10-19-2011, 03:32 AM
#61 |
Ignorance is a gift
Oddometer: 688
TX750 coming out of the boneyard
I picked up a very ratty 1973 TX750 out of the junk yard last fall. Someone had given it a funky rat / cafe treatment sometime in the past and it had a cool rusty look to it so I stuck it in the window at the shop. Things slowed down over the last couple days so I put in on the lift to see what would happen. Cleaned the carbs, checked the timing and threw on an aux tank. Wiring was hacked so I put 12v straight to the coil. Scared the cramp out of me when it actually fired up and ran.
![]() I think it has the extended oil sump and I'll check for the hole at the points case (no evidence of oil though). I'm hoping to find the adjustable chain for the balancer. I really didn't expect it to run so now I'll look a bit more carefully. It should be a fun shop bike
www.motorcyclesolutionsllc.com |
10-21-2011, 06:22 AM
#62 |
Oddometer: 206
I've always liked the TX750, and from what I hear the bike was great if you didn't live at the
top of the rev range and kept up on routine maintenance. The balancer adjuster was also needed. A shame a little more development wasn't done before original release. I went to talk to the Yamaha Dealer in my old hometown recently, (I moved many years ago) We talked about the old days, reminisced about DT1's and XS's, when the talk turned to TX750's his facial expression said it all. That bike cost Yamaha and the local dealers a lot of money. I love the TX for it's uniqueness, but his experience was a lot different than mine! |
10-21-2011, 06:52 AM
#63 | |
WFO for 41 years
Oddometer: 4,015
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
10-21-2011, 06:56 AM
#64 | |
WFO for 41 years
Oddometer: 4,015
http://www.tobyfolwick.com/tx750/textual/pbadj_1.php http://www.tobyfolwick.com/tx750/bulletin.php
10-23-2011, 02:27 PM
#65 |
Oddometer: 18
tx750 oil check
Nice work on the TX.
Question for you. When you check the oil level, is the dip stick inserted all the way down or should it be sitting on the tube? Thanks, Lawrence |
10-23-2011, 07:05 PM
#66 |
WFO for 41 years
Oddometer: 4,015
Thanks! Seated all the way down is the correct method.
10-23-2011, 07:11 PM
#67 |
WFO for 41 years
Oddometer: 4,015
Oil Filter mount
The spin on oil filter I fabbed up:
10-24-2011, 11:49 AM
#68 |
Oddometer: 22
Tx750 Oil Filter Adapter
I just had a batch of aluminum oil filter adapters made for my 4 Tx's. These are the ones that replace the expensive stock filter and use the BMW R65 filter - work great. Have some extra's to sell if anyone interested. Comes with new filters and oring (the other parts are used from the old filter). PM if interested I can email pics.
10-24-2011, 04:05 PM
#69 |
Oddometer: 18
I am on the fence to install the BMW filter or the spin on type, I have the spin on set up already.
I did change the oil today, 15w-40 Rotella is what I used. I have the 74 with the oil cooler. Thanks for answering my question about the oil dip stick! I bought this bike back in May when I was across the world off the coast of Libya, (Canadian Navy). My father went and pick her up for me, a bit of a gamble considering that she was not running at the time, since then I fixed the issues and ridden about 100 miles. She rides nice, she does like around 3000 rpm onward. Lawrence |
10-24-2011, 04:10 PM
#70 |
Oddometer: 18
I forgot to include the you tube video of her running for the first time in about 10 years.
http://www.youtube.com/watch?v=0NkTtHC6ZCI Another question; the tubes going to the oil filter, which tube do I use for the input to the spin on filter and the output? Thanks for the pictures of your setup, Concours! Lawrence |
10-25-2011, 03:48 AM
#71 | |
WFO for 41 years
Oddometer: 4,015
10-25-2011, 03:51 AM
#72 | |
WFO for 41 years
Oddometer: 4,015
10-26-2011, 02:34 AM
#73 | |
Ignorance is a gift
Oddometer: 688
I went through the rest of the motor adjustments and made a simple wiring harness to start it up without frying anything. It started and ran well yesterday. Got a quick adjustment done on the carbs and it idled fine, had good response and seemed smooth. The motor is smoking a bit, but it hasn't run in who knows how long and I did add a fair amount of oil in the cyclinders for the compression test. Also, I do not know if these bikes are prone to wet-sumping like the old brit bikes. I've got the extended oil sump so hopefully I've also got the balancer mod
10-26-2011, 03:10 AM
#74 | |
WFO for 41 years
Oddometer: 4,015
http://www.tobyfolwick.com/tx750/textual/pbadj_8.php http://www.tobyfolwick.com/tx750/textual/pbadj_9.php As for wet sumping, I've never experienced it, and never read anything about it for a TX. One of the Brit "quirks" they solved with some sound engineering.
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster concours screwed with this post 10-26-2011 at 03:17 AM |
10-26-2011, 03:17 AM
#75 |
Ignorance is a gift
Oddometer: 688
Thanks a ton! I don't know how I missed it on Toby's site, but I appreciate your help. I just started my own thread so I don't distract from this one.
Thanks Again!
