Old 10-05-2011, 08:40 AM   #55081
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,799
Eek
Originally Posted by Al Tuna View Post
Why... sprinkle yourself with a dose of common sense and spread the callapers...
why not sprinkle yourself with a dose of reading comprehension and take another look at the OP's post?
OP, unbolt the rotor from the wheel and fit it up. that's what i had to do to mount the KX wheel.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 10-05-2011, 09:19 AM   #55082
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
TCI Products Skid plate
Has anyone used TCI Products skid plate? I like the side engine guards.
https://tciproductsusa.com/index.php...roducts_id=569
Has it held up good? Is it easy to R&R? Worth the money?
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 10-05-2011, 09:22 AM   #55083
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
That is frickin expensive. Is it gold plated. I have the procycle one and it covers almost as much as that TCI one. At only $80.
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 10-05-2011, 10:09 AM   #55084
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Corbin or Sargent for on-road only?
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-05-2011, 10:14 AM   #55085
vintagespeed
fNg
Oddometer: 1,799
how much are all the engine covers that have to be added to that $80 for the same protection?
that TCI might have saved my shift lever this weekend...
Old 10-05-2011, 10:54 AM   #55086
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
both are good
sargent is 1" taller.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 10-05-2011, 11:18 AM   #55087
dfishman
dfishman's Avatar
Oddometer: 173
Stock shock?
Anybody that has upgraded the rear shock on their Dr have the stock one for sale.My buddy is in need.He got a DR about 6 months ago that had been sitting for 2 years here on Hatteras Island.The salt air pitted the shaft & it is done.
E-mail bigeyefish@msn.com
dfishman is offline   Reply With Quote
Old 10-05-2011, 11:22 AM   #55088
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Maybe right. Case armor (which is sweet stuff), skid plate and spare shifter lever (which I always carry). All total about $180 from procycle. I don't know. The TCI thing may be the way to go, just seems a little high when you can get good protection and can include spares of stuff and still save $75
Old 10-05-2011, 11:38 AM   #55089
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Harley Beemer View Post
Yes, the spacer is still inside the hub between the wheel bearings. Ran the bike on my stand last night with bike in second gear. Rim looks true. Bearings and Cush hub are all tight. Tire is mounted true on the bead...........tire itself looks like it is lopsided!!!
What the he'll?
It's pretty rare ... but out of round or lop sided tires do happen on occasion.
Double check to make certain the tire is fully seated into the rim. Sometimes you need over 60 PSI to have it "Pop" and fully seat.
What kind of tire is it?
Old 10-05-2011, 11:42 AM   #55090
Adv Grifter
Oddometer: 6,128
Both seats get good reviews here on this thread. I have a Corbin and it's good ... but I have no doubt the Sargent is probably just as good. Comfort and ergos are subjective. I'd ride a couple bikes with these seats and decide.
Old 10-05-2011, 11:52 AM   #55091
discoganya
discoganya's Avatar
Oddometer: 196
Is there any recommended interval to change (not just clean) the air filter on a 2005 DR650SE? I have 22,000 miles now and I'm not sure if the previous owner has ever changed the filter.
Any recommendations for 90% street 10% dirt?
Stock ($45)
Twin Air ($31)
Uni (25)
K&N ($47)
No-Toil ($22)
discoganya is offline   Reply With Quote
Old 10-05-2011, 12:05 PM   #55092
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
What the he'll?
Ride it for an hour at about 16psi. Get some heat into it and then see what it looks like.
Sometimes they're deformed by the way they're strapped when shipped.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 10-05-2011, 12:07 PM   #55093
Adv Grifter
Oddometer: 6,128
Stock ($45)
Twin Air ($31)
Uni (25)
K&N ($47)
No-Toil ($22)
Good idea to change it out. Filter foam tends to crumble and begin to fall apart after years of use. As it breaks down, little particles can get sucked into carb as foam softens and dissolves.
The stock Suzuki filter probably is the longest lasting of the foam filters ... but for an '05, if original, I'd change it. I've had great luck with both UNI and Twin-Air filters. Not so much with K&N, which flow lots of air but let by some fine dirt. The Twin-Air and UNI flow a bit more air than the stock Suzuki filter.
Old 10-05-2011, 12:07 PM   #55094
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Replace when it starts falling apart.
Any filter will do but I really like the TwinAir.
I alternate between a stock 2001 and TwinAir filters.
DR650 Wiki
Old 10-05-2011, 01:01 PM   #55095
planemanx15
Oddometer: 1,009
Maybe someone on here has the same dimensions as me, I'm 5'8" 180 lbs, 30" inseam... There aren't many dr650's around these parts to go test seats :(
Times are GMT -7.   It's 09:39 AM.
