Old 08-05-2011, 07:47 PM   #61
ThatOtherGuy
ThatOtherGuy's Avatar
Oddometer: 308
Anybody ever rebuild the master cylinder on the front or rear brakes on their FT? I'm having trouble with my rear master cylinder and was thinking about getting a rebuild kit.
If you have done this, how hard of a job was it?
Anything's possible with screwdrivers, big hammers, and beer.
ThatOtherGuy is offline   Reply With Quote
Old 08-06-2011, 12:20 PM   #62
truck6driver OP
The Fireman
Oddometer: 7,455
Havent yet. I have on a car and it is the same thing just smaller. Trick is to bleed the crap out of it or your time will be wasted. Should be pretty straight foward.
Ray
When the system fails you, what then?? Do you fight it or just surrender and give up? If all seems doomed what is left to fight for? Is it just me or does the world seem to close in on you when you seem to be making ground? Options are dwindling down, what comes next? And in the words of Pink Floyd "Is there anybody out there". All I know is I WILL SURVIVE.
truck6driver is offline   Reply With Quote
Old 08-06-2011, 06:45 PM   #63
ThatOtherGuy
Oddometer: 308
Well, I'll be doing it here in a few weeks. I'll take some pics and try to do a write up.
Depending on how it turns out it could be very informative or a model of how not to do it.
Old 08-07-2011, 06:32 PM   #64
ClineDesign
Grandpa
ClineDesign's Avatar
Oddometer: 366
Originally Posted by CharlieT View Post
Here's what I did to my '82 FT500 Ascot a few yrs ago:
I'm interested in what you had to do to mount the tracker seat to your FT. Got any photos? Thanks
ClineDesign is online now   Reply With Quote
Old 08-07-2011, 06:53 PM   #65
ThatOtherGuy
Oddometer: 308
As am I. The stock seat puts my to sleep.
Old 08-07-2011, 06:54 PM   #66
tmills
tmills's Avatar
Oddometer: 120
A friend of mine has an Ascot and he is having trouble with the rear brake sticking on. He thinks its in the master cylinder. He was looking at my KLR650 and he thinks that the rear master cylinder from a KLR will fit the Ascot so now he's looking for one.
tmills is offline   Reply With Quote
Old 08-07-2011, 06:56 PM   #67
ThatOtherGuy
Oddometer: 308
I figured I would get mine from here, but if the master cylinder is rusted on the inside you would need a whole new one anyway because you would never get a decent seal again.
Old 08-07-2011, 08:24 PM   #68
truck6driver OP
The Fireman
Oddometer: 7,455
When I got mine the rear brakes would stick. It ended up being the caliper piston binding. I had a CB650SC parts bike and the front brake calipers are the same as the Ascot ones. Both front calipers fit the Ascot. The right front fits the Ascot rear and the left front fits the Ascot front. Once I swapped out the caliper and bleed them out (what a P.I.T.A.) rear brakes work just fine.
Ray
Old 08-12-2011, 06:08 AM   #69
ThatOtherGuy
Oddometer: 308
Finally got my Ascot back on the road. I've been out of commission with an oil leak for about a week.
Old 08-12-2011, 12:17 PM   #70
Hughlysses
Hughlysses's Avatar
Oddometer: 3,338
Sometimes the master cylinder relief port can get blocked which will lead to the brakes gradually coming on. The pads drag a little, that heats up the pistons, which heats up the fluid, causing it to expand. It's got nowhere to go because of the blocked port, and the brakes eventually come on.
The front M/C on my VT500FT suffered from this. Took me a while to find it- I discovered the small area of yellow discoloration in the bottom of the reservoir was actually a hole that was full of yellow gunk. Disassemble, clean, prod hole clear with a piece of guitar string, reassmble, still good 20k miles later (with yearly brake fluid changes).
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is online now   Reply With Quote
Old 08-12-2011, 01:41 PM   #71
Olderslowerguy
Olderslowerguy's Avatar
Oddometer: 409
FT Ascot Luggage Rack
I'm cleaning my shop and have found a luggage rack I took off a FT Ascot when I bought it for my son...it does not have any markings on it, so doubt it is a Hondaline rack...BUT, it's free to anyone who wants it....pictures available if you will email me at RHerringt@aol.com
OSG
Clearwater, Fl.
Olderslowerguy is online now   Reply With Quote
Old 08-13-2011, 11:24 AM   #72
truck6driver OP
The Fireman
Oddometer: 7,455
E-Mail sent.
Ray
Old 08-19-2011, 06:37 AM   #73
fiep
fiep's Avatar
Oddometer: 1,918
would you considder this VT an Ascot or not?
fiep is offline   Reply With Quote
Old 08-19-2011, 09:38 AM   #74
Malcolmlovesbikes
Oddometer: 26
I have owned one in the past and they are a nice bike, but not an ascot, only the motors, swing arm, rear brake and one or two other bits are the same. They ride and handle quite differently. Not better or worse but different, mostly down to the Ascots longer forks and longer wheelbase. I've got two of these in bits the best is being used as parts to rebuild my VT500FT and the other to be rebuilt as standard. This one looks a fine example. BTW I came off the last one I had, got some help to kick the handle bars staight pulled of the broken indicators, front mudguard, fairing etc and rode it 110 miles home.
Malcolmlovesbikes is offline   Reply With Quote
Old 08-31-2011, 07:09 AM   #75
fiep
fiep's Avatar
Oddometer: 1,918
I sure hope 'snow white' is a fine specimen
am prowd to own her
but she is to d#$% far away and importing her to the States would cost far more than the bike is worth
so I am looking to buy an Ascot now
well this Ascot:
not perfect but nice
don't like red but who cares?
think she will make a good commuter?
Times are GMT -7.   It's 09:48 AM.
