Old 10-05-2011, 01:06 PM   #55096
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Originally Posted by planemanx15 View Post
Maybe someone on here has the same dimensions as me, I'm 5'8" 180 lbs, 30" inseam... There aren't many dr650's around these parts to go test seats :(
I believe the sergeant can come lowered 1 inch. This might be good for you.
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 10-05-2011, 01:27 PM   #55097
SprintST
SprintST's Avatar
Oddometer: 208
Originally Posted by asrvivor View Post
Maybe right. Case armor (which is sweet stuff), skid plate and spare shifter lever (which I always carry). All total about $180 from procycle. I don't know. The TCI thing may be the way to go, just seems a little high when you can get good protection and can include spares of stuff and still save $75
My DR has a really poor sense of balance and seems to lie down at the most inopportune times. It also has a serious case of overkill on case protection. My thinking is that if my bike lies down and the case gets pierced in the middle of nowhere the $75 savings would be of little consequence.
I first ordered and installed ignition, clutch and oil filter guards from Perry Gray only to find out that the Scorpion skid plate (with protective wings) that I'd also ordered to round out the protection package was no longer available for the DR. I settled on the TCI set-up because I like the side guards and I'm hoping to use them to mount up some highway pegs. After a quick look I'm thinking that moving the passenger pegs/bracket might even be a viable option.
The TCI engine guards got tested the other day when the bike tipped over in the driveway while I was working on it. The guard was scratched up at point of impact but that's it. I'm satisfied. TCI make a quality product. Expensive, but good stuff that bolts right on. It's just one of those things that I was willing to spend a bit extra on. I'll scrimp elsewhere so it all works out in the end.
"Let us never forget those who can't remember" [author unknown]
SprintST is offline   Reply With Quote
Old 10-05-2011, 01:32 PM   #55098
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,428
Originally Posted by epix1718 View Post
Tried putting on my supermoto wheels last night, is there a trick of getting the darn front caliper inside the wheel!?? I'm using the EBC 320mm rotor kit with adapter which is mounted on the fork, but it's almost like I can't fit the caliper between the rim and rotor when I try to put the wheel on.
when i was mad about motards i ended up opting for 310mm discs where possible. no noticeable difference in braking power but that 5mm less radius made getting the caliper on a breeze. not much help on a DR650 as i think only the 320mm disc is available, but 310mm discs and caliper adapters are readily available for KTMs, drz400, wr450/250 etc.
B1 is offline   Reply With Quote
Old 10-05-2011, 02:22 PM   #55099
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,799
i'm the same size, 5'9 on a good day though, and i love my Seat Concepts seat! i commute every day (except for yesterday & today due to rain.. :( ) and i love it. no longer does my rear ache.
Originally Posted by NordieBoy View Post
Replace when it starts falling apart...
i agree, but i'd add that the poster should check the condition of the stock filter. mine has shrunk and was lifting at the far corner letting dirt by. i added some wire around the filter foam to hold it to the inner support to keep it from pulling away and not sealing.
i think it shrinks a little with age, like me.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 10-05-2011, 02:56 PM   #55100
nzrian
nzrian's Avatar
Oddometer: 362
Hello all, I was doing the nsu check last night on my 2009 dr650 with 4000 km, and found that the bolts were Allen head from factory
Not sure if this has been brought up before should make checking a lot easier
If you don't know where you are going, any road will get you there.
-Lewis Carroll.
nzrian is offline   Reply With Quote
Old 10-05-2011, 02:59 PM   #55101
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,187
After picking my DR up a week or five back my friends been so impressed he's been on the look out for one !!! anyway he got one 1996 with 38k km on the clock for 1200 and in mint condition.................just one small problem at very low speed it's a little lumpy !!! feels like it's lacking gas !!! Any ideas ??????
Cheers Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 10-05-2011, 03:22 PM   #55102
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,516
Cheers Phil
The tiny filter that's in the fuel inlet. You have to pull the gasline off the carb to find it. It's inside the brass inlet. Pull it out and clean it. I tossed mine out and put an inline filter in the fuel line.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-05-2011, 03:31 PM   #55103
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,127
Well, I am 5' 8", but more in the 215lb range . I have the Corbin seat and love it. I couldn't ride the stocker for more then 40-50 miles at a time. The Corbin I can go till the gas runs out. It is narrow in the front for standing then wider in the back for comfort. I have stiff springs on mine so even with my weight the bike doesn't sag much when I sit on it. I can't flat foot...but it doesn't bother me.
Mongle is offline   Reply With Quote
Old 10-05-2011, 04:45 PM   #55104
drsmiley
drsmiley's Avatar
Oddometer: 253
Thumbs up on getting rid of the tiny filter in the carb inlet. I also put me a in line filter in.
drsmiley is online now   Reply With Quote
Old 10-05-2011, 05:17 PM   #55105
doug s.
Oddometer: 1,348
Corbin or Sargent for on-road only?
the first one that comes up used for a good deal. if you go w/a corbin, be sure it fits your tank; the sargent is supposed to fit any tank. another option would be to get a seat concepts or procycle kit to refurb the stock seat; awailable from procycle.com
doug s.
doug s. is offline   Reply With Quote
Old 10-05-2011, 05:19 PM   #55106
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
doug s.
If you have the duckets you can send your seat in to procycle and get $75 towards another seat. All they are doing is refabbing your seat when you send it back and reselling it. They will give you a credit towards another for yours.
Old 10-05-2011, 06:14 PM   #55107
UberKul
UberNoob
UberKul's Avatar
Oddometer: 113
Originally Posted by CHRIS_D View Post
Has anyone used TCI Products skid plate? I like the side engine guards.
https://tciproductsusa.com/index.php...roducts_id=569
Has it held up good? Is it easy to R&R? Worth the money?
Have not seen/used one in person but my only concern would be if an otherwise simple slide/impact would bend the mounting tabs and generate a single impact point directly into the side case? Otherwise they look very stout and BMWish.
My Smugmug, it's how I roll.
UberKul is offline   Reply With Quote
Old 10-05-2011, 06:29 PM   #55108
doug s.
Oddometer: 1,348
you still need case armor, at least on the left side; imo - nothing to stop the gear shift lever from hitting the case... my bike is street only; i need to get some case armor...
doug s.
Old 10-05-2011, 06:38 PM   #55109
ER70S-2
ER70S-2's Avatar
Oddometer: 6,880
Someone was complaining about how much disassembly was necessary to remove the oil filter with the TCI set-up. He wasn't very happy.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-05-2011, 07:08 PM   #55110
lonewolf97
lonewolf97's Avatar
Oddometer: 2,395
Lonewolf97
I put led turn signal lites on my 97 dr 650 now all 4 lites blink fast when I try right or left. got the lites from Virtual village .com I don't want to add resisters. is there a relay kit that works?
lonewolf97 is offline   Reply With Quote
Times are GMT -7.   It's 05:32 AM.
