08-12-2011, 05:10 AM
#23821 | |
Oddometer: 3,539
![]() We rode Mill Creek on Saturday, then around the White Rock area on Sunday.
Loud Sucks! www.wrrdualsport.com www.designatedvaping.com <- for all your electronic cigarette needs |
08-12-2011, 07:38 AM
#23822 | |
Navigate 2 Adventure
Oddometer: 2,115
Another perspective on the drop-off next to the rock juting out in the trail......call me a sissy, I don't care, I'm walking around it ![]()
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com |
08-12-2011, 07:40 AM
#23823 | |
Oddometer: 2,115
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com Crawdaddy screwed with this post 08-12-2011 at 07:45 AM |
08-12-2011, 07:42 AM
#23824 |
Oddometer: 289
With the damage to my WR I need to replace the stock bars. I'm looking for a bend that is a little bit taller with a little bit less sweep. With my rough measurements on the stockers it appears the Pro Taper Henry/Reed bend provides this. Can those of you with this bend confirm?
I'm also debating on sticking with 7/8 or going to a big bar. Are there any pros/cons of the choice other than the obvious bigger is stronger and new bar/hand guard mounts needed? Regarding the ends of big bars, I know they taper off the 7/8 for the controls. Do standard hand guard inserts still fit or are mods needed? Thanks.
WR250R - perhaps the ideal motorcycle for myself Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi? I am now for sure sold on the Dual Sport style bike. Keeping the Vulcan for now. The ladies seem to love it.
08-12-2011, 07:50 AM
#23825 |
Oddometer: 2,115
Consider saving a few $$.......I have the cheapo Rocky Mtn "Chub Bars" on my bike and they''re fine......CR high Bend or ATV bend if you really wanna go high.....
http://www.rockymountainatvmc.com/pr...FamilyId=19027 Stock inserts will work on bar ends but you'll need fat bar clamps
08-12-2011, 07:59 AM
#23826 | |
Oddometer: 289
08-12-2011, 08:00 AM
#23827 | |
Lacks Freetime
Oddometer: 4,978
I stuck with 7/8" myself since I already had the snazzy HDB top clamp and did not want to render it useless. Not to mention everything else on the bars is set for 7/8". The Protapers are hella thick, and strong. I am using some Pitposse.com generic risers to get a little more height on them since I stand 90% of the time while riding. The bar end/hand guard connector has to be for a smaller ID..inside diameter bar. Most come with both set ups. The stock bars bend like swiss cheese since they are pretty thin walled...comparatively. Hope that helps.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
08-12-2011, 08:16 AM
#23828 | |
Oddometer: 2,115
Also, I have a GPR stabilzer so my bars are lifted a bit......I went with the YZ bend....
08-12-2011, 08:20 AM
#23829 | |
Lacks Freetime
Oddometer: 4,978
#23830 | |
Huh???
Oddometer: 982
X2 on the Chub Bars. I have those and they seem to be pretty strong and are priced right for my silly budget.... |
08-12-2011, 08:44 AM
#23831 | |
Oddometer: 2,115
08-12-2011, 08:55 AM
#23832 |
Oddometer: 289
Well I just went and took some new rough measurements of the non bent side of the stockers. Somehow my height measurement is much different.
Old Height: 4.5" New Height: 2.75" if not a little less My old width measurement was about 31" and I can't do a new one. My sweep or pull back is about the same. Old: 2.5" New: 2.25-2.5" Can anyone tell me if which height is more accurate? Based of these I think the YZ bend on the Chub Bar is a better option over the CR High. Also, I was wondering if anyone has replaced the plastics around the headlight. There is the top piece then the bottom part that screws into the black frame of the headlight assembly. Well, normally it may be one piece but the top piece popped off and won't pop back on because the lower piece is a little bent and cracked on the left side. Any ideas on exactly what I'd need to replace this? I've been looking on bike bandit for the 08 R and I can't figure out if part 12 is all I need on the headlight schematic. 13 looks like it may be needed but I imagine that broke off when the top piece broke off in the crash as I don't see it anywhere. I don't care about the graphics.
bhd1223 screwed with this post 08-12-2011 at 09:49 AM |
08-12-2011, 08:58 AM
#23833 | |
Huh???
Oddometer: 982
Considering that you do quite a bit of riding on your bike, what do you think about using the RimLocks? ![]() I'm in the process of ditching the stock tires on my WR250R and mounting up a D606 in the rear with a Heavy Duty Fly tube, and a K760 Trackmaster front tire with a Heavy Duty Fly tube. I was considering putting these Rim locks in both tires...... Are they needed? Do they help with lower pressures? I'm not sure If i need them or not...... |
08-12-2011, 10:58 AM
#23834 |
Oddometer: 3,510
bhd,
Per RichardU way back on page 474: Stock bars are 30.7" W, 3.8" H, 2.6" Pull Back. Handy chart: http://www.rockymountainatvmc.com/handlebarinfo.do Sarah
'08 DR650 |
08-12-2011, 11:07 AM
#23835 | |
Lacks Freetime
Oddometer: 4,978
I know once, I got a flat, and the rim lock at least held the tire in place for me, so I could still ride it home without the tire coming off the rim.
