Old 08-12-2011, 05:40 PM   #616
GreaseGorilla
GreaseGorilla's Avatar
Oddometer: 415
Wicked
A few years ago, while fishing with a friend of mine in the UK at Dovecote lakes in Milton Keynes we were surprised by a very bad and cold night........
our flashlights had run out, we had no candles and we were colder than hell.
I had packed some food, we were younger and foolhardier then, used to eat straight from the tin, none of this warm food up crap, so no stove also summer weight sleeping bags.
well we were below freezing and the tent was colder than a polar bears balls.... so i punched a small hole and a smaller hole also in a tin of tuna with oil, then stuffed a cotton wick in there with the aid of a knife,,,,,,, once said wick was saturated with the sunflower oil, i lit it, trimmed it, and the heat and light made the night a LOT more comfortable...... the cotton wick was the end 2" of a shoestring and the bonus was the next morning we got to eat the tuna.......... 2 for 1!
when i went for pee at 2am and came back into the tent the difference in temperature was amazing!
just thought i would share that one.....
GreaseGorilla is offline   Reply With Quote
Old 08-17-2011, 06:03 PM   #617
Kevinhooa
Pitch pine slalom
Kevinhooa's Avatar
Oddometer: 420
That beer can sleeve is pretty slick. I've always just put the beer into a red cup or used a ginger ale soda bottle.
On another note, I was helping a friend change out the fork seals on his Magna. The snap rings were rusted in there pretty good and my ring pliers were just not up to the task and wanted to bend (don't worry, we tried the penetrating fluid and the whole 9). So I put the plier nubs into the ring holes, and then squeezed the teeth together with another pair or pliers. Got the rings to pop right out.
There seems to be less and less garden in this state.
Kevinhooa is offline   Reply With Quote
Old 08-18-2011, 08:59 AM   #618
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,368
Tow strap for broken dog bones
Broke the suspension bones on my BMW F650 Dakar in Death Valley this winter. Stuck about 50 miles from camp, so I used the tow strap I always carry to lash them together.
The rope wrapped around it was probably unnecessary, but who knows. Rode the bike on a rough dirt road for 15 miles and the highway back to camp.
Luckily I had a spare set in my tool box and kept riding.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 08-19-2011, 10:08 AM   #619
troidus
Oddometer: 15,300
Not my MacGyver moment, but one I witnessed back in 1980 or so was similar. Two guys rolled into a NAPA in an early 70s Impala, needing a U-joint for said Impala. They'd had a couple of failed attempts at getting the right part, so they made a temporary joint out of baling wire so they could pull the joint out to match it physically, yet still be able to drive down the road to go buy it.
troidus is offline   Reply With Quote
Old 08-22-2011, 01:28 PM   #620
danfrit
danfrit's Avatar
Oddometer: 5
Originally Posted by Transalp Jas View Post
THe superglue and floss is a VERY interesting idea- even better if it works.
not exactly that, but same principle: I was away for a weekend of downhill mountain biking when I crashed and put a huge crack in my helmet's visor (just the visor, the rest of helmet was unscathed). The mountain didn't carry TLD stuff, so sanded the underside if the visor, I mixed a little epoxy from the toolbox and used a 4x4 gauze pad to "glass" it back together. When i got home i found out i couldn't get another visor in the same color scheme, and have been rocking that one ever since.
danfrit is offline   Reply With Quote
Old 08-26-2011, 07:48 PM   #621
ptero
ptero's Avatar
Oddometer: 540
Going back to the posts about breaking beads... Sorry if I missed it, but didn't see any posts about this... Many years ago I had heard of breaking a bead using a second bike's sidestand. Then I had a chance to try it - on a trip w/friends. It was the rear off a 93 Kbike at the time.
I had a flat in front of the Lincoln Memorial at the huge bus loading area. Tried plugs but it wouldn't hold air w/even multiple plugs longer than a half-hour. That got us to a friend's house at least. We pulled the wheel and lined up a friend's bike next to the wheel on the ground. It took a couple people to lean the bike right to raise the sidestand high enough to get the wheel w/flat under it.
Then we leaned the weight of the bike on the rubber, just missing the rim itself. It popped pretty easily. Snazzy. No real MacGuyvering, but a great solution.
Since the only tire available in this garage was a slightly used GS tire, that bike forever became my 93 K1100GS! It fit fine and ran fine - loved it.
Team Pterodactyl
Logistics and Tats
Midwest Command
Ride Hard or Stay Home
ptero is offline   Reply With Quote
Old 08-31-2011, 05:58 PM   #622
arcanum
Oddometer: 317
Cheap tire spoons
A perfectly useable tire spoon is the small Harbor Freight brake adjusting tool made for drum brakes. I bought 5 of them at $1.10 per each. Yes,I tried the zip tie and other methods,but I keep going back to using spoons for my narrow rims.
Simply drill the tool in the appropriate spot and use a string or wire to hold it to a spoke...
arcanum is offline   Reply With Quote
Old 08-31-2011, 07:07 PM   #623
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Hit a rock with the right valve cover of my old GS. Oil was leaking out and I was far from anywhere. My friend had a piece of foam rubber that we wedged up against the hole. It kept the oil in to got me 100 miles home.
A lot of other things would work you just have to have them with you.
Bead breaking
http://www.advrider.com/forums/showthread.php?t=145079
Fast way to inflate your tire.
scooteraug02 is offline   Reply With Quote
Old 08-31-2011, 07:24 PM   #624
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,360
Lots of people do it (I use starting fluid), but be VERY CAREFUL.
WARNING: Most things posted above contain sarcasm.
Daamud is online now   Reply With Quote
Old 09-01-2011, 04:38 PM   #625
tomdubz
getting there
tomdubz's Avatar
Oddometer: 517
spin off OF
Couldn't find my oil filter wrench 'cause I'm a slob. So, I made it sticky with some double sided tape, wrapped my belt around it a few times, and pulled it like the lawnmower. The best part was when it spun off entirely and splashed down into the pan pool. Good times in the driveway.
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 09-02-2011, 07:49 PM   #626
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,652
Using my KTM tool kit to fix a Buell shifter linkage that broke.
Yes it worked, in fact it worked so well it was used for a full week after I made it until we had the parts to fix it.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 09-11-2011, 03:01 PM   #627
(none)
poser
(none)'s Avatar
Oddometer: 2,624
from the looks of it, thats a split rim wheel, big different from what is commonly used today.
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 09-21-2011, 03:59 PM   #628
broncobowsher
broncobowsher's Avatar
Oddometer: 1,731
I was thinking that it was a widow maker split rim. You can see the rim seperating when it blows.
My worst starting fluid tire seating incident was reseating a itty bitty trialer tire that was dry rotted and been off the bead for who knows how may years. Spray, light, pop, add air. First 3 went OK, adding air resulted in a few little blow torches of fire shooting out between the bead and the tire for a few seconds. My guess is the tire finally melted onto the rim sealing it (it held air when done), but the flames shooting out while putting air in were spooky. Good thing I had a good pair of gloves on when doing it.
broncobowsher is offline   Reply With Quote
Old 09-21-2011, 07:00 PM   #629
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,360
I had a set of Super Swamper tires seat fine, but the air inside would cool quicker than I could put air in, sucking the tire back off its bead.
Ended up pushing the rim to one side of the tire and filling the void on the other side with grease. Then just filled with air. It worked fairly well.
Old 09-21-2011, 07:45 PM   #630
scmopar
scmopar's Avatar
Oddometer: 248
a ratchet strap arond the outside of the tire works good too also a tire tool twisted into the strap gets that little extra omp to get the bead to touch the rim
It was no time for supineness and lamentation - every energy of the soul had to be exercised, -Tarleton Brown
scmopar is offline   Reply With Quote
Times are GMT -7.   It's 11:30 AM.
