Thread Tools Search this Thread Rating: Thread Rating: 54 votes, 5.00 average. Display Modes
Old 09-13-2011, 10:55 PM   #91
wheels
Practicing to retire
wheels's Avatar
Oddometer: 143
I recently replaced the digitizer on my 550 and it worked perfectly for a few thousand miles. Now it's acting like the screen is being pushed all the time. Anyone have any ideas?
Jim
"Full Tilt Bozo Panic"
wheels is offline   Reply With Quote
Old 09-14-2011, 12:18 AM   #92
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,794
Bluhduh A regular service Item?
Uncanny you posted this.........I just had to put my spare to use today, same problem.
The last one worked for 13 months. The original Garmin one lasted 24 months
Anyone else have any input on this subject?
I have been ever so gentle with the last replacement worrying somehow that the original failure was my fault.
For such an expensive GPS I am disappointed to say the least.
And don't begin to mention the so called 'waterproof' cradles
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 09-22-2011, 12:36 PM   #93
SidewinderX
Hey, watch this!
SidewinderX's Avatar
Oddometer: 1,146
Replaced my screen last night in my Zumo 450. Very easy to do. As others have stated, it is intimidating until you do it once....
Works great with no leaks. Tested that today.....
Daniel
What would you attempt to do in life if you knew that you could not fail?
SidewinderX is offline   Reply With Quote
Old 09-23-2011, 09:21 PM   #94
RoadWeenie
Super n00b
RoadWeenie's Avatar
Oddometer: 98
Just did my Zumo 550, exactly as described. I didn't have any trouble with screen degrading over time; I had an off and some part of me, the dirt, rocks or trees scratched the screen.
RoadWeenie is offline   Reply With Quote
Old 10-07-2011, 07:24 PM   #95
DrWez
Mad Scientist
Oddometer: 96
The screen on my Zumo is also locking up. This week the XM radio started changing stations by itself. Could this be related to the bad digitizer????
Where is the best place to order the correct size digitizer?
2010 R1200 GSA, 1976 MotoGuzzi 850 T3
BMW MOA 140210
BMW RA 32150
IBA 56882
DrWez is offline   Reply With Quote
Old 10-07-2011, 08:41 PM   #96
RoadWeenie
Super n00b
RoadWeenie's Avatar
Oddometer: 98
I ordered this size from this seller.
http://www.ebay.ca/itm/LCD-Touch-Scr...#ht_1803wt_689
Fit perfectly, with the correct connector (no soldering required). Took about 10 days, standard shipping, to Canada.
Old 10-11-2011, 07:08 AM   #97
MotrSklz
MotrSklz's Avatar
Oddometer: 129
I recently replaced the touchscreen on my 550 and within 2 weeks, I was experiencing issues again. I am getting phantom presses again but only in the top right corner of the screen so when on the map screen it constantly zooms in as far as it will go. It is not recognizing other locations on the screen a lot of the time either.
I have found that this is most prevalent when I leave the zumo on the bike overnight and it is parked outside (when camping etc). Sometimes it sorts itself out once the day warms up and sometimes not. Very odd and annoying!
I have another new touchscreen I can put on (I ordered two... just in case ), but I was wondering if anyone else is going through this and if there was any other option before I scrap this screen?
Cheers
MotrSklz
MotrSklz is offline   Reply With Quote
Old 10-17-2011, 02:51 PM   #98
dirtydoug
dirtydoug's Avatar
Oddometer: 226
try re-plugging the plug onto the board
may be a bad connection
life is like a dick...when its soft you cant beat it ...when its hard its F*cked
"treat me good, ill treat you better. treat me bad, ill treat you worse" Sonny Barger
" Do one thing every day that scares you " Kurt Caselli
dirtydoug is offline   Reply With Quote
Old 10-17-2011, 07:23 PM   #99
DrWez
Mad Scientist
Oddometer: 96
My Zumo is getting worse, on top of the touch function of the screen not working, the gps screen locks up updating the map while moving, the XM stations will change suddenly (always goes to HLN), some type of error log screen popped up, and several of the buttons don't work for example the volume button.
So, if I go ahead and open up the unit and replace the digitizer (79mmx 64.5mm ordered from goodsupply0889), is this going to solve the problems above or do I need to send it in to Garmin for $150?
BMW MOA 140210
BMW RA 32150
IBA 56882
Old 10-17-2011, 08:03 PM   #100
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,794
For what an ebay screen is worth, try changing first.
It is most likely that.
Old 10-18-2011, 08:46 AM   #101
DrWez
Mad Scientist
Oddometer: 96
Garmin will not take it back if you open it.
BMW MOA 140210
BMW RA 32150
IBA 56882
Old 10-21-2011, 02:01 PM   #102
dirtydoug
dirtydoug's Avatar
Oddometer: 226
the up side of sending it to garmin is ( was in my case anyway )
that they send a new ( refurbished ?? ) unit that has all the brackets, wiring etc...
Old 10-22-2011, 08:42 AM   #103
DrWez
Mad Scientist
Oddometer: 96
How long did it take to receive the refurbished unit? How is it holding up? I heard that some of the refurb units failed in a short time.
BMW MOA 140210
BMW RA 32150
IBA 56882
Old 10-22-2011, 10:02 AM   #104
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,749
I sent mine back after it crapped out from wear. They sent me a new on in about a week for 100 bucks.
DELTATANGO is offline   Reply With Quote
Old 10-24-2011, 10:45 AM   #105
dirtydoug
dirtydoug's Avatar
Oddometer: 226
my first one stoped working after 6 mos ( hard impact )
got it back............... dont rember how quick it came
second unit still going (after new screen this yr ) around 4 years
Times are GMT -7.   It's 12:02 AM.
