! hurry up with that larger tank will ya! HTR ; we need an oil cooler for this new motor if your not too busy please, also add a CUSH sprocket and I'm GTG.
Visigothic screwed with this post 07-25-2011 at 08:05 AM |
07-25-2011, 12:22 AM
#127 | |
Oddometer: 0
![]() http://www.gear4direct.com/?i=311138 No real need for a cush sprocket when you have cush CLUTCH
--------------------------------------------------- 1000cc BMW, 2090cc KTM Swede screwed with this post 07-25-2011 at 06:36 AM |
07-25-2011, 08:05 AM
#128 | |
Oddometer: 174
I hope they make a 5 or 6 gal. for the long hauls. Thanks Swede ![]() ![]() ![]() ![]() ![]() ![]() "Aih' hef qiman ga-tairan reik nauhap'-p'an af-slahan ceasar ...... alls fram-himma fra-qistnan dat jainar bi unsar mnags fotus fram meins kun ...... ahhhhhh." "I have come to dethrone an empire and it's ceasar......which now lay in ruin at the feet of my fellow tribesmen......ahhhhhh." VG Visigothic screwed with this post 08-02-2011 at 09:49 PM Reason: oops |
07-29-2011, 12:06 AM
#129 |
Zoob
Oddometer: 987
Back to the valve adjustment - the head looks exactly like the 2008-2011 450/530 EXC/XC. This is very easy to adjust and very robust.
You pull off one 6mm screw and a forked keeper, then the cam slides out of the bearings and drops down. This allows both rocker arms to pivot up and you can pluck the shims off the top of the keepers. This uses the 7.98 dia shims like all the 2007-up four strokes. Total time to adjust all four is about 45 min, including unloading it from and truck and pushing it in the shop. The USA bike will be a 500 EXC with Fuel Injection, just like the current 350 SX/XC, but no doubt a few more catch bottles. There will also be a street legal 350 exc, but no street legal 450 exc. The Keihin FI on the current 350 XC and the 250 XC is perfect. This FI can be modified to run without a battery in kick start only mode, you only add a capacator. There is a $450 'user setting tool' available from KTM that will allow you to modify the FI and Ign timing, but you won't need it. The only issues so far are dirt getting to the injector, so KTM added a fourth (!) small filter. These should be available in the USA about late-Sept to early-Oct. I've got one on order, it will be replacing an XR650R and a 300EXC, so it will do full trail and dual-sport duties. Just needs a bigger tank (4 gal) and a cush seat.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
07-29-2011, 12:36 AM
#130 |
Oddometer: 990
Every year those seats get smaller, and every year my ass gets wider.
07-29-2011, 06:00 AM
#131 |
Cavalera Conspirator
Oddometer: 956
[QUOTE=Visigothic;16472010]Intel says just 36 more days until "IT" hits the shore; the street legal 2012 500exc.
My only hope is that the US version will be carb'd. + 1
07-29-2011, 12:44 PM
#132 |
roost maker
Oddometer: 1,145
07-29-2011, 10:03 PM
#133 |
Zoob
Oddometer: 987
They sorted out the EFI on the Husburgs (that KTM owns) years ago. So, 2012 will be the fourth? year with the same EFI.
I can't wait for EFI on a street legal trail bike. Been holding off for a couple of years. No more guessing on the choke settings, no more dirty float needles puking gas, no more re-jetting for high desert vs sea level, clean low end torque, much better mileage. Anyone look up the price of a Keihin FCR 41 MX carb from KTM? Try $850!! We added up all the parts for the Keihin FI that comes on the 350XC, that's the pump, injector, fuel rail, sensors, throttle body, everything. Total = $650! These are retail prices in the USA.
07-29-2011, 10:46 PM
#134 | |
Oddometer: 956
07-30-2011, 08:50 AM
#135 | |
Let's Ride
Oddometer: 876
Looks like the head on the 500 is SOHC, and the head on the 350 is DOHC. Any thoughts on that? Differences in reliability, performance? |
