Old 08-23-2011, 12:07 AM   #24106
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Originally Posted by Crawdaddy View Post
Entire thread on SDAR; http://dualsport-sd.com/forums/index...ost__p__110690
unfortunately Chris picked up a nail along the trail but we were on our way after ~20 minutes.....
He changed/patched a tube in 20 minutes?!? Impressive.
That fire tower was still manned? I thought the USFS went all to remote video cameras...
JamesG is offline   Reply With Quote
Old 08-23-2011, 04:54 AM   #24107
greer
Oddometer: 3,729
Key Blank
Ilco X248 YM63 from the local locksmith, cheap.
Sarah
Originally Posted by 10Cup View Post
Guys, searched this forum but came up dry so will ask. Has anyone found a key blank that works with the Yamaha ignition hey? Tried all the Walmart blanks with no luck. As it is I'm on an extended trip and lost my key, do have a spare but would like to get another made while I can.
Any help appreciated
'08 DR650
greer is offline   Reply With Quote
Old 08-23-2011, 07:43 AM   #24108
bhd1223
bhd1223's Avatar
Oddometer: 294
Sarah
Good idea Sarah. I didn't even think to look at the spare for a code. Mine has the same code which makes sense since it's an Ilco.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 08-23-2011, 08:14 AM   #24109
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
20 minutes because "I" brought tools/CO2
The fire spotters at that location stay up there for 10 straight days......then someone drives up in a truck, flips the keys, and the spotter who was there drives back down.......lonely job.......he would've talked our ears off ALL DAY if we had stayed longer
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 08-23-2011, 08:57 AM   #24110
skierd
Wannabe Far-Rider
Oddometer: 2,912
I applied for the fire lookout jobs actually, I'd love the solitude personally. Just read a great book about it too call Fire Season.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is online now   Reply With Quote
Old 08-23-2011, 10:25 AM   #24111
bhd1223
bhd1223's Avatar
Oddometer: 294
Question Radiator Guard Question
Yes, yes. Another question from me. I thought I installed my Flatland radiator guard until I tried to put the tank shroud back on. I'm thinking I did something wrong so those of you who have put one of these on please look at the below pictures and tell me what I need to fix. The problem is it's not possible to put the front shroud bolts back in with the guard in place. They prevent the bolts from being able to be placed through the holes in the shroud and align with the tab/nut things on the radiator. Also, the lower rounded tab coming off the side of the radiator which appears to serve no purpose is actually resting on the guard. I'm not sure you can tell that from the pictures. Thanks for any help you can provide. Is it possible that I just need to tighten the bolt and nut on inside to compress the rubber a bit more?
bhd1223 screwed with this post 08-23-2011 at 11:01 AM
Old 08-23-2011, 11:28 AM   #24112
sturgeon
sturgeon's Avatar
Oddometer: 928
I had essentially the same problem, so I ground out the lower opening a bit with a Dremel, and cut a narrow slot in the lower plastics mounting hole with a side-cutter. I was able to get the upper bolt in, but now I can put the lower bolt in and slide on the shroud before I tighten it. Hope that makes sense.
EDIT: I didn't have a problem with the tab on the rad, but I'd just carefully bend that back a bit if it's in the way.
sturgeon is offline   Reply With Quote
Old 08-23-2011, 12:36 PM   #24113
cozmo2312
Canyon Carver
cozmo2312's Avatar
Oddometer: 240
wow. that's sweet! do you have a build thread for your bike or anything?
Originally Posted by Machtig View Post
cozmo2312 is offline   Reply With Quote
Old 08-23-2011, 12:47 PM   #24114
bhd1223
bhd1223's Avatar
Oddometer: 294
Flatland Racing Rad Guard
Well I need to head out to try and find some plugs to build a cable for the new welder but I just wanted to inform everyone that I modified the radiator guard so I'm able to tighten/loosen the shroud bolts from outside the guard. When I return I'll post up the pictures and mention what I did.
So here goes. I took a file and filed down the spots shown in the following pictures to allow access to the bolts using a L shaped allen key from outside the guard. I started on the lower with the shroud off and after I was able to get the bolt in by hand I put the shroud on because I was able to also get the upper bolt in by hand. I then ran into the problem of tightening the bolts. To solve this I just filed at an angle to try and get straight access to the bolt head. On the lower I was successful but I left the upper as it is just a little off straight because I didn't want to take away more material. I was already getting closer to the bend at the front than I wanted to so I decided it was good enough. Onto the pictures. First is the file, second the lower, third the inner part of the upper, and last the outer part of the upper. On the lower section you can see that I had to remove a good deal with the different curve before I even filed from the side. On the top the only filing was from the side.
bhd1223 screwed with this post 08-23-2011 at 03:29 PM
Old 08-23-2011, 03:21 PM   #24115
debaisley
debaisley's Avatar
Oddometer: 1,424
don't bolt the shroud on , just use thin zip ties. That way if you fall hard on the right side , the zip ties will break , and will save your radiator. If you use the bolts , the radiator can get squished. I have always used the zip ties , the shroud is perfectly secure.
debaisley is offline   Reply With Quote
Old 08-23-2011, 04:32 PM   #24116
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by debaisley View Post
i have always used the zip ties , the shroud is perfectly secure.
+1
Old 08-23-2011, 06:09 PM   #24117
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,442
Took my WR250R to the Central ADV rally, heres some pics.
Saltydog86 on the Northern Highlands route:
My WR nice and dirty.
Fun riding!
Pretty decent scenery up there!
I even got to test a prototype rack!
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger DR650, KTM 990 Adventure R
Lone Wolf Expeditions
rokklym is offline   Reply With Quote
Old 08-23-2011, 06:36 PM   #24118
AZ TOM
Oddometer: 3,876
Fun riding!
Wiconsin the most beautiful place on earth!!
AZ TOM is offline   Reply With Quote
Old 08-23-2011, 06:48 PM   #24119
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,442
i'll trade ya
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Old 08-23-2011, 08:18 PM   #24120
AKASY
Noob
Oddometer: 2,167
Ride
10cup--hope you figure the key thing out, could be a real PITA.
Looking forward to your RR hope the weather holds for you like it did for me.
Ride safe.
Don't make the mistake of believing everything you think.
AKASY is online now   Reply With Quote
Times are GMT -7.   It's 10:15 PM.
