10-15-2011, 10:12 AM
#2266 |
There is no spoon.
Oddometer: 1,212
Wow. That Garwood unit looks awesome.... it would be really cool to have a tail light / led blinker kit so you could just do it all in one kit.
This seems like it has to be done for eveyone....might jist as well make it a kit.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
10-15-2011, 10:18 AM
#2267 | |
There is no spoon.
Oddometer: 1,212
) so I'm not planning on taking it on super tight trails just yet....although I'm not just fire roading it either....I'll put them on at some point....not sure which I may go with...there's some good looking ones and some really tough, but heavy looking ones.....
10-15-2011, 10:26 AM
#2268 | |
There is no spoon.
Oddometer: 1,212
![]() I did like you and went over the carb boot, I ran it pretty hot the other day, and had no vapor lock issue or whatnot. The one thing I have noticed is I turned on the petcock on the left (clutch lever) side and forgot to turn on the right....the bike started to run out of gas with about 2 gallons still in it. Once I turned on both petcocks (did not go reserve) it straightened right out and ran fine again....I think it creates a vacuum lock in the line, kind of like when you hold your finger on the end of a straw..... I can take some pics of the routing if it would help you, just let me know.
10-15-2011, 02:38 PM
#2269 |
The 2-Stroke Guy
Oddometer: 495
I have a Promoto Billet rack that I may want to sell off my 530. Anyone interest...PM me.
Here's the link.... http://www.promotobillet.com/catalog...roducts_id/455
Eric '09 KTM 300XC '07 FJR1300 (For Sale) |
10-15-2011, 08:22 PM
#2270 | |
NorthWest Adventure Rider
Oddometer: 1,702
Sounds like the same setup I run except I run the line under the carb. Here's a few pics of my setup. ( clamps are removed in these shots. I've since replaced the larger hose with a head shielding made for automotive fuel line.) Get a good quality T-fitting instead of the cheesy plastic unit the tank comes with. ![]() I also use another section of larger hose as a heat/abrasion guard to protect the fuel line. I run a quality silicone fuel line like the motion pro stuff as well as an external filter for extra insurance during remote desert travel. ![]() Use snap ties to keep the fuel line away from the header. ![]() ![]() Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE |
10-16-2011, 11:31 AM
#2271 |
Oddometer: 586
oil burn
Questions for the knowledge...
I have noticed the past two times I rode my bike for a couple hours or more that the next day when I happen to look at my sight glass the oil is no where to be seen. I know specifically this last time it was at least 3/4 of the way up... Should I not worry about the sight glass and only measure based off of what goes in and how much comes out...or is this a ridiculous amount of oil to be missing after one ride?
10-16-2011, 12:24 PM
#2272 |
The 2-Stroke Guy
Oddometer: 495
OK....I did mention that I was going sell my Promoto Billet rear rack. However, I am also going to sell my HT oil cooler. PM if interested. If I do not get any responses......I'll post up in the flea market section.
HT Cooler........SOLD. Still have the rack.
Eric '09 KTM 300XC '07 FJR1300 (For Sale) ekms377 screwed with this post 10-21-2011 at 04:53 AM |
10-20-2011, 10:46 PM
#2273 |
fishing with dynamite
Oddometer: 2,064
Anybody know where I might be able to find wiring diagrams for the XC-W / EXC?
10-21-2011, 04:54 AM
#2274 |
The 2-Stroke Guy
Oddometer: 495
I downloaded the whole manual from somewhere......if you can't find it.......shoot me a PM with your e-mail.
10-21-2011, 05:09 AM
#2275 |
Oddometer: 353
Hodakaguy,
What tank is that you have and what is its capacity? I was looking at the Clockworks 3+ gallon tank.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
10-21-2011, 08:56 AM
#2276 | |
Oddometer: 2,064
pretty sure that's the big acerbis tank. But if you're onoy looking for a 3+ gallon tank, have never seen a better-made/better-fitting/better/looking tank than the 3.4 gallon acerbis tank. Built-in radiator shrouds, but no wider than stock. |
10-21-2011, 09:11 AM
#2277 | |
Oddometer: 1,702
Hodakaguy
10-21-2011, 04:12 PM
#2278 |
Oddometer: 353
Trying to get prepped for little ride on Sunday. Still figuring out the new to me punkin' and have found out that the PO installed the 48 pilot jet, the 175 main jet, and the blue needle. The PO did not de-smog the bike so it has a stumble off idle and does not like to "tractor" in first very smoothly. I don't have time to go through the de-smog so I may re-insert the 42 pilot jet and re-set the screw.
Any thoughts?
10-21-2011, 04:21 PM
#2279 | |
There is no spoon.
Oddometer: 1,212
10-21-2011, 05:25 PM
#2280 | |
Wanderer
Oddometer: 2,451
dc |
