Go Back   ADVrider > Riding > Regional forums > Central – From Da Nort Woods to the Plane States
Old 09-01-2011, 08:12 PM   #39391
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,288
Originally Posted by MrFurious View Post
Yeah, I have all the dimensions off it, the problem would be finding someone with a 16mm drill bit long enough to bore a 9" hole and not have it drift off center. Would also need to be hardened.
O.D. = 22mm
I.D. = 16mm
Length = 8.8125" (8-13/16")
I think Whitey has the best idea to call the Rice paddy. If they don't have it they might be able to cross reference another bike that used the same part.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 09-01-2011, 08:12 PM   #39392
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,921
O.D. = 22mm
I.D. = 16mm
Oversized bar stock, drilled to 16mm, then turned to 22mm OD, then hardened, is how you'd do it.
swingset is offline   Reply With Quote
Old 09-01-2011, 08:20 PM   #39393
buildit
buildit's Avatar
Oddometer: 14,288
Or:
http://www.powersportsplus.com/parts...FWICQAod_D9m1A
I also spotted this blurb
Re:Bronze swingarm bushing question Posted by RonKZ650 - 03 Feb 2009 17:38
_____________________________________
The bronze bushings were used on all those except the KZ650 was only in 1977. 1978-83 was needle
bearings. You don't want to put crap bushings in place of needle bearings even if they would fit. Buy the
4 needle bearings. Kawasaki part #92046-1115. 4 bearings are cheaper than one bronze bushing
through Kawasaki $11 each at bikebandit.com where it's around $46 each for the bronze bushings used
in 1977
Re:Bronze swingarm bushing question Posted by 650ed - 03 Feb 2009 17:55
Please check with dealer to be sure, but according to Kawasaki.com, it looks like the KZ650B2 uses 4
needle bearings – part #92046-1115 (these are available Ron Ayers price = $8.80 each, Z1E may
charge less?) and 1 swing arm sleeve – part #42036-1012 (no longer available from dealer, but some
internet parts dealers have them). Always check the eBay part numbers against Kawasaki.com before
buying because the folks selling stuff very often list the wrong models for the parts their selling. You
may be able to get a refund if the seller is honest, if not, let us know his eBay ID so we are extra careful.
Ed
2013 Super-10
2007 KTM950SEr
2006 KLR650
Old 09-01-2011, 08:20 PM   #39394
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,201
Broom stick and duct tape as a shim is how I roll.
Whitey1 is offline   Reply With Quote
Old 09-01-2011, 08:23 PM   #39395
buildit
buildit's Avatar
Oddometer: 14,288
That does explain your mesh MC jacket made from an old potato sack.
2013 Super-10
2007 KTM950SEr
2006 KLR650
Old 09-01-2011, 08:47 PM   #39396
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,201
It works, however I am always getting hungry for chips when I wear it.
Old 09-01-2011, 08:59 PM   #39397
flashover604
tailgunner
flashover604's Avatar
Oddometer: 552
Evening... My 640 exploits continue! If any of you have followed the 640 threads, you may have seen the HID headlight update that dirty_sanchez did on his (now my) 640. If not, and you have a little time... http://http://www.advrider.com/forum...d.php?t=197163
Anyway, when I got the bike, the low beam ballast was hosed. You'd hit the switch and it'd flicker but not fire. I ordered a set of H1 bulb/ballasts for $38 on eBay and got them in today. Two wire hookup. All I had to do was replace the bulb and ballast on the low beam side. I was done in half an hour and really wanted to try them out. Once I got out of town, I hit the high beam. Dirty had wired the switches so I could have the high beam on by itself or high and low at the same time. When that high beam lit, I could see every reflector for at least half a mile. Not "hey, is that a reflector down there?" but "Hole LEE COOOWW! This looks like a runway!" I've never seen motorcycle headlights this bright. I wish I'd have done this on my EXC when I had it. If you have a separate high beam bulb and low beam bulb, I'd at least look into this. You could probably put everything together for $150 or so. The low beam didn't seem to bother anyone, or at least they didn't bother to flash me. I used to hate riding at night. I did fifty miles tonight just because. These bulbs are only 35W as opposed to the 55Ws that come stock. Not bad, at least twice the light and a little more than half the power draw. I'm really liking this thing...
"That which does not kill You, usually makes you wish it did......."
flashover604 screwed with this post 09-01-2011 at 09:04 PM
flashover604 is offline   Reply With Quote
Old 09-01-2011, 09:05 PM   #39398
buildit
buildit's Avatar
Oddometer: 14,288
V-strom
Those who've ridden one at night know what I'm saying.
2013 Super-10
2007 KTM950SEr
2006 KLR650
Old 09-01-2011, 09:27 PM   #39399
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,921
V-strom
No doubt. Best lights ever put on a motorcycle....ride home with 'em every night. BTW, Silverstars are the shiznit in the Strom.
Old 09-01-2011, 09:38 PM   #39400
buildit
buildit's Avatar
Oddometer: 14,288
I'm always getting flashed with the low beams on. So I flash back to prove the point and they end up in a ditch because they can't see anything but a giant white spot for three hours.
2013 Super-10
2007 KTM950SEr
2006 KLR650
Old 09-02-2011, 03:08 AM   #39401
BigOhio
BigOhio's Avatar
Oddometer: 480
That's nothing, you should have seen the utility quad on top of the Geo Tracker I followed up 33 from Nelsonville last weekend. Couldn't get past that one fast enough!
It'll be okay
Just leave me alone...
BigOhio is offline   Reply With Quote
Old 09-02-2011, 03:13 AM   #39402
BigOhio
BigOhio's Avatar
Oddometer: 480
As a long shot try James T. Parker in Somerset PA. He was my dealer growing up now defunct. Has a website and still NOS parts in stock. He probably still has my 73 H-1 that my dad refused to store when I moved away. Said he didn't want it but he is probably making a few bucks parting it out now...
Need some help finding a part for a 1979 KZ650 SR (KZ650-D2). Apparently it's been discontinued and not a single dealer in the U.S. has one left-over in their inventory. What I need is the swing arm sleeve (#6 in the diagram below) that the bearings ride on. Kawasaki's P/N was 42036-1012
Unfortunately a sleeve from a B3/C3 model won't work as those models used bushings rather than needle bearings.
BigOhio screwed with this post 09-02-2011 at 03:18 AM
Old 09-02-2011, 03:58 AM   #39403
gelandestrasse
Fidem Scit
gelandestrasse's Avatar
Oddometer: 20,255
1,700 pairs of panties strewn along road
AP - Authorities are trying to solve a panties puzzle: why hundreds of pairs of mostly women’s underwear were dumped along the side of a road.
Fairfield County Deputy Gary Hummel said yesterday that the undergarments were found in trees and on hillsides in several spots this week on a road in Berne Township, about 30 miles southeast of Columbus.
He said some of the panties were still folded the way they’d come in packaging, while others appeared to have been worn. There were nearly 1,700 pairs in all, in a mix of colors and patterns. Hummel said that when collected, they filled 10 large trash bags.
He said investigators are “baffled” as to where the panties came from.
"The trouble with quotes on the Internet is that you can never know if they are genuine."
- Abraham Lincoln
gelandestrasse is offline   Reply With Quote
Old 09-02-2011, 04:18 AM   #39404
Castle
Red Cloud Slept Here
Castle's Avatar
Oddometer: 1,143
He said investigators are “baffled” as to where the panties came from.[/INDENT]
Obviously fall-out from the government's War on Panties. The street value of used women's panties is HUGE in Japan. Just check e-bay.
"Adventure is the result of poor preparation" - Mark Twain
Castle is offline   Reply With Quote
Old 09-02-2011, 04:26 AM   #39405
dragoon
I'm the REAL Dingo Joe
dragoon's Avatar
Oddometer: 23,185
TOD! How's things?
Everyone should be so lucky as to be able to ride a motorbike through the Himalayas.
- Misery Goat
daveology rule #143 - never ever pass up a chance to hear a band that has a stand up bass -Mutineer
dragoon is offline   Reply With Quote
Times are GMT -7.   It's 01:46 PM.
