10-01-2011, 08:54 AM
#91 | |
Oddometer: 2,820
Erling ebrabaek screwed with this post 11-08-2011 at 05:52 PM |
10-02-2011, 07:38 AM
#92 | |
Oddometer: 1,072
"I'd like to meet the joker who had the nerve to call this a road!" -- Walter Sigmann |
10-02-2011, 08:40 AM
#93 |
Oddometer: 1,072
Vacuum regulators
I'm looking for a decent vacuum regulator. I've found decently vacuum pumps at reasonable prices, and I'm going to build my own vacuum tanks: http://www.joewoodworker.com/veneering/whybuild.htm
(borrowed photo) ![]() But now I'm looking for an electro-mechanical valve that will cut off the pump when the vacuum hits about 25" Hg. Any ideas? I started trying to find a good regulator, but the only regulators I'm finding are really expensive at over $200, and that doesn't include a cutoff valve to shut the pump down when the pressure gets high enough: http://www.smcpneumatics.com/irv-series.html ![]() Maybe it's cheaper in the end to just buy a more expensive regulated pump? I don't know.
"I'd like to meet the joker who had the nerve to call this a road!" -- Walter Sigmann Orangecicle screwed with this post 10-02-2011 at 08:47 AM |
10-09-2011, 11:56 AM
#94 |
Oddometer: 2,684
Here's my finished project of a custom fiberglass, pop up camper on my Samurai.
10-09-2011, 08:09 PM
#95 | |
Groovinator
Oddometer: 2,396
This is really nice work. I can't wait to see the inside. Did you use foam as your mold? If so, where did you find pieces large enough? |
10-10-2011, 06:08 AM
#96 | |
Groovinator
Oddometer: 2,396
10-10-2011, 06:59 AM
#97 |
Oddometer: 2,684
10-22-2011, 07:38 AM
#98 |
Oddometer: 2,684
Hey Hick, what do you think of those pumps that work off of an air compressor? I have a decent compressor in my garage already.
11-08-2011, 04:54 PM
#99 |
lurk
Oddometer: 286
Finally gave it a try....
Post # 36 I printed it and was waiting til I actually got the bike running again before I messed with the sidebags. Plastic Enduro's that someone jigsawed an inside corner out of. I've never done any fiberglass work, didn't even know how to buy it. So I read the detailed instructions and gave it a try....unfortunately I was using Bondo gel resin, and it's boucoup thick. It did manage to plug the hole from the inside, but on the outside (which luckily won't show when it's mounted) I still ended up with a thick mess that I couldn't really smooth when 'wet', so I sanded it and went to Home Depot to buy the 3M version, which went on much more like your description.
http://flemsmith.smugmug.com/Other/M.../IMG3678-M.jpg Here's a pix of the rough dried fiberglass before any sanding or painting. (assuming I did the picture link properly). The green color is from the bondo resin, I can't see using that again. The main point is that I really do appreciate the great advice available on this site, For almost any topic! Thanks! roy |
11-09-2011, 09:18 AM
#100 |
Oddometer: 215
Here are a couple of tips:
Use large diameter shallow containers vs small diameter deep containers to extend the pot life of polyester resin. epoxy is less sensitive to this. You will get better results with spraying pva by not thining it and spraying with a non hvlp gun. The best pva gun I had was an old binks model 7. Tape down some heavy plastic over a table and lay your cloth flat to wet it out then pick it up and place it in the mold. On choped and thicker cloth pour/paint some resin on the plastic before placing the cloth on the table. Large pieces of pre wetted cloth can be transered to the mold by rolling or folding up the cloth to avoid streatching and distortion. Doing this will speed things up and can help reduce resin pooling in the bottom of your mold. Tap Plastics in California is a great resource for all things composite. their house brand of epoxy is very similar to system 3. In addition to the 3 hardeners having different working times the most important difference is they produce 3 different levels of stiffness. |
11-09-2011, 07:26 PM
#101 |
Groovinator
Oddometer: 2,396
Do you have this backwards? I am under the impression that the greater the surface area exposed to air, the shorter the pot life??
11-11-2011, 11:38 AM
#102 |
Flame Bait
Oddometer: 937
He might have been talking thermal runaway? Dunno.
11-11-2011, 02:33 PM
#103 | |
Oddometer: 215
I used to have my own pattern and mold business and before I had any employees large layups would get a bit crazy. I would mix resin and paint some on the mold then wet out a piece of cloth and fold it up and transfer it to the mold and un-fold it but not roll it out, then pre wet another layer and leave it on the table while I rolled out the first piece of cloth. I have never used a paint roller to apply resin, it is too slow. I aways pre-weted the cloth by pouring the resin on and then using a bondo spreader to move it around. When I mention rolling out the cloth I am refering to using a ribed metal roller to get rid of any air bubbles. All that I have written also applies to epoxy but the effect of using a shallow bucket on 40 minute epoxy is less than on polyester resin. You may be refering to high humidity reacting with epoxy resin and making it kick faster. I live in California and have no experiance with this so some one who does will have to chime in. |
11-11-2011, 04:47 PM
#104 | |
Groovinator
Oddometer: 2,396
11-11-2011, 07:30 PM
#105 |
Oddometer: 2,820
There are a lot of good user input in this thread. A subject that most books....dvd's or course's don't cover..... "The spills and thrills" But as with many people trying their own phase of work..... they venture out to try new things.....and all are not good.... and so it goes that mis information.... Or things that is not necessary the way things work correctly can be misinterpret, and discourage others that thought this is the way. So with all these different advises......available....I encourage all to test new methods ( wherever they are found) on a test batch of any kind.... Before moving onto the piece you are making.......as you are running a risk of destruction and failure...... Which to the newcomer can be detrimental. Many things work great...but perhaps not for each project... So that goes for every project.... Test your methods on a ....uuuummm test bed before moving on to your project...... That said.... Onward with the layups.....
Erling |
