Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 09-07-2011, 04:29 PM   #31
etyson
Oddometer: 56
Originally Posted by jphish View Post
Happy Trails SU rack for tigers will accomodate any hard pannier that has a flat mounting surface & can be used for drybags as well. Good as auxillary frame sliders when bags are on / off too.
I was thinking about the HT SU racks with 1450 pelicans for a compact form factor around town. Small storage plus a place to put my armored jacket, gloves, etc.
Then, what I really need is a 2" thick top box that expands like an accordion to one-foot tall box to accommodate a helmet when I'm stopped.......
etyson is offline   Reply With Quote
Old 09-09-2011, 09:34 AM   #32
gallowaystx
gallowaystx's Avatar
Oddometer: 135
+1 to that!
gallowaystx is offline   Reply With Quote
Old 04-02-2012, 10:43 AM   #33
SpecialAgentNancy
& your little dog 2!
SpecialAgentNancy's Avatar
Oddometer: 548
Ortlieb
Been reading this thread, saw at the beginning that someone mentioned they have ortlieb soft saddle bags, so do I.
I don't use hard panniers ever (I guess I don't pack that much even on my month long trips through Europe) anyhoo....having a hard time figuring out which rack option is best.
1. I will never use hard cases, only my ortlieb soft bags
2. I need an inexpensive rack to get the exhaust bag away so it won't burn/melt
3. I want a rack that has a bar across the back so that if I do go down, it won't bend in
4. I don't care how pretty it looks, I'm going for cheap but strong
I've looked at Caribou, Happy Trails and Touratech.
Want to stay under $300
Advice with links to the frames only would be ideal thanks...some abbreviations on manufacturers had me spending way too much time on google
SpecialAgentNancy
SpecialAgentNancy is offline   Reply With Quote
Old 04-02-2012, 11:19 AM   #34
MisterPX
Oddometer: 143
Maybe make your own? This frame setup, 3/4 steel square tubing, basically two rectangles with support arms, and crossbar, ran less than $15 in stock, plus bolts/nuts.
MisterPX is offline   Reply With Quote
Old 04-02-2012, 02:17 PM   #35
fbj913
I ride
fbj913's Avatar
Oddometer: 2,396
Happy Trails gets my vote.
fbj913 is offline   Reply With Quote
Old 04-02-2012, 06:16 PM   #36
Bad-Tat
800 XC
Oddometer: 125
Tourtech 35L bags. Kept the ones from my Dakar. The right side hangs out there a bit but can't split lanes anywhere on the East Coast so not much of an issue.
Bill
1995 XR 650L, Tiger 800 XC, 72 Triumph T100R, 86 SRX 6, 05 FLSTSCI, 13 Vespa 300, 08 Versys, 14 Grom
Bad-Tat is offline   Reply With Quote
Old 04-02-2012, 08:48 PM   #37
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,568
I'm seriously thinking Ortlieb as well. Is the only reason you want a rack is to keep the bag off the exhaust? If so, how about this?
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 04-02-2012, 09:55 PM   #38
wiskee
wiskee's Avatar
Oddometer: 12
After much hand-wringing, I ended up with the Touratech Zegas. So far, works great. I opted for the standard bags (not the cut away on the muffler) with 38l/45l boxes which have a pretty symmetrical feel. I haven't had much off-road use, but on the freeway, there isn't much problem with wind, etc.
wiskee is offline   Reply With Quote
Old 04-03-2012, 08:39 AM   #39
SpecialAgentNancy
Oddometer: 548
already got a heat shield and its not enough
SpecialAgentNancy
Old 04-03-2012, 09:37 AM   #40
jphish OP
Oddometer: 622
I have the Ortlieb soft bags & 38L zega pros. The HT symetrical rack (same width both sides) work fine for either. Havent "crash" tested yet - but sure 'beta' test will come in due course. Zegas for fishing / camping trips - Ortlieb for just dirt fun. Soft bags just arent sufficient volume for all the gear I schlep (copious quantities of food, waders, boots, fly rods, reels, 4 flyboxes, tent, sleeping bag etc etc. for camping & fishing. But OK for just one or the other & great otherwise. Also use 70L sealine bag for 'topper' over side cases - looks like the Clampets coming to town.
jphish is offline   Reply With Quote
Old 04-03-2012, 09:42 AM   #41
jphish OP
Oddometer: 622
MisterPX - those look great! Nice job. Why dont you fab a set up for 'special agent Nancy' ? About $250 cheaper than HT's.
Old 04-03-2012, 07:03 PM   #42
MisterPX
Oddometer: 143
Now you got me thinking, I might just build another set. This time, I'll fix some measurement issues I had with version 1 ( didn't account for subframe taper, so racks are at an angle to the bike).
I wonder if I'll get pulled over carrying a 12' length of steel like a medieval jouster?
Old 04-04-2012, 06:27 AM   #43
jphish OP
Oddometer: 622
As long as you have a little red flag on the tip & wear a helmet...you should be fine. Jousting is legal on Freeways here ...just not on secondary roads. With the square tubing, your racks look a lot like the HT SU model. Also like the ammo case - good use of the 'space'.
Old 04-04-2012, 08:44 AM   #44
SpecialAgentNancy
Oddometer: 548
Love the idea and open to it. Your racks look beefier than the HT and I've heard complaints from GS owners of the tiny clearance between the back and exhaust, one small bend and it would be touching.
SpecialAgentNancy
Old 04-04-2012, 04:53 PM   #45
jphish OP
Oddometer: 622
S.A.N - Uh...yep. That can happen alright. SU racks need about another 1/4 - 1/2" space on exhaust side. But geez...theyre already hippo width size! No lane splitting with these racks. Of course, not legal here anyway. If MrPX fabs another set - you ought to snag his old ones. Looks like nice work! Chow' j
Times are GMT -7.   It's 03:51 AM.
