Old 10-05-2011, 08:13 PM   #55111
shu
Oddometer: 1,073
Originally Posted by Harley Beemer View Post
Kenda 270 tire.
Looks fully seated all the way around the rim on both sides? Could it still need seating?
No....usually there's a little raised rubber ring on the tire near the wheel. If that ring is evenly spaced from the rim all the way around on both sides the tire is seated correctly. Run your finger all the way around on that ring and make sure it's seated evenly.
If it still looks misshapen there's something else going on with that tire.
......shu
shu is offline   Reply With Quote
Old 10-05-2011, 08:15 PM   #55112
shu
Oddometer: 1,073
Went for a 4 day Fall ride- it's going to snow here soon, so I wanted to get up high before it does. Hope you guys don't mind if I post a Mini Ride Report featuring my DR here.
Jones Pass
Hmmm..........seems to be a little DR sized space there to the left. I'll never tell about the somewhat steep rocky road behind the sign, though. My lips are sealed.
Lots of beetle killed trees in Colorado now. Some of them are being harvested but most will just fall down and rot.
Colorado's Fall Colors- Spectacular to ride through.
Quiet lonely tracks.
Down low, nice and sunny...
Up high......the storm's moving in on Ptamigan Pass. Time to move on.
...........shu
Old 10-05-2011, 09:05 PM   #55113
TrophyHunter
Oddometer: 2,305
Thx Shu!!! Good to see it out in it's environment.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 10-05-2011, 09:12 PM   #55114
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,993
Originally Posted by lonewolf97 View Post
I put led turn signal lites on my 97 dr 650 now all 4 lites blink fast when I try right or left. got the lites from Virtual village .com I don't want to add resisters. is there a relay kit that works?
Superbrightleds.com has a flasher kit. You can replace the flasher module under the seat. Then either pull the dash bulb or install the kit Dennis Kirk sells to make the dash light work. Good luck. There is an abundance of info on this topic in this thread. You just have to search for it.
Sent from my SCH-I500 using Tapatalk
"I go where the voices in my head tell me to!"
2012 KTM 990 ADV- "Annika"
2007 KTM 250XCF- " Viktoria"
Grizz Adams is offline   Reply With Quote
Old 10-05-2011, 09:17 PM   #55115
SprintST
SprintST's Avatar
Oddometer: 208
Help me decide - Bring camping gear or not?
I'm currently in Des Moines Iowa, a thousand miles from home in Ontario Canada on my way to Tierre Del Feugo wondering how much I'll use the camping gear I'm hauling along. I enjoy camping but the stuff takes up awful lot of room, not to mention the weight. One of the reasons I changed to a DR from a KLR is the lighter weight. Now I find myself loading up on the poundage again.
Accommodation costs in the U.S. are manageable in the short term (kinda) but how much would I really be camping once outside of the States? Safety is a concern since I'm traveling alone. I'm hoping to do some couchsurfing along the way and stay in motels and hostels in the cheaper areas.
For those of you who have already done Central or South America and taken camping gear along would you do it again or forego the camping altogether?
So, do I leave the camp gear at a friends and just enjoy the ride a lot more or what? HELP? Would love to hear other peoples take on my dilemma.
"Let us never forget those who can't remember" [author unknown]
SprintST is offline   Reply With Quote
Old 10-05-2011, 09:27 PM   #55116
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Originally Posted by nzrian View Post
Attachment 292846
Hello all, I was doing the nsu check last night on my 2009 dr650 with 4000 km, and found that the bolts were Allen head from factory
Not sure if this has been brought up before should make checking a lot easier
That doesn't sound right. Even 2010 bikes have had philips head screws.
NordieBoy is offline   Reply With Quote
Old 10-05-2011, 09:48 PM   #55117
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,476
nup. checked my 2010 DR a few weeks back and it had allens... they were nice and tight (as was scottl's 2003 DR we did at the same time, it had the usual phillips heads) but we did the usual slightly longer bolts, loctite, drilled and wired.
B1 is offline   Reply With Quote
Old 10-05-2011, 10:25 PM   #55118
TRAVELGUY
Old Traveler
Oddometer: 716
Having done that trip as far as the Panama border and now livng in Costa Rica I would leave the camping gear up north.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 10-05-2011, 10:34 PM   #55119
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,195
Originally Posted by Rusty Rocket View Post
The tiny filter that's in the fuel inlet. You have to pull the gasline off the carb to find it. It's inside the brass inlet. Pull it out and clean it. I tossed mine out and put an inline filter in the fuel line.
Cheers Rusty, the simple things ehhh !!!!!!!!!!!!!! i'd never have sorted it.
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 10-05-2011, 11:39 PM   #55120
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,010
In case anyone is looking for a change of pace.
http://advrider.com/forums/showthread.php?t=731183
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 10-06-2011, 01:22 AM   #55121
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
The one I checked had 2 loose philips screws...
Old 10-06-2011, 02:40 AM   #55122
CHRIS_D
CHRIS_D's Avatar
Oddometer: 969
Is the NSU the Neutral Sensor Unit? I think I'm getting the fact that the screws (allen or phillips) loosen up and this sensor falls off causing a nightmare. Does it just need some blue loctite and a good tightening or does it need its bolts changed also?
Next week I'm picking up a 2006, so I'm currently in the planning stages of getting it dirt worthy and reliable. Any other advice in this regard is highly appreciated.
And to think I use to think the KTM 690 thread was long!! So with that said, I'm sorry in advance for asking all these newbie DR questions .........
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 10-06-2011, 03:27 AM   #55123
nzrian
nzrian's Avatar
Oddometer: 410
i am 100% positive no on else has been into that clutch, still had all the blue paint on the bolts.
my bolts were nice and snug but loctited them anyway.
this is an aussie bike, i am second owner, the first owner used it to learn on, when he got his full license he "upgraded" to a cb 1300 or something like that.
His loss my gain.
Absolutely lovin the dr, what a weapon, the farkeling has begun!
If you don't know where you are going, any road will get you there.
-Lewis Carroll.
nzrian screwed with this post 10-06-2011 at 03:30 AM Reason: grammatically incorrect
nzrian is offline   Reply With Quote
Old 10-06-2011, 04:05 AM   #55124
newone
newone's Avatar
Oddometer: 2
Hi guys! I want to put 18 inch wheels on the back for winter driving, we have a large selection of tires of this diameter. Unfortunately we have hard to find a wheel assembly at a low price. Suitability for the DR wheels from other bikes?
newone is offline   Reply With Quote
Old 10-06-2011, 04:20 AM   #55125
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,966
after you sell or swap, would you mind writing up a comparison?
plugeye is offline   Reply With Quote
Times are GMT -7.   It's 05:47 AM.
