Old 08-29-2011, 05:01 PM   #24196
emerson.biguns
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 8,165
Tubes: Metzeler, they're natural rubber and are easily patched. Others have silicone in them that the patches/glue won't stick to. Don't always assume you'll replace and not repair on the trail.
Read the tire changing thread. Watch youtube videos on changing. Put a little air in the tube before you spoon the tire back on to the rim. Don't jam the spoons deep into the rim.
ps - For a minute I thought I had wondered into the KLR thread.
emerson.biguns is offline   Reply With Quote
Old 08-29-2011, 05:37 PM   #24197
bpg
Off Trail
bpg's Avatar
Location: Charlotte, NC (summer back home in western PA)
Oddometer: 559
word to yo motha... I've always done as you prescribe, never had a pinch flat yet (knock on butyl rubber) Definitely a process you want to take your time with in the comfort of home the first few times, under little duress. By a few tire changes, you'll be adapt at doing it ~ANYWHERE~ - which is good because that's where the WRR might take you!
- Brendan
'08 Yamaha WR250R (sold)
'78 Honda XL250
'02 Honda CBR1100XX
bpg is offline   Reply With Quote
Old 08-29-2011, 06:19 PM   #24198
Cromoth
I've been cloned
Cromoth's Avatar
Oddometer: 385
FMF heat shield spoon
Thanks! It should be 1 bolt/nut to remove to use the spoon for trailside repairs. Question is which way to secure it: tap or weld or another method ya'll think of?
$35/30min shop time - they say they can do either. I'm leaning toward the tap.
FWIW this started at post 24246, right after the license plate heat shield.
Originally Posted by bpg View Post
wasn't sure what you were going for at first, but I have to say I like it - great way to store the spoon and also shield the luggage from the exhaust, in one fell swoop - go for it!
seeking entelecheia thru ipsedixitism
Cromoth is offline   Reply With Quote
Old 08-29-2011, 06:19 PM   #24199
2whl-hoop
2whl-hoop's Avatar
Location: Cottage Grove, the ragged edge of suburbia, MN
Oddometer: 659
I've changed tires four or five times now and the tire changing thread was a huge help. I've only pinched a tube one other time (that was on the front too). I don't know what I'm doing now that's causing the probs...
2whl-hoop is online now   Reply With Quote
Old 08-30-2011, 08:20 AM   #24200
Jäger
Osons
Jäger's Avatar
Oddometer: 668
Originally Posted by chrisspy View Post
So I want to make a heat shield from a 15" tire spoon. The spoon is curved & fits into the passenger foot peg bracket. the other end is flat & it's basically 1" wide.
I have a 60mm (crome) & 70mm (stainless) version of the stock 10mm bolt. There's also a spacer so the bolt holds the muffler braket down. How do I secure the flat end of the spoon to the long bolt?
2 ideas so far:
1: tap the head so a M3 (like the bolt that holds on a skid plate) can screw in. Would need an oval hole thru the spoon since it's at an angle.
2: weld the head of the M3 to the head of the long bolt so the shaft sticks out & can secure the spoon at a 90 deg angle.
All this so the Giantloop Coyote doesn't touch the FMF muffler. I like that it goes back to stock easily & seems to be a great way to store the spoon.
Any other ideas?
I'll propose an alternative idea.
There's always Giant Loop's protector, ready made, which costs less than the shop time is going to cost you and probably goes back to stock even quicker.
I have the Motion Pro tire spoons with an axle nut wrench at the end, one for each axle. They're very light, nest very nicely in minimal space in the fender bag where the rest of the tire change stuff resides, accept their socket converter, and work like a hot damn. I don't think I would have them tapped or welded on, even if it was for free. You've still got a few other things to store that are needed for changing a flat... how much room are you saving by screwing with just one of the spoons to make it do double duty as a heat shield?
I'm sure you've got a plan all laid out, but I kind of like having my spare tube, patch kit, pump, irons, etc all together in one place in a fender bag or whatever, without having to start messing with my GL and whatever is mounted around it. Giant Loop already has their ready-made heat shield, and you could probably recreate it in 15 minutes with a couple of band clamps, some scrap thin sheet metal, some tin snips, and a vise if you really wanted to go low dollar.
I think I also recall a few people having some fab work done on their FMF so that the stock heat shield would bolt on when needed.
Jäger is offline   Reply With Quote
Old 08-30-2011, 10:06 AM   #24201
Roonie
Roonie's Avatar
Oddometer: 379
I have the giant loop protector for my FMF muffler on my WR and it was easy. $25 dollars later and everything is protected. No more worrying about burning stuff on the muffler. I got a fender bag and mounted it to my front fender and that holds all my tubes and tools for tires stuff and bike repair.
Roonie is offline   Reply With Quote
Old 08-30-2011, 12:23 PM   #24202
SteveO
Huh???
SteveO's Avatar
Oddometer: 979
Got any pics?
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 08-30-2011, 01:41 PM   #24203
Roonie
Roonie's Avatar
Oddometer: 379
No but I can take some soon.
Old 08-30-2011, 01:43 PM   #24204
Rufjeep
Oddometer: 304
I definately applaud your ingenuity. But, do you really want to have to remove any luggage you might be carrying just to get to your tire spoon?
Rufjeep is offline   Reply With Quote
Old 08-30-2011, 06:53 PM   #24205
Cromoth
I've been cloned
Cromoth's Avatar
Oddometer: 385
FMF GL heat shield
Definitely looking forward to pics of GL's heat shield with luggage (coyote?) mounted.
I looked at it on their website but didn't think it'd do the job on the WRR since there's no plastic shield above like on their pix of the KTM.
Thanks for all the comments.
Old 08-30-2011, 09:24 PM   #24206
malibu_dan
Adventuring Mystic
malibu_dan's Avatar
Oddometer: 1,070
Working on the install write-up and review for the Britannia Composites Lynx fairing. Been riding with it for a week, and I had high expectations for it to meet... I'll have it all up on wrrdualsport.com in the next week or so. We'll put some mixed miles on it this weekend also.
Follow me over here >>> WRRDualSport.com <<<
malibu_dan is online now   Reply With Quote
Old 08-30-2011, 11:53 PM   #24207
thumpjump
huh?
thumpjump's Avatar
Oddometer: 97
Dawn To Dusk 12 Hour Enduro
This is how I spent last weekend!
Dawn to Dusk 12 hour (Actually 13 hour) Enduro in Wales, U.K. WRR performed flawlessly. The other bike is my teammates KTM 400EXC. Go Team Allied Farce!!
Pre-Race Photo
After Lap 1 of 6
2010 Yamaha WR250R
2008 KTM 690 Enduro
1983 Yamaha Chappy
thumpjump screwed with this post 08-31-2011 at 05:52 AM
thumpjump is offline   Reply With Quote
Old 08-31-2011, 06:19 AM   #24208
makad
P/T Shed Dwelling Hermit
makad's Avatar
Oddometer: 191
......cant wait
makad is offline   Reply With Quote
Old 08-31-2011, 06:24 AM   #24209
flatboarder
flatboarder's Avatar
Oddometer: 235
Send a message via Skype™ to flatboarder
Great!
I love that stuff. Congrats!
Phil
flatboarder is offline   Reply With Quote
Old 08-31-2011, 12:32 PM   #24210
Doctor Zed
Resident
Doctor Zed's Avatar
Oddometer: 857
Hey guys. I wanted to order Flatland Racing radiator guards for my wifes WR and is it true they only make them for one side?
I thought that was kinda funny
Doctor Zed is offline   Reply With Quote
Times are GMT -7.   It's 01:07 PM.
