08-31-2011, 09:19 AM
#76 |
mc caregiver
Oddometer: 2,592
neck kit for Ascots
08-31-2011, 07:10 PM
#77 |
The Fireman
Oddometer: 5,791
Fiep,
Nice looking bike there. Have you bought it yet? Ray |
09-01-2011, 05:41 AM
#78 |
Oddometer: 1,832
after checking with the tag office - no title + back taxes -
I called and said I'll take it seller will not be available for pick up before Sunday so yes and no I hope I bought it will need fork seals and stock turn signals |
09-01-2011, 09:52 AM
#79 |
Oddometer: 302
Anybody else have trouble finding parts for their ft? I've had to call all kinds of different salvage yards with no luck.
Anything's possible with screwdrivers, big hammers, and beer. |
09-01-2011, 10:00 AM
#80 |
Riding to the horizon.
Oddometer: 385
![]() 82 ascot 500 motor: overbored 1 mm with Wiseco Hi comp piston, stock cam. 83 XL500R frame 2002 CR250 front forks and triple clamps, stock stem pressed in. A&A Racing 19" front rim on CR250 hub. black excel rim and stainless spokes. CR125 MX brake rotor classic double wall race header and Yosh GSXR muffler project in process
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS |
09-01-2011, 03:15 PM
#81 | |
The Fireman
Oddometer: 5,791
What parts are you looking for? Ray |
09-02-2011, 09:56 AM
#82 | |
Oddometer: 302
I was looking for a rear master cylinder, but since I last posted I cleaned mine up and it's looking pretty good. Although it may be nice to have one on hand.
09-02-2011, 10:33 AM
#83 | |
The Fireman
Oddometer: 5,791
![]() Like with the engine the took the XR engine and just adapted it for street use. Bigger exhaust head, kick start remove and starter cheaply added with external bracketry. It works. I like my Ascot and ride it more than my Nighthawk. Ray |
09-02-2011, 11:52 AM
#84 |
Oddometer: 26
09-02-2011, 12:41 PM
#85 | |
Oddometer: 1,832
it 'lives' in a friends garage in Germany gets out whenever I make it over there if shipping would not by far exeed the bikes value and I do not see a hazzle free way to get it registered in GA *sigh* |
09-04-2011, 10:53 AM
#86 |
Oddometer: 1,832
09-04-2011, 11:46 AM
#87 | |
The Fireman
Oddometer: 5,791
the front ones on the FT500 are on the fork clamps and not on the headlight brackets so I'm not sure if it is right or not. Ray |
09-13-2011, 09:46 AM
#88 |
Oddometer: 29
FT500 Ascot Project Bike
Found an FT500 that had been sitting for about 17 years or so .. here is a picture of the bike when I picked it up.
![]() To date, I have replaced the chain, treated the fuel tank for rust (but I think I still need to reline it), purchased replacement rear shocks from PartsNMore, rebuilt the starter solenoid mechanism (the PO had already rebuilt the starter itself), cleaned the carb (twice so far), ordered brake caliper and master cylinder rebuild kits (not done yet). Bought a replacement seat cover but haven't installed it yet (the seat pan and foam are good). I'm currently trying to figure out why it won't start. Need to check compression today and rule that out. Spark is there but I'm not sure it's strong enough. The petcock needs to be repaired as gas leaks out w/o vacuum being applied. The bike itself only cost me $150 and I've spent much more on parts already .. Hope to get it running soon so I'll feel better about my investment!
Ray '98 NH 750, '82 FT500 |
09-13-2011, 10:06 AM
#89 |
Oddometer: 29
hose routing question
Can anyone verify if I have the carb/petcock hose routing correct?
Just want to be sure. Currently, I have carb port 1 connected to petcock port A ... and carb port 2 connected to petcock port B. Also, I'm curious about the first connection's purpose ... is it an alternate fuel supply line to the carb? These port designations are my own.
09-14-2011, 08:52 AM
#90 |
Oddometer: 190
My understanding on Petcocks on Hondas is that there is 1 fuel line (1/4" to 5/16" ID)
and 1 vacuum line (3/32" ID). The 3rd. port on the petcock is left open to atmosphere. In one case, I saw a filtered vent line on that 3rd. port, but it was still open to the atmospehere. The fuel line connects to the floatbowl (s) and the vacuum line connects to the engine intake at 1 of the carbs. From the drawing, I would guess that even though it has a hose on it, the outermost small nipple should be vented to the atmosphere, not connected to the engine intake. http://www.hbhonda.com/fiche_section...1982&fveh=3421 Note that the left most hose has only 1 hose clip on it and none on the "open" end. Ride safely,
ExTex 1983 Nighthawk 650 1989 Inteceptor VTR 250 1985 Sabre 700.......Sold 1983 Shadow 500.... sold 2006 Ninja 500........ sold |
