Old 10-10-2011, 01:56 PM   #10321
mechahayai
Oddometer: 142
Africa on Ice
How was your weekend?
mechahayai is offline   Reply With Quote
Old 10-11-2011, 01:04 AM   #10322
Grumbleweed
Africa Twin UK
Grumbleweed's Avatar
Oddometer: 15
Warmer than yours it seems!! This was Dartmoor in Devon, UK
Grumbleweed is offline   Reply With Quote
Old 10-11-2011, 06:09 AM   #10323
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,997
First the TA, now Jim is selling off spares?
Is the BMW that compelling? Is Honda ownership about to be terminated? Will our hero be seduced by europeans?
Ladder106 is offline   Reply With Quote
Old 10-11-2011, 03:36 PM   #10324
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I've always had a foot in the old world. My roots are still there. I'm not selling all my Hondas, just the one to make my other one even better. I like my F800GS but it's my two-up ride compared to the AT. The GS as currently configured is way too heavy for any serious offroading as witnessed on this year's Big Dog ride. I only went down twice.
I'm in the mood for a 4-wheeled project anyway. Okay, it's a BMW 2002tii. Honda cars are kind of boring.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 10-11-2011, 04:22 PM   #10325
Ladder106
Ladder106's Avatar
Oddometer: 4,997
Ever tried a NSX?
Old 10-11-2011, 04:32 PM   #10326
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Ever tried a NSX?
Haven't come across an NSX project yet. My wallet is not that deep, especially with a senior looking at colleges.
My AT doesn't look like this anymore.
Jim Rowley
Black Forest, CO
Old 10-13-2011, 06:49 AM   #10327
Hectoe
Oddometer: 25
Originally Posted by Hectoe View Post
Yes, Youtube do not want to show the video in Germany, because of the music. I could upload the video to another service for you guys in Germany.
Hi German viewers. Can you see the video from here?:
Africa Twins in "The Fun Park" - For more of the funniest videos, click here
Hectoe is offline   Reply With Quote
Old 10-13-2011, 10:28 AM   #10328
ninety
Oddometer: 20
My AT after a day of fun !
https://picasaweb.google.com/lh/phot...eat=directlink
Chears,
Simon
ninety screwed with this post 10-13-2011 at 11:39 PM
ninety is offline   Reply With Quote
Old 10-13-2011, 10:16 PM   #10329
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,251
Bike died
Ok guys, went for a short ride to a bike night and never made it. Bike died like it was running out of gas, push starter motor cranks a few times like normal then dead. No poer at all as if battery has puked and is done. Can not get it to fire pushing it. Push bike to gas station fill with gas and hook to jumper cables bike turns over for a while before firing and then idles fine. Mount up ride toward the house no indicators or lights will work and bike dies completely a mile down the road.
I am pretty sure this is a stator issue or RR it is also called. What say you experts? I have not unload from my truck yet so have not checked anything.
My intention is to unload tomorrow night and then start with the battery and move to the stator and keep moving forward from there... sound good?
Reidy008 is offline   Reply With Quote
Old 10-13-2011, 11:28 PM   #10330
john_aero
john_aero's Avatar
Oddometer: 1,173
FUel pump buy any chance? only say this as if bike is turning over and does start but dies it sound sliek fuel starvation
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 10-14-2011, 06:14 AM   #10331
Ladder106
Ladder106's Avatar
Oddometer: 4,997
Likely the rectifier.
It sounds like you were running on only the battery. The jump and restart at the service station recharged the battery a bit and allowed enough to run.
Headlights quickly drain things back down again if there's no power coming in.
If it's daylight, pull the headlight fuses and the bike should run for quite a few miles (YMMV) if the battery is only powering ignition.
I say rectifier because that's the common problem. The actual problem is that electrical power is not being put into the bike from the stator that produces it.
So, the problem can be with the stator, the wiring, the connector plugs, the rectifier and so-on up the line.
Check easy stuff first:
(a) batter terminal connections and all "ground" connections.
(b) the 3-wire connector between the stator and rectifier
(c) condition of battery (will it hold a good charge)
(d) charge rate.....if you charge the battery and get the bike to run, measure voltage across battery terminals while bike is running at idle and then at about 4-5000 rpm (max. output).
We'll go from there............................
Old 10-14-2011, 08:11 AM   #10332
Reidy008
Reidy008's Avatar
Oddometer: 2,251
Cheers
Thanks will proceed as prescribed and let you kmow.
Old 10-14-2011, 02:41 PM   #10333
GSPD750
GSPD750's Avatar
Oddometer: 1,452
Good advice by Ladder. How old is your battery. It may be tired and old.
Once it's up and running you need to test the output of your alternator. If your not savvy with a multimeter....which you will need... then watch the following tutorial. Yes it's for a car however the voltages prescribed are almost identical to our AT's. If you do exactly whats in the vid then you have sucessfully troubleshot your output voltage. Stators rarely fail so i'm betting on your battery or R/R.
http://www.youtube.com/watch?v=Bzz7P...V-wg&index=113
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 10-14-2011, 03:32 PM   #10334
alainmax
ca vaut le detour !!
alainmax's Avatar
Oddometer: 618
hi Reidy,,
great comprehensive tutorial, check this site and DL the PDF
http://www.electrosport.com/technica...-finding-guide
..I have an extra RR as I will most likely do the Mosfet mod
( still in the box, sent to me from PapaPete )
04 GS 1150
93 Africa twin RD07
alainmax is offline   Reply With Quote
Old 10-14-2011, 03:59 PM   #10335
headbanger on wheels
Oddometer: 3
Originally Posted by alainmax View Post
great video Wald Man, what a load to control!!and all in the back..
nice panniers set up, did not seem to interfere with the legs in tight passages
Zega Pro by Touratech.
headbanger on wheels is offline   Reply With Quote
Times are GMT -7.   It's 11:38 PM.
