Old 10-05-2011, 09:22 AM   #55081
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Originally Posted by CHRIS_D View Post
Has anyone used TCI Products skid plate? I like the side engine guards.
https://tciproductsusa.com/index.php...roducts_id=569
Has it held up good? Is it easy to R&R? Worth the money?
That is frickin expensive. Is it gold plated. I have the procycle one and it covers almost as much as that TCI one. At only $80.
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 10-05-2011, 10:09 AM   #55082
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Corbin or Sargent for on-road only?
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-05-2011, 10:14 AM   #55083
vintagespeed
fNg
Oddometer: 1,855
how much are all the engine covers that have to be added to that $80 for the same protection?
that TCI might have saved my shift lever this weekend...
vintagespeed is offline   Reply With Quote
Old 10-05-2011, 10:54 AM   #55084
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
both are good
sargent is 1" taller.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 10-05-2011, 11:18 AM   #55085
dfishman
dfishman's Avatar
Oddometer: 173
Stock shock?
Anybody that has upgraded the rear shock on their Dr have the stock one for sale.My buddy is in need.He got a DR about 6 months ago that had been sitting for 2 years here on Hatteras Island.The salt air pitted the shaft & it is done.
E-mail bigeyefish@msn.com
dfishman is offline   Reply With Quote
Old 10-05-2011, 11:22 AM   #55086
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Maybe right. Case armor (which is sweet stuff), skid plate and spare shifter lever (which I always carry). All total about $180 from procycle. I don't know. The TCI thing may be the way to go, just seems a little high when you can get good protection and can include spares of stuff and still save $75
Old 10-05-2011, 11:38 AM   #55087
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Harley Beemer View Post
Yes, the spacer is still inside the hub between the wheel bearings. Ran the bike on my stand last night with bike in second gear. Rim looks true. Bearings and Cush hub are all tight. Tire is mounted true on the bead...........tire itself looks like it is lopsided!!!
What the he'll?
It's pretty rare ... but out of round or lop sided tires do happen on occasion.
Double check to make certain the tire is fully seated into the rim. Sometimes you need over 60 PSI to have it "Pop" and fully seat.
What kind of tire is it?
Old 10-05-2011, 11:42 AM   #55088
Adv Grifter
Oddometer: 6,128
Both seats get good reviews here on this thread. I have a Corbin and it's good ... but I have no doubt the Sargent is probably just as good. Comfort and ergos are subjective. I'd ride a couple bikes with these seats and decide.
Old 10-05-2011, 11:52 AM   #55089
discoganya
discoganya's Avatar
Oddometer: 204
Is there any recommended interval to change (not just clean) the air filter on a 2005 DR650SE? I have 22,000 miles now and I'm not sure if the previous owner has ever changed the filter.
Any recommendations for 90% street 10% dirt?
Stock ($45)
Twin Air ($31)
Uni (25)
K&N ($47)
No-Toil ($22)
discoganya is online now   Reply With Quote
Old 10-05-2011, 12:05 PM   #55090
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
What the he'll?
Ride it for an hour at about 16psi. Get some heat into it and then see what it looks like.
Sometimes they're deformed by the way they're strapped when shipped.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 10-05-2011, 12:07 PM   #55091
Adv Grifter
Oddometer: 6,128
Stock ($45)
Twin Air ($31)
Uni (25)
K&N ($47)
No-Toil ($22)
Good idea to change it out. Filter foam tends to crumble and begin to fall apart after years of use. As it breaks down, little particles can get sucked into carb as foam softens and dissolves.
The stock Suzuki filter probably is the longest lasting of the foam filters ... but for an '05, if original, I'd change it. I've had great luck with both UNI and Twin-Air filters. Not so much with K&N, which flow lots of air but let by some fine dirt. The Twin-Air and UNI flow a bit more air than the stock Suzuki filter.
Old 10-05-2011, 12:07 PM   #55092
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Replace when it starts falling apart.
Any filter will do but I really like the TwinAir.
I alternate between a stock 2001 and TwinAir filters.
DR650 Wiki
Old 10-05-2011, 01:01 PM   #55093
planemanx15
Oddometer: 1,009
Maybe someone on here has the same dimensions as me, I'm 5'8" 180 lbs, 30" inseam... There aren't many dr650's around these parts to go test seats :(
Old 10-05-2011, 01:06 PM   #55094
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
I believe the sergeant can come lowered 1 inch. This might be good for you.
Old 10-05-2011, 01:27 PM   #55095
SprintST
SprintST's Avatar
Oddometer: 208
My DR has a really poor sense of balance and seems to lie down at the most inopportune times. It also has a serious case of overkill on case protection. My thinking is that if my bike lies down and the case gets pierced in the middle of nowhere the $75 savings would be of little consequence.
I first ordered and installed ignition, clutch and oil filter guards from Perry Gray only to find out that the Scorpion skid plate (with protective wings) that I'd also ordered to round out the protection package was no longer available for the DR. I settled on the TCI set-up because I like the side guards and I'm hoping to use them to mount up some highway pegs. After a quick look I'm thinking that moving the passenger pegs/bracket might even be a viable option.
The TCI engine guards got tested the other day when the bike tipped over in the driveway while I was working on it. The guard was scratched up at point of impact but that's it. I'm satisfied. TCI make a quality product. Expensive, but good stuff that bolts right on. It's just one of those things that I was willing to spend a bit extra on. I'll scrimp elsewhere so it all works out in the end.
"Let us never forget those who can't remember" [author unknown]
SprintST is offline   Reply With Quote
Times are GMT -7.   It's 06:36 PM.
