Old 09-21-2011, 12:58 PM   #76
BigChris99
BigChris99's Avatar
Oddometer: 226
I've had two Wings, a 1986 1200 Aspencade, and the 1991 1500 Aspencade that I've had for years. I've done so much to my 1500 over the years, it is perfectly set up for me. It is a mile eater of a bike. Comfortable, fast enough for me and reliable as a stone. I don't believe I will ever sell this bike. I really like the 1500 version of the Goldwing. I have all the room to streach out, and it has great weather protection too. I like Hondas flat six so much, that when I found a 1997 standard Valkyrie two years ago, I bought it. A Goldwing on steriods. Both of those go well with my KLR too. Got all the bases covered. Touring, Hotrod cruiser, Dual Sport. Life is good.
Goldwing
Valkyrie
KLR
4on3off
IBA#7849
1991 Honda GoldWing...gone 1997 Honda Valkyrie, 1998 Kawasaki KLR 650
BigChris99 is offline   Reply With Quote
Old 09-21-2011, 03:14 PM   #77
moist
Thaumaturgist
moist's Avatar
Oddometer: 180
Goldwing
Valkyrie
KLR
Awesome stable selection in my opinion.
I have a 99' Valk an 02' BMW GS and a 87' KX500 gotta love a good selection. But I want a goldwing. 15 or 18, will be fine.
moist is offline   Reply With Quote
Old 09-22-2011, 06:37 AM   #78
BigChris99
BigChris99's Avatar
Oddometer: 226
Thanks. I really like all of them. A bike for every purpose. Keep looking for that Wing. They are out there. Find a clean one, without a lot of crap on it and set it up for you. Take your time setting it up and ride it. The bike will be there, Wings that are taken care of last forever. You know that with your Valkyrie. You'll find out what you need and what you don't. Thats what I did with my 1500. It just plain works for me. Very comfortable, safe, user friendly, reliable bike. Looks good too, IMO.
4on3off
IBA#7849
Old 09-22-2011, 10:47 AM   #79
Guy Young
Guy Young's Avatar
Oddometer: 7,763
Originally Posted by mngl1500 View Post
The stock alternator is failure prone. In 1995 HITACHI moved their manufacturing from JAPAN to CHINA, since then they have been producing bad alternators. Broken rotor windings or burned up rotor coils from inferior wire and insulation. Replace it with a compufire or get a quality rebuilt one. Depending on how much electric clothing you also have the stock alternator is under powered.
I think I may be getting a Wing ('08?) in the shop next week that needs the stator replaced. He already has the part, so suspect it's an OEM version and subject to failure too.
He rides year round if the roads are clear of snow, sometimes 2-up, so I know the system is probably cranking out the watts for two heated vests/jackets, gloves, grips, etc.
I'll see if I can talk him into trying to return the original (assuming still in plain brown wrapper), and opt for a Compufire.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/G...11686385_YA8pi
Guy Young is offline   Reply With Quote
Old 09-22-2011, 11:51 AM   #80
Guy Young
Guy Young's Avatar
Oddometer: 7,763
True cartridge front fork conversion
My friend with an 1800 seems to think there is a true cartridge conversion front fork system available for this bike. The only things I have seen are the emulators from someone like Race Tech:
http://www.racetech.com/page/id/58
Is there something else out there I haven't heard about??
Old 09-22-2011, 02:05 PM   #81
BigChris99
BigChris99's Avatar
Oddometer: 226
Guy, If your friend with the 1800 is riding year round and running heated gear and extra lights and such, Compufire is the way to go. I've had one on my 1500 for years. No problems. I have a gauge on my bike, and with the Hotgrips on, electric vest and Tulsa lights on, it stays in the green. He will need a sealed battery such as an Odessy to go with the higher output of the Compufire. As for the front forks on the 1800, you need someone else to chime in. I have Progressive front and rear on my 1500 and am happy with that set up.
4on3off
IBA#7849
Old 09-22-2011, 04:33 PM   #82
richarddacat
high on honeysuckle
richarddacat's Avatar
Oddometer: 2,631
Some folks in Woodstock, GA;
http://www.traxxion.com/goldwingforks.aspx
* 05FJR/74R90s *
If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles.
richarddacat is offline   Reply With Quote
Old 09-23-2011, 02:41 AM   #83
Guy Young
Guy Young's Avatar
Oddometer: 7,763
Thank you, and I have passed this along to the owner. Bet this installation ain't cheap, but I have asked him for all the information on their form so we can, at least, get a quote.
Best.
Old 09-23-2011, 02:34 PM   #84
The PacRat
I'm that other guy
The PacRat's Avatar
Oddometer: 2,126
Which is easier to work on (for general stuff) - 1200 or 1500?
If a hammer don't fix it, then it's an electrical problem.
The PacRat is offline   Reply With Quote
Old 09-23-2011, 07:12 PM   #85
BigChris99
BigChris99's Avatar
Oddometer: 226
For general stuff, they are both about the same. Oil changes are easy, you can get a wrench that slides over the oil filter, so on the 1500 you dont have to remove the bottom cowel, even though the book says to. Getting to the battery is easy too. Pop off a side cover and there it is. Air filter on the 1500 is a major PITA, but doable, just takes time. The problem is that older plastic gets very brittle, and you have to be very careful when you take it off and put it back on. I broke a nipple on a side cover and had to have it plastic welded. Still, they are both coverd in plastic, so it takes some time and patience to work on a Wing. Totally different mindset than say working on my KLR or a Sportster for example. The good news is that they don't need " major " work very often. Another good thing is that if you need to know how to do something, someone somewhere has done it already and there is a wealth of information out there.
4on3off
IBA#7849
Old 09-23-2011, 10:28 PM   #86
beechum1
beechum1's Avatar
Oddometer: 4,944
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
just FYI, on the 1200, the OEM crankshaft oil seal under the timing belt cover is discontinued. My friend made me a 59mm OD 55MM ID sleeve to put in, and we got a 55mm OD oil seal from one of his vendors to change it out because it started leaking.
If anyone else runs into this problem, Let me know, i'll get a sleeve made for you and mail it out.
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 05-01-2012, 11:36 AM   #87
LukeMacPU
LukeMacPU's Avatar
Oddometer: 243
New to me GL1100 Standard
My dad has graciously donated his trusty GL1100 to me. I've been playing around with restoring a '75 Z1 that spent the last decade in storage. The Z1 runs, but isn't exactly a smooth or practical machine.
In any event, my dad is getting an upgrade and I get his '83 GL1100 with just over 23K miles. Bike looks good and runs super smooth. I'm looking forward to it, though I doubt I do much off-road with this one!
Any tips on locating a passenger backrest for the GL1100 standard? I keep seeing them on bikes in pictures, but I've not had much luck finding one. The Mrs. really doesn't enjoy riding without a sissy bar.
ABIDE
'83 GL1100 Naked - silky smooth (the bike, not me)
LukeMacPU is offline   Reply With Quote
Old 05-01-2012, 05:20 PM   #88
WhatThaFrig
WhatThaFrig's Avatar
Oddometer: 247
Here's an updated pic of my 82. Done for now until winter. Just gonna ride!
"Life is hard! It's even harder when you're stupid!"
John Wayne
Not all who wander are lost!
1982 GL1100 Standard
1980 GS550
WhatThaFrig is online now   Reply With Quote
Old 05-01-2012, 06:59 PM   #89
Ultra54
Ultra54's Avatar
Oddometer: 142
Wow...that is nice...!! I owned a bone stock 80 Interstate and now ride a sweet 86 Aspencade.
Ultra54 is offline   Reply With Quote
Old 05-01-2012, 07:26 PM   #90
lake_harley
Oddometer: 616
What kind of paint did you use on the pipes, BBQ Paint maybe? They look to be stock pipes without the "tailpipes" and front shields. Any info you might share about how you prepped the previously chrome pipes and how it's holding up?
Cool looking 'Wing! Superbike bars??
Lynn
lake_harley is offline   Reply With Quote
Times are GMT -7.   It's 03:38 AM.
