Old 09-22-2011, 10:45 PM   #781
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,441
990 Adventure wheels on a 950 Super Enduro?
Guys,
Will the OEM wheels from a 990 Adventure work on a 950 SE? I know
- the wheel diameters are the same
- the right front rotor *may* have to be removed.
What about axle diameters/lengths and spacers? I think it might work after reading this thread:
http://www.advrider.com/forums/showthread.php?t=621198
Has anybody actually put Adventure wheels on the SE? I have an opportunity to pick up a set cheap.
TIA
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney screwed with this post 09-22-2011 at 11:18 PM
DangerMoney is offline   Reply With Quote
Old 09-22-2011, 11:10 PM   #782
WARRIORPRINCEJJ OP
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,746
Originally Posted by DangerMoney View Post
...Has anybody actually put Adventure wheel on the SE? I have an opportunity to pick up a set cheap.
TIA
I'm almost positive that Mike (Brown Dog) has a rear Adventure rim, on his SE.
You know they're soft as shit...right?
They don't even come close to your DirtStars...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 09-22-2011, 11:16 PM   #783
DangerMoney
Oddometer: 1,441
That's OK as I would shod them with tires more street-oriented for street use. My DirtStars are shod with full knobbies.
Old 09-23-2011, 04:28 AM   #784
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
I have adventure rims on my SE with scorpions that I use for the roads. Dirt stars have the knobbies. I have just one front disc installed and use the the SE front wheel spacers. Back tire cost more because it is wider.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 09-23-2011, 06:25 AM   #785
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,940
Originally Posted by Xmoto View Post
I have adventure rims on my SE ...
I have ADVenture Rims laced to my SE hubs.
+1 on the looks
BUT . . . . . . the wide rear catches Everything on the trail with it's Width
I Always keep aired above 34psi to not bend a rim.
The Stock Rims are Mucho better for Off-Roading as JJ mentioned
Brown Dog screwed with this post 09-23-2011 at 06:33 AM
Brown Dog is offline   Reply With Quote
Old 09-23-2011, 07:02 AM   #786
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 841
adv rims
I have a set of adv hubs set up with 19" front, stock 18" rear,converted to tubeliss. just need to run SE spacer's and alls good
dogsslober is offline   Reply With Quote
Old 09-27-2011, 04:09 PM   #787
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
OK this question is for the people who have done the vacuum fuel pump conversion. I put the pump on top of my air box and tee into the crank case breather hose. Everything was fine for about a month then the bike died on me and barely kept running to make it home. I took the pump apart and there was water on the vacuum side of the diagram, I guessed it was condensation from the engine breather. I switched to the rear cylinder and put the fitting with the larger ID on the left and plug the hole on the right with a bolt. The bike runs fine but is hard to start now. In the past in the morning I would pull the choke lever and she would fire right up. Now I have to crank it a lot to get in running. Not as bad when it is warm but still not the same. Anyone have any ideas.
Old 09-27-2011, 06:56 PM   #788
Qwik
Adrenaline Addict
Oddometer: 6,539
I have my Vac pump mounted under the engine (on a 950ADV) and havent had any issues with it. I dont know if the higher mount makes a difference. I would not think so but I could be wrong. You may still have moisture in the line too.
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 09-27-2011, 07:44 PM   #789
DangerMoney
Oddometer: 1,441
+1 on the looks
Are both of you running the standard size ADV rear tire (150/70-18)? Any problms with the tire rubbing up against the chain/swingarm/etc?
Old 09-28-2011, 03:53 AM   #790
1SEinRo
1SEinRo's Avatar
Oddometer: 26
Hi guys,
I have a bit of a problem with a 950 SE. The bike stayed in a garage for some long time (more than 6 month) without running at all and now, there are two issues:
1. I can start it once and after that the starter relay just makes noises but engine will not start until I charge the battery again....
2. I can start the bike with the choke at 1/2 but when I am trying to close the choke (to idle position) it stalls.
Please give me some inputs if you run into this specific behaviors.
1SEinRo is offline   Reply With Quote
Old 09-28-2011, 04:30 AM   #791
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Yes that is the tire. No problems.
Old 09-28-2011, 04:32 AM   #792
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Originally Posted by 1SEinRo View Post
Hi guys,
Sounds like you might need a new battery.
Old 09-28-2011, 05:05 AM   #793
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,266
+1
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 09-28-2011, 11:51 AM   #794
1SEinRo
1SEinRo's Avatar
Oddometer: 26
Agree with the battery solution, but what about the other issue. To add some info: when I try to give it some gas after I started it with the choke, it stalls also...
Old 09-28-2011, 11:53 AM   #795
exhaust_nut
exhaust_nut's Avatar
Oddometer: 190
Clogged jet?
exhaust_nut is offline   Reply With Quote
Times are GMT -7.   It's 11:35 PM.
