11-03-2011, 07:32 PM
#346 |
Oddometer: 90
Two Plugs
How did you adjust/alter your preload on the shock,once installed its a pig to get to. |
11-06-2011, 11:06 AM
#347 |
Oddometer: 342
Wilbers Shock
My Wilbers shock arrived and I installed this weekend. I was able to remove the old shock without removing the swing arm by removing the shock bolts, the shock link completely and then just removing the 3 battery box attachment screws. I left the battery box in place (and all the wires and junk) but it gave enough to allow me to remove the stock shock. The Wilbers shock went in much easier since its a bit less volume than the stock unit.
We got rain and snow in SoCal but I plan to ride it today. Steve
1971 Moto Guzzi 125 Stornello 1971 CL100 1972 SL125 1972 TS125 1974 XL125 1975 CB360T 81 miles since new! 1985 XLV750 1988 RTL250S 1988 NX650 1989 XL600V Transalp White 50K Miles 1990 XL600V Transalp Red 7K Miles near perfect 1990 XL600V Transalp Moonstone 1990 VFR750R RC30 1990 NT650 1990 CB-1 1991 CBR400RR 1993 CRM250R 1993 NSR250RR 1994 XRV750 Africa Twin 1994 RVF750RR RC45 1995 RVF400RR NC35 1996 CBR250RR 2000 W650 2003 FJR1300 2004 RVT1000 RC51 |
11-06-2011, 11:59 AM
#348 |
Oddometer: 342
Sag appears to be close from the factory
11-06-2011, 07:38 PM
#349 | |
Oddometer: 90
11-06-2011, 10:45 PM
#350 | |
Oddometer: 342
Wilbers install
Steve
11-20-2011, 05:15 PM
#351 |
ADV B4 DEM/TED
Oddometer: 117
Hi all , i am in the process of possably getting a XLV 750 with some miner damage to the tank and may have some other damage .
The fuel pump has been changed to a fuel pump from a Mazda Capella and i am told that it works ?????![]() Are parts easy or hard to find , i am only paying a few hundred for the bike after a look at it first . Would it still be worth it to buy or leave it alone ????? ![]() Tezza
Tezza. KTM 990 ADVENTURE. ![]() KTM 520 EXE. ![]() Now the Perfect pair!!!!
11-20-2011, 10:59 PM
#352 | |
Oddometer: 980
Get it! It's a very rare machine. Don't worry about the Mazda fuelpump. The Africa Twin XRV750 and the Varadero XL1000V are using Mitsubishi fuelpumps. On my MK1 Varadero I replaced it by an Rover fuelpump.... Keep in mind that hardware is more- en more difficult to find.
Bernard 'Two Plugs', NL the First International Crosstourer Forum - www.crosstourer-international.com the First International Varadero Forum - www.varadero-international.com May 2013 Wales/UK: 15th Varadero & 2nd Crosstourer International Meeting! |
11-21-2011, 01:39 AM
#353 |
ADV B4 DEM/TED
Oddometer: 117
Hi All , so are parts hard to get ????????????????
![]() Tezza
11-21-2011, 01:51 AM
#354 |
Oddometer: 164
It depends on what you need.
There are quite some industry standard parts in there. You might have a problem when it comes to engine or transmission parts. Plenty of spares in France. http://www.leboncoin.fr/annonces/off...q=xlv+750&th=1 Pretty much everyone operating an XLV has one or two bikes sitting around for spares.
2008 XR650L - Sutton Oil Cooler, Cigar Mike Center Stand, XRs only bash plate, Shifter & Case saver, Steel braided lines, 650R C/S sprocket, Manracks case saver, Trailtech Vapor/Dashboard. 1985 Honda XLV750R - Ignitech Sparker DC-CDI-P2, Wilbers shock and progr. forks. 2008 KLR650E- fully farkled |
11-21-2011, 08:03 AM
#355 |
Oddometer: 980
Same here. But I've just started to neglect the noice... In my case, it only occurs when I pull the bike backwards with the steering fully out to the right or left.
11-23-2011, 04:59 PM
#356 |
Oddometer: 298
I may have an opportunity to purchase as XLV. How is the parts situation in the USA for them? Any reoccurring issues that one needs to be aware of, but since it is a honda all should be well. Mainly concerned about parts. Looks like a really neat bike.
11-24-2011, 01:25 AM
#357 |
Oddometer: 164
I think they were never sold in the US.
Honda dealers are pretty much out of stock. Parts you'll find are the few ones common with other bikes. For everything else you need to warm up the net and search. I bought parts from all over the world when they were available and cheap. That gives me quite an inventory. Grab the opportuniy and buy that bike!
12-04-2011, 12:50 AM
#358 |
TWIN Cylinder ADV
Few bits that might interest someone on here in Oz seeing as though these are getting very rare
http://www.ebay.com.au/itm/HONDA-XLV...item2316f8202a
Hodgo RD07 Africa Twin, KTM 950 Super Enduro www.facebook.com/KTM950SE Retired.. CR500E XRV750W,XTZ750,XLV750R,XR600R,CM250M,CB250T,CR125R,YZ100H |
12-04-2011, 01:31 AM
#359 | |
Keen AG100 rider
Oddometer: 499
12-21-2011, 01:21 PM
#360 |
Oddometer: 17
XLV 750 Fuel Pump Failed
Guys,
In the process of starting / running the bike (for the first time in a number of years) it would appear the fuel pump failed (plunger jammed) and then the fuel relay had the smoke escape, so that rendered it all useless, so am now looking for an aftermarket unit. In various threads I've seen details of the pump failing but haven't seen anything explaining what has been used in it's place.If anyone has some handy hints as to what has been successfult and what hasn't, would appreciate your feedback.I can see REPCO have a variety of pumps which I believe could be adapted To continue the story, got it running using a piece of hose direct to the carby's and with the help of gravity feed, had her purring in no time. Man, it sounds good, although not sure what the neighbours thought at that time of night. I'm sure they will be understanding of a man and his toys ! ! ! ![]() Cheers, GASco |
