Old 10-19-2011, 08:42 PM   #25186
Sock Monkey OP
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,231
Originally Posted by OSU
im going to college for electrical engineering, its my job to make things overly complicated haha
LOL.
FWIW, I was told this mod only changes the idle circuit (lower revs), and NOT the entire range. That may have been BS, but I erred on the side of caution (since I opened up the airbox and replaced the pipe) and ended up getting a FMF Power Programmer. YMMV, etc.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 10-19-2011, 09:07 PM   #25187
OSU
OSU's Avatar
Oddometer: 57
Originally Posted by Sock Monkey View Post
LOL.
-SM
ill be checking my plug to see if it gets really black from running too lean and I think ill put temp a gauge on the case
2005 Ducati monster s2r 800
2008 WR250R
OSU screwed with this post 10-20-2011 at 12:29 AM
OSU is offline   Reply With Quote
Old 10-19-2011, 09:15 PM   #25188
cug
Oddometer: 4,935
Quick question: what is the largest rear sprocket I can mount on a WR250X with the OEM chain? I googled and found it for DRZ and YZ models, but not for the WR250X.
cug is online now   Reply With Quote
Old 10-19-2011, 09:56 PM   #25189
skierd
Wannabe Far-Rider
Oddometer: 2,956
44, maybe 45T. Stock chain is 108L. You'll need 110L for a 46T rear.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 10-19-2011, 10:17 PM   #25190
cug
Oddometer: 4,935
Thanks. Bummer. I see only 42 and 47 so far. Have to search a bit more. Not too big a deal as I'm not planning on really technical stuff, but was hoping to find a 43 to 45T that'll fit X hubs.
Old 10-19-2011, 10:38 PM   #25191
skierd
Wannabe Far-Rider
Oddometer: 2,956
Steel sprockets ok?
Part number JTR2452.xx where XX is your tooth count for JT steel sprockets. For a 44T it would be JTR 2452.44. I'm running a 42T right now (JTR2452.42) and have used a 46 and 47 in the past.
For reference the front sprocket is a JTF1590xx. JTF1590xxSC if you want the lightweight steel version with holes drilled in it, otherwise it'll be solid.
Unsure of other brands, so far my sprockets outlast my chain as it is and they're cheap so I haven't had any incentive to switch.
2008 Yamaha WR250X
Old 10-19-2011, 11:35 PM   #25192
skierd
Wannabe Far-Rider
Oddometer: 2,956
BT-003 RS Ordered, 140/70-17 rear and I'll burn up my take off OE BT090 front for this change. Sportbike Track Gear had them for $112, about $10 better than the next nearest site.
I have a small to medium conniption every time I see or think about that luggage setup, I think I pack lighter for a month on the road... . Looks like the beverly hillbillies got themselves a motorsickle.
Originally Posted by bpg View Post
Well, I finally replaced my rear MT43 last weekend - but not until I squeezed another 250 street miles out of it!
this was on the way to the Fuzzy Beaver Rally in western NC: http://www.advrider.com/forums/showt...719630&page=25
yeah I know, I'm too poor to afford ultralight camping gear and too lazy to compress every sock, pair o' boxers, shirt, etc. when packing - get over it!
Anyway, ended up with 3500 miles on the MT43. As you can see, it still had a lot of life left for street/commuting, and actually still gripped very well off road as long as it wasn't too wet. This was about 2X the life I was getting from aggressive DOT and non-DOT knobbies, with significantly better traction in all off road conditions other than pure mud.
After seeing what the new MT43 could do off road at the rally (uber-steep 5 minute "hill" climbs countless wet log and rock crossings, etc), quite a few folks were asking about it - might have converted a few!
2008 Yamaha WR250X
Old 10-20-2011, 12:39 AM   #25193
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,441
Well, that's the danger of being 7 time zones ahead of you guys, I miss out on all the hot deals.
I'm glad someone posted a link to that 4.7gal tank ad, because gol'dang that fucker is wide. Yup, happy with the direction I plan to go, but I still appreciate all the inputs.
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is online now   Reply With Quote
Old 10-20-2011, 06:04 AM   #25194
SkidMarx
SkidMarx's Avatar
Oddometer: 2,165
That's backwards. White is lean, black is rich.
I'm sure that was just a test to see if anyone was reading your posts.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 10-20-2011, 06:53 AM   #25195
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,224
Is it any wider than the stock shrouds that it replaces?
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 10-20-2011, 07:10 AM   #25196
ironbrewer
Hopefully Riding
ironbrewer's Avatar
Location: Was in Colorado now in The Northwet, Washington
Oddometer: 4,011
I use my GPS for a speedometer and odometer. Can you in fact put your WR into permanent CO diagnostic mode to have a tach all the time? Would you just permanently ground the wire? And if you did this would you have to go through the program every time you started up the bike??
"All the problems we face in the United States today can be traced to an unenlightened immigration policy on the part of the American Indian."
Pat Paulsen
ironbrewer is offline   Reply With Quote
Old 10-20-2011, 07:31 AM   #25197
bhd1223
bhd1223's Avatar
Oddometer: 294
Bt-003
Just some info regarding the BT-003 and the BT-003RS. They are 2 different tires. Very different in fact. The 003 is a straight race tire. It's not designed to work well in the wet, racers use rain tires for that. The 003RS is a "racing/street" tire. It's designed to work for people commuting on their bikes and going to trackdays. I actually ran/run the 003RS on my EX500(Ninja 500) track bike. I say used because I didn't race or do any trackdays this year due to the WR consuming my track budget. For the events and trackdays I did on the 003RS I was very impressed. No experience with rain though. They stick well until you start really pushing them to borderline expert club racing level. They slide predictably from what other have told me, I've never pushed them to that point.
YMMV.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 10-20-2011, 07:52 AM   #25198
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,103
YMMV.
Ya, I think most people (like me) in this thread are referring to their tires as the BT-003, but we actually have the racing/street version (BT-003RS). Is the racing BT003 even street legal?
GotMojo? is offline   Reply With Quote
Old 10-20-2011, 08:41 AM   #25199
cug
Oddometer: 4,935
Originally Posted by skierd View Post
Steel sprockets ok?
Awesome info! Many thanks, I'll find one now! Wheels are ordered, now all the other related hardware has to be decided (tires) and ordered (tubes, bands, ...). I'll use my existing rotors and whatever else I need for the time being so save some money as I need so many other things for this bike for my November trip.
Old 10-20-2011, 09:36 AM   #25200
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,966
MT-43 rear 1,800-mile longevity update...
I've had the MT-43 DOT Trials-type tire on my WR-R for just over 1,800 miles now and thought I'd post some photos to update how it's wearing. To my eye the center lugs are about halfway gone, but the tire still grips about the same as when it was new as far as I can tell.
'Course, with all that gas a-sloshing around in my big-ass IMS tank, this could just be a byproduct of the worn, shorter knobs counteracting a jello-like effect caused by the longer knobs when they were new and gummy, but what do I know?
I'm pretty much running 12 psi all the time in this tire based on advice from inmates here that running more on-road would accelerate wear in the center.
Looks like this tire will have a longer "useable" life than the D606s I had been running. I'm thinking this one might see 3K miles before it needs replacing. The D606s were almost completely gone at 2,500 miles and were all but worthless off road long before that.
Will update again as they wear out more...
Closer view...
GSBS is offline   Reply With Quote
Times are GMT -7.   It's 07:11 PM.
