Old 09-05-2011, 09:01 PM   #10396
jackpiner57
Moto-Racks.com
jackpiner57's Avatar
Oddometer: 1,679
Originally Posted by Naq View Post
You weren't using enough fuel on the slow rocky section and it flooded. Turn the idle mixture screw the whole way in and if enough fuel is getting by the float needle valve it will still idle because the fuel level is too high in the bowl and you will know there is a problem.
If it wasn't just a temporary problem, make sure the petcock doesn't leak when the bike is off. Check the float level, valve needle, needle seat, and needle seat o-ring. Some searching will give details since it is a common issue.
Thanks for the reply. I'll check it out and post what the problem was.
Originally Posted by bobbed06 View Post
Thanks for the link.
Tom - '07 DR-Z400S, '05 DL650
Dual Sport Luggage Racks: DRZ400, DR650, KLR650, WR250R:
http://www.moto-racks.com
"I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott
jackpiner57 is offline   Reply With Quote
Old 09-05-2011, 10:28 PM   #10397
LockRider
Oddometer: 44
Originally Posted by ifixfords View Post
Got the DRZ for the liquid cooling, and auto clutch...... Auto clutch works great .....
Maybe I am confused, but what are you talking about? I have never heard of an auto clutch....well an automobile clutch, but I don't think that is what you are talking about as that wouldn't make any sense.
LockRider is offline   Reply With Quote
Old 09-05-2011, 10:47 PM   #10398
southy
southy's Avatar
Oddometer: 117
There are a number of aftermarket auto clutches out there for motorcycles although the DRZ don't come standard with them.
Look here,
www.rekluse.com
www.revloc.com.au
Current rides - Husqvarna TE610IE and Suzuki RMX250.
southy is offline   Reply With Quote
Old 09-05-2011, 11:02 PM   #10399
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by SuchesRider View Post
I am thinking about replacing the stock carb on my 08 DRZ400S with the FCR 39 carb. I see that ThumperTalk sells a kit and was wondering if any of you all have had experience with it.... Any feedback appreciated.... Thanks. SR
I have one of the TT FCR39MX carbs. It adds ALOT of throttle response, and about 3-5 hp on a stock engine, but really likes a big bore kit,cams, and a SSW pipe. Then your DRZ will be a monster. Its expensive at almost $600 bux though.
bobbed06 is offline   Reply With Quote
Old 09-06-2011, 07:09 AM   #10400
msgvb
msgvb's Avatar
Oddometer: 273
Originally Posted by r22eric View Post
sweet im glad to hear that i am a week away from my corbin seat and cant wait, so i will be adding a clark tank very soon
Hey fellas, so does this mean the Corbin seat for the DRZ mounts up with no probs when using the Clark tank?
-msg
msgvb is offline   Reply With Quote
Old 09-06-2011, 08:32 AM   #10401
William42
William42's Avatar
Oddometer: 3,048
Very happy with mine.
Mud is evil
William42 is offline   Reply With Quote
Old 09-06-2011, 09:51 AM   #10402
LockRider
Oddometer: 44
Look here,
www.rekluse.com
www.revloc.com.au
Thanks. In my opinion that has to be the lamest thing you could ever do to your bike. It seems to turn a bike with a manual transmission into a mini-bike with a centrifugal clutch with 5 speeds. I guess it is like training wheels for an adult bike.
Old 09-06-2011, 09:57 AM   #10403
CatfishRacing
Just a rider.
CatfishRacing's Avatar
Oddometer: 628
You've never used one huh?
I rode the Sandy Lane Enduro on my KTM 450 with the stock clutch one year and added a Rekluse z-Start Pro for the next year.
It made a world of difference.
It made it less fatiguing to ride so you could ride faster.
I still got my ass handed to me but I had more fun because of that Rekluse.
Just sayin'.
Catfish
FarkleMasters.com
IBA #12835
AMA Lifer
CatfishRacing is online now   Reply With Quote
Old 09-06-2011, 10:24 AM   #10404
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Talking My take on the auto clutch
I have ridden 2 bikes equiped with the Rekluse auto clutch and the left hand rear brake (LHRB) and i have to say man what a difference it makes! You never have to use the clutch or have to worry about stalling the engine ever again. And when in tight right hand down hill switch backs all you have to do is use 2 fingers on the rear brake and ride right thru the switch back with worring about how am I going to do this AND use the rear brake.
As soon as I can afford to get one I will put that setup on my DRZ!
Go forth and modify my friend.
jeff_in_rc is offline   Reply With Quote
Old 09-06-2011, 10:36 AM   #10405
CatfishRacing
Just a rider.
Oddometer: 628
My setup leaves the clutch lever in tact.
You could still use it although it has no effect at low RPM.
I didn't have the left hand brake but that must be pretty convenient also.
Catfish
FarkleMasters.com
IBA #12835
AMA Lifer
Old 09-06-2011, 10:44 AM   #10406
Spacelord
Mutha Mutha
Spacelord's Avatar
Oddometer: 874
I like the looks of that, I'm assuming it doesn't use the stock spacer does it ?
"I swear to god that I will beat you senseless with a sanka can before I die"
Spacelord is offline   Reply With Quote
Old 09-06-2011, 11:23 AM   #10407
BugsyGS
Oddometer: 36
DRZ Temp light is on!
Any advice out there regarding my temp light coming on? 2004 DRZ with 4,500 miles on it..mint condition. Rode about 20 miles and light flickered and came on...fan did not come on & when it cooled off I checked coolant level..all good. If you have any suggestions please PM me.....thanks!
BugsyGS is offline   Reply With Quote
Old 09-06-2011, 11:41 AM   #10408
bobbed06
Oddometer: 1,236
No sir It does not. You will need shorter bolts and it eliminates the spacer. Saves a good chunk of weight as a bonus... The seller is a nice fella as well.
I have been looking into handlebar mounted headlights and was wondering if any of you fellas had tried these lights?
http://trailtech.net/handlebar_lights.html
My DRZ project has slowed down a bit because I took a fairly hard hit from an event that involved a Big Bertha Innertube, a High HP boat, and a generous use of Throttle from the driver. I am hoping I will be able to take it easy for a week or two and get back to work on it. My ribs are bruised and I am hoping they arent cracked. I dont have any bruising visible so I am hoping thats a good sign.
Feedback on these lights appreciated. Thanks Naq for the encouragement on the Trailtech 8 inch options. I appreciate the info on the Lynx as well Jettn Jim. They are still on the short list.
Old 09-06-2011, 11:46 AM   #10409
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Thumb
PM sent.
Old 09-06-2011, 11:52 AM   #10410
ZukiNoomin
The Dude abides
ZukiNoomin's Avatar
Oddometer: 292
Temp light Question
Start by thoroughly flushing (including forced reverse-flushing) your cooling system.
Replace coolant with silicon-free motorcycle coolant, Maxima or similar.
Test your fan's thermostatic switch. It should make contact when placed in boiling hot water.
Test your fan by connecting it to 12V DC.
OOPS missed the part about PMing...
Winter Springs, FL
Yeah, well, you know, that's just like your opinion man - The Dude
ZukiNoomin is offline   Reply With Quote
Times are GMT -7.   It's 01:59 PM.
