Old 10-11-2011, 11:55 AM   #1906
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,887
Originally Posted by bmwktmbill View Post
Dirty,
Last I sealed the top of the engine I used Red hi-temp RTV.
It worked OK, leaked a little.
What are you recommending for that these days?
Also on the road it might be necessary to reuse a base or head gasket if the engine has to come apart and fresh spares aren't available.
Can you recommend anything for reuseing these and if so does the torque spec stay the same?
Should the head be retorqued?
Should the engine top?
bill
Bill-
The automobile industry stopped using cut gaskets like the ones used to help seal the valve inspection covers on the LC4 Mill back in the '70s. And there's a reason for it.....cut gaskets are prone to taking on a compression set which results in leaks.
I try not to use cut gaskets on anything that uses a spark plug in our house and use instead...you might guess, one of which ever Gasket Eliminator product I have closest. 518, 515, or even 510 all would be entirely suitable.
Acetoxy cure RTV's like ALL red high temp RTV's don't play well with non-polar fluids such as oils and fuels. The hydrocarbons absorb into and are attracted to the silicone molecules, then sometimes slowly and sometimes rather quickly the RTV breaks down and a leak is born. This is what you experienced. Then there's the small bit of squeezeout that will become dislodged and might come to rest at an oil pump intake location.
Plus RTV's we all use are cured by moisture. As soon as a thick or thin bead of RTV or any other solvent based gasketing product is applied it immediately begins to cure and skin over. If you fiddle around once you draw out a bead of RTV, by the time you mate the surfaces it's already skinned over to the point the exposed product has cured to the point it won't wet out the mating surface which is needed for a satisfactory seal.
Gasket Eliminators have no open time to worry about like you do with the gasketing products mentioned above. You could apply the material, go to lunch, take a week vacation, then return and mate your parts. It doesn't begin to cure until you remove air from the equation...mate your parts and tighten things up.
A little 6ml tube (think small like a tube of Chapstik) of 518 is an ideal thing to have in a tool bag.
The use of Gasket Eliminator does not change the torque specs.
On the inspection covers I dab a thinnish visable film on the top of the head, place the covers in place, then with a bit of blue threadlocker on the hex head bolts thread them in. Once finer tight, I'll go back around and snug everything up, then wipe off any squeezeout to keep the dust from finding a place to call home. Because we're not using an elastic/mildly compressible gasket, arriving at "tight" feels different. I suspect you work on your own bike so you should know how tight...tight is. I've never torqued these buggers with a real live clicker torque wrench.
A head or base gasket can be removed and reused by dressing both sides of the gasket with a thin film.
Careful work with a razor blade will allow you to remove the head or base gasket. Tedius, but I've done it with no real issues.
Once everything is buttoned up, no need to re-torque simply because you upset the seal. Same goes for nuts and bolts with a threadlocker.
My LC4 does not have any sort of oil leak.
Dirty
No, really, the mustache means I love you.
dirty_sanchez screwed with this post 10-11-2011 at 12:01 PM
dirty_sanchez is online now   Reply With Quote
Old 10-11-2011, 11:48 PM   #1907
bmwktmbill
Traveler
Oddometer: 5,048
Dirty,
Is this the stuff you are recommending?
http://www.amazon.com/Loctite-38655-.../dp/B0002KKTTA
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 10-12-2011, 06:45 AM   #1908
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,887
Yep, only I vote for 518 more than 515 simply because it fixtures (holds your parts together) a bit more quickly than 515.
Instead of an Amazon-type place, I suggest going to one of your local Industrial Distribution/Bearing/Power Train houses like Motion Industries, Applied Industrial Technologies, Grainger, Fastenal. If they don't have the stuff, you'll get it the following day.
Some part numbers:
pn. 51817 Loctite 518 Gasket Eliminator, 6ml "Travel Size"
pn. 51831 Loctite 518 Gasket Eliminator, 50ml
Dirty
Old 10-12-2011, 09:11 PM   #1909
SCsurfer
surfing explorer
Oddometer: 170
Hey Bill , I used Honda Bond when my rocker cover started leaking at 8k miles . Now at 14k and still no leaks .
'07 640 Adventure
SCsurfer is offline   Reply With Quote
Old 10-13-2011, 12:27 AM   #1910
bmwktmbill
Traveler
Oddometer: 5,048
SC,
I have used Honda bond myself several times and it works but...it's a PIA to work with and a PIA to clean off when the time comes to open the chest.
That said I carried it RTW on one trip. It started to harden up after a couple of years. I will try the Loctite products next.
They sound like the final solution and will multi-task.
bill
Bill Shockley
Old 10-13-2011, 04:58 AM   #1911
flashover604
tailgunner
flashover604's Avatar
Oddometer: 548
Hóla, Seńor Sanchez. Any guess as to what the grayish white toothpaste looking stuff is sandwiched between the head and leaking rocker cover of your old, my new 640? It was up posed to have had the top end rebuilt 1000 miles before I got. Hard to tell what the shop used, but it's fugly. It'll be cleaned off and replaced by 515 or 518 when I get around to it.... Still a great bike, btw. It almost got it's first whitetail last week...
http://
Shown with a buddies Trail 90. I think I can get IT for $500. I'll just throw it on the back for a spare....
"That which does not kill You, usually makes you wish it did......."
flashover604 is offline   Reply With Quote
Old 10-13-2011, 06:38 AM   #1912
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,887
Flashover- I was about to say what happened! It shrunk and has fork boots now-then I noticed the Grey Mare.
The guys last into the engine likely used Hondabond/Yamabond, XXXXXbond, that clay/solventbased sticky, pain in the arse to clean up stuff.
Patience, time, and a non-marring scraper to get it off are all your friends.
Dirty
Old 10-13-2011, 07:44 AM   #1913
flashover604
tailgunner
Oddometer: 548
Grey Mare. I like it. That little trail 90 will run 41 mph all day long. It won't do 42. As for the MysteryBond stuff, it looks like it was put on with a paint brush. This bike is a ball. I used the spare switch on the dash for my clutch/neutral switch for the time being. Now I can bypass it when I want to. I may go back and run the wiring from the clutch through the switch so I can have the original function, plus a complete bypass. Right now it's all or nothing.
Old 10-13-2011, 08:45 AM   #1914
racedawg
Have bike will travel
racedawg's Avatar
Oddometer: 254
Just in case anyones interested. http://www.advrider.com/forums/showthread.php?t=733171
Need to get rid of her.
04 KTM 400 EXC plate /
09 KTM 950 SE
racedawg is offline   Reply With Quote
Old 10-13-2011, 10:58 AM   #1915
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,887
So with the spare dash switch thrown you can now start it while in gear....with the clutch lever pulled in?
Anyone else know if we can start the bike while in gear/clutch lever pulled in by disconnecting the wire down down near the oil filter cover and counter sprocket?
Dirty
Old 10-13-2011, 11:19 AM   #1916
flashover604
tailgunner
Oddometer: 548
When I got it, the connector was hanging at the perch, so it would only start in neutral, whether the clutch was pulled in or not. Now, with the switch off, it'll still only start in neutral. With the switch on, it'll start in gear or neutral, with the clutch lever in or out.
Old 10-13-2011, 03:35 PM   #1917
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,407
KTM noob with a question.
What's wrong with this picture?
Picked up a 2002 640 Adventure about a month ago and I'm loving it!
Needs a bit of jetting, but other than that its in great shape! Shouldn't there be a snorkel on top of the airbox? How would this affect the way the bike runs? It idles a bit rough, and I get some surging at low rpms between 0-1/4 throttle.
2005 KTM 950 Adventure
Roaming Rally 2011RR2012 RR2013 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 10-13-2011, 05:07 PM   #1918
bmwktmbill
Traveler
Oddometer: 5,048
What carb?
If it's the BST 40 try raising the needle a notch.
The bike will run fine with stock jets.
What jets do you have in there?
Clean the carb.
bill
Bill Shockley
Old 10-13-2011, 05:39 PM   #1919
juames
juames's Avatar
Oddometer: 2,407
What carb?
Clean the carb.
bill
OEM carb...not sure of the jets. Haven't had the carb open yet. Stock exhaust.
What affect if any would removing the top of the airbox have? Looks like it was cut off.
Old 10-13-2011, 06:33 PM   #1920
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,111
Removing the top of the airbox will add more air to the mix so you can run bigger jets and in theory gain a bit of horsepower... In order to take advantage of this your exhaust has likely been cored out to allow the extra volume of combustion to exit the engine...
On the downside: your filter will need more frequent cleaning... The way the top was butchered of your airbox you are losing the integrity of one of the most watertight airbox designs...
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Times are GMT -7.   It's 08:21 AM.
