09-25-2011, 09:16 PM
#91 |
Here and There
Oddometer: 1,342
Great job Luke!!!! I was very impressed when I first saw the bike at the meet up last week, now i have found the thread to read along.
09-26-2011, 12:21 AM
#92 |
Oddometer: 6,888
I've kicked around the idea of converting my '89 JS440 JetSki to electric. One problem is that the whole system has to be waterproof, not just water resistant. Also, boats are constant load, so there is no coasting to save power, meaning that runtime will be an issue. It should run for at least 90 minutes, or it'll be disappointing. There should also be a "reserve", some smaller pack in the battery bank that will at least get it to shore if I misjudge and run out of juice in the middle of a lake.
09-26-2011, 07:56 AM
#93 |
sunshine and puppies
Oddometer: 28,982
Combining a backhanded compliment with spam. Well done.
Go Jane Go - Analog Jane and her three chamber heart www.scottconary.com | Oil & Piston : Motorcycle paintings and prints | The Punk's Bike |
09-26-2011, 08:07 AM
#94 |
Oddometer: 175
09-30-2011, 04:47 PM
#95 |
GPoET&P
Oddometer: 3,748
So it's been a while without any updates, so here's a little one.
I've been messing with the charging system; building the charger into a portable box, and doing a bunch of invisible fussing with the electronics. It's paying off- the same battery pack gives about 25% more range than it did before. There's also a fair bit to do to make the throttle response better; MX tires on wet rocks give a lot of wheelspin. ![]() The wooden box is the charger- it takes 1 hour to charge at home, 3 hours from the truck. With a bit more work it should be able to charge this sized pack in around 1/2 hour. For any more remote charging I'll get a generator. 3 hours is a long time to charge, especially when I have to keep my truck running. Here's the last run of the day. I got hung up on a root hole midway through and had to lift the back of the bike out- but it's so light that that's easy. And of course, the battery ran out right at the very end. |
09-30-2011, 05:21 PM
#96 | |
oneandahalfassed
Oddometer: 9,797
Gotta remember to ride up hill so you can coast back
Round Way Round, 2 months and several thousand miles on a WR250X |
09-30-2011, 10:44 PM
#97 |
Oddometer: 28,982
How is throttle control working out now that you've had it out in the woods?
09-30-2011, 11:44 PM
#98 |
Oddometer: 166
Saving weight
I read through the entire thread & didn't see anything about belt drives so I thought I would mention it.
Remember Harleys have belt drives so you should be able to find one somewhere close to what you need through Gates Belts or ?? It's not going to save you a whole lot of weight but it is rotating weight & should help out some when you get to that point. I can see you lightening up the cases that hold the batteries too, I know that wood fiberboard isn't light. Great job on the build though I like it. |
10-01-2011, 01:34 AM
#99 |
GPoET&P
Oddometer: 3,748
It works well as long as I'm moving. Not so well when I get stuck :) Then the back wheel really likes to spin up. That makes it hard to get moving again, and is probably wasting a lot of energy.
10-01-2011, 01:46 AM
#100 | |
GPoET&P
Oddometer: 3,748
I've been talking with a local guy with a similar project. He used a belt for the primary reduction and it has been giving a bit of trouble despite careful mechanical design and construction. My tape measure and cutting torch approach would not work at all with a belt. At this point I'm going to stick with the chain but would like to use a belt eventually for the noise benefit. As far as the battery packs, yes there is a lot of extra weight. The plastic isn't light either, and the cases and supports weigh nearly as much as the cells. That's not a big deal with these small packs, but for a bigger one it will be. |
10-05-2011, 11:15 PM
#101 |
Oddometer: 166
Is there a minimum distance that the batteries have to be seperated by ?
10-06-2011, 08:36 AM
#102 |
GPoET&P
Oddometer: 3,748
10-06-2011, 08:48 AM
#103 |
Oddometer: 28,982
Is there a ready solution for modulating the initial power ?
10-06-2011, 08:02 PM
#104 |
GPoET&P
Oddometer: 3,748
10-06-2011, 09:32 PM
#105 |
Racing Like a Noob
Oddometer: 4,279
What about making an electric vintage trials bike? Ever thought of that?
Racing a Subaru in the 2013 Mexican 1000 |
