Old 10-05-2011, 01:47 AM   #55156
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,788
Originally Posted by B1 View Post
no worries! if you have the cash then the procycle motard wheels for the DR650 look like good value at $1200.
I got my 19" excel front for my last DR from them. Great people, and turned the bike into an extra hell of a good time
2012 Triumph Bonneville
2006 Suzuki Vstrom 650
and 19 Others...
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 10-05-2011, 03:24 AM   #55157
epix1718
epix1718's Avatar
Oddometer: 537
Tried putting on my supermoto wheels last night, is there a trick of getting the darn front caliper inside the wheel!?? I'm using the EBC 320mm rotor kit with adapter which is mounted on the fork, but it's almost like I can't fit the caliper between the rim and rotor when I try to put the wheel on.
97 Suzuki DR650
97 Ural Sportsman 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200
www.drriders.com
epix1718 is offline   Reply With Quote
Old 10-05-2011, 03:27 AM   #55158
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,110
IIRC I ended up filing a small bevel onto the offending part of the caliper.
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780.
ADV8 is offline   Reply With Quote
Old 10-05-2011, 03:30 AM   #55159
Al Tuna
PUI Offender
Al Tuna's Avatar
Oddometer: 8,620
Why... sprinkle yourself with a dose of common sense and spread the callapers...
Southeast Weather Map
"I might as well keep going, there's no 'effing way I'm going back the way I came"
Moran Nation 21 Club.
Al Tuna is online now   Reply With Quote
Old 10-05-2011, 03:52 AM   #55160
ADV8
ADV8's Avatar
Oddometer: 2,110
Even with the (new) pads spread it is tight.
A small bevel makes it easy.
Old 10-05-2011, 05:07 AM   #55161
Harley Beemer
Harley Beemer's Avatar
Oddometer: 76
Originally Posted by asrvivor View Post
Are you sure you got the spacer inside the wheel in? The long one that goes inside the wheel bearings.
Yes, the spacer is still inside the hub between the wheel bearings. Ran the bike on my stand last night with bike in second gear. Rim looks true. Bearings and Cush hub are all tight. Tire is mounted true on the bead...........tire itself looks like it is lopsided!!!
What the he'll?
13' KTM 500 exc
06' Suzuki DR 650
09' Genuine Blackjack
08' KTM 300 xcw
Harley Beemer is offline   Reply With Quote
Old 10-05-2011, 05:19 AM   #55162
Al Tuna
PUI Offender
Al Tuna's Avatar
Oddometer: 8,620
What the he'll?
It's you ... You fucked up! The tire ant' seated right.
Old 10-05-2011, 05:39 AM   #55163
Harley Beemer
Oddometer: 76
Tires mounted and balanced by Cycle Gear out West here.
Not sure if they use an actual high speed balancer or not........but that makes sense to me although the tire looks perfect around the bead. No visual clues.
13' KTM 500 exc
06' Suzuki DR 650
08' KTM 300 xcw
Old 10-05-2011, 06:05 AM   #55164
Al Tuna
PUI Offender
Al Tuna's Avatar
Oddometer: 8,620
Take it back. somethings not right.
They never use anything but Fred Flintstone balancing.
Talk to Wilma and smile...
Old 10-05-2011, 07:41 AM   #55165
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Ya that's weird. I think trying a different tire might be the only option. Problem is you now have spacers that are messed up. Gonna have to replace them if they are too bad. Procycle in Eugene Oregon can get all that crap. The spacers aren't cheap though. $23 bucks for number 19.
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 10-05-2011, 08:40 AM   #55166
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 797
Eek
why not sprinkle yourself with a dose of reading comprehension and take another look at the OP's post?
OP, unbolt the rotor from the wheel and fit it up. that's what i had to do to mount the KX wheel.
2006 DR650SE, daily commuter + a StripleR
and a bunch of 2 strokes that you dont want to read about. :)
http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 10-05-2011, 09:19 AM   #55167
CHRIS_D
CHRIS_D's Avatar
Oddometer: 640
TCI Products Skid plate
Has anyone used TCI Products skid plate? I like the side engine guards.
https://tciproductsusa.com/index.php...roducts_id=569
Has it held up good? Is it easy to R&R? Worth the money?
2011 Victory Cross Country
2006 Suzuki DR 650
CHRIS_D is offline   Reply With Quote
Old 10-05-2011, 09:22 AM   #55168
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
That is frickin expensive. Is it gold plated. I have the procycle one and it covers almost as much as that TCI one. At only $80.
Old 10-05-2011, 10:09 AM   #55169
planemanx15
planemanx15's Avatar
Oddometer: 746
Corbin or Sargent for on-road only?
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb.
1985 Yamaha CA50 - My Hot Rod
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-05-2011, 10:14 AM   #55170
vintagespeed
fNg
Oddometer: 797
how much are all the engine covers that have to be added to that $80 for the same protection?
that TCI might have saved my shift lever this weekend...
Times are GMT -7.   It's 11:30 AM.
