Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-07-2011, 02:16 PM   #46
TAMPAJIM OP
Oddometer: 459
Originally Posted by eakins View Post
yep nice simple water-proof nuvi.
that fabric hood help w/ glare?
got a link?
It does a pretty good job with the glare. I can usually see it unless the sun is shinning directly into it.
Got it here http://www.glarestomper.com/316.html
Wifey had to modify it with a little flap to make it more convenient to use the RAM mount and so I could get to the on/ off stitch. But no big deal.
__________
Jim
TAMPAJIM is offline   Reply With Quote
Old 11-07-2011, 04:27 PM   #47
Snapper
Snapper's Avatar
Oddometer: 2,502
Originally Posted by twflybum View Post
Thanks for the insight.. I'm interested in the Madstad screen, but notice they have four different offerings for the T800.
18"/20"
Sport/Adventure
In all combinations plus optional screen tints.
I like the way yours looks, but was curious if you remember which model/size you chose?
Thanks in advance..
Mine's the Adventure screen in 18" with the light gray tint. I'm 5'8" w/30" inseam and seat in low position. As mentioned earlier, I look over my screen and see unobstructed asphalt about 1 standard parking length ahead of me (about 20').
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 11-07-2011, 04:31 PM   #48
Snapper
Snapper's Avatar
Oddometer: 2,502
Originally Posted by TAMPAJIM View Post
It's pretty solid. That nose brace on the bike is substantial ( seems I remember it being metal) and the RAM base is only an inch or two away. Some guys on the Brit forum were mounting directly on that brace using a long RAM arm.
Most of my miles are on pavement and the GPS is very convenient above the instruments, but you have a good point about off road. I do keep another RAM mount on the handlebar for that purpose.
Yeah.... I kind of overload my previous GS dash . It bounced like crazy, but was actually more substantial than the Tiger's mounts. The GS windscreen sucked too.
Lateral G Junkie
Fear Deer
Old 11-07-2011, 07:02 PM   #49
twflybum
Prodigal Biker
twflybum's Avatar
Oddometer: 125
Great! Just the info I was looking for! I'm 5'8" too, so the same options should do.
twflybum is offline   Reply With Quote
Old 11-07-2011, 08:48 PM   #50
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
I look over the screen. Mine is set at mouth level in the winter, little lower in Summer almost exactly as in Snapper's photo..
But I still like to see everything out in front of me and a dark screen creates a blind spot particularly if going slow or stopped. Doesn't help that I wear a light tint face shield.
that makes sense for the slow speed.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 11-20-2011, 06:40 AM   #51
woodys3b
Oddometer: 150
+1 for the OEM touring screen
Just got back from a 4k mile trip from Michigan to Florida and back. The trip south was with the OEM shield which worked pretty well for me. I knew that I needed more protection for the trip home as the temps had dropped a bunch. Picked up the Triumph touring screen in Miami and headed north. It works a lot like the stock screen but just punches a bigger hole in the air. I think it looks right on the bike as well. FYI, I'm 5'8" with 30" inseam. Seat is in low position.
I know it was off topic but thanks for the info on reducing glare on the GPS. I have mine mounted just above the instrument cluster as well and 50% of the time it's unreadable. BTW, there is more room above the instrument cluster with the Triumph touring screen than there is with the stock screen.
Now I just need a better seat. Is there a dedicated seat thread for the Tiger 800? Corbin says they have one "coming soon."
woodys3b is offline   Reply With Quote
Old 11-20-2011, 07:14 AM   #52
Shep
Vagabond
Shep's Avatar
Oddometer: 506
I'm very happy with the Mastad screen on my Tiger. I have the smaller one, I believe in a Sport. I'm short (5'5") and I have it pretty much all the way down and slightly tilted in my direction (very slight). I tested it out on a boring Interstate ride from Indiana to Southern Florida and back about a month ago. I even had the chance to spend about 200 miles of the ride in the remnants of a tropical storm...35-40 mph winds and driving rain. You know a product is working for you when you don't give it a second thought. Wish I could say the same for the seat.
Shep
Looking for the Road Less Traveled...and a 690 Duke.
http://motorheadcoffee.wordpress.com/
Shep is offline   Reply With Quote
Old 11-20-2011, 08:42 PM   #53
Fireman1000
Fireman1000's Avatar
Oddometer: 2,549
Does anyone make a short screen that just lets clean air flow?
Fireman1000 is offline   Reply With Quote
Old 11-21-2011, 06:52 AM   #54
Snapper
Snapper's Avatar
Oddometer: 2,502
Speed triple screen...? Pricy tho Clicky
Lateral G Junkie
Fear Deer
Old 11-21-2011, 07:00 AM   #55
TAMPAJIM OP
Oddometer: 459
There was one on the UK forum where somebody used a flyscreen from the (speed/street?) triple but I think it was very expensive. Looked good though.
Others have taken the stock screen off entirely or modified it to lay back against the instrument pod. You get smooth air but not much protection at higher speeds.
The Madstad is convertable to a flyscreen. The plastic shield comes off in about a minute via four thumb screws, and for an even cleaner look, you can take the robo brackets off almost as fast (4 bolts w/nynuts). I saw one where the owner had got some little black pop-in plastic plugs from the hardware store to fill in the bolt holes for a real finished look.
__________
Jim
Old 11-23-2011, 06:00 PM   #56
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by fbj913 View Post
I have the Givi Screen (below). I hate it! I am 5' 11" and have my seat in the High position. The screen throws spoiled air right at the top of my head and gives me the worst head shake ever above 60 mph. I am taking it off tonight and putting the stock screen back on. I tried everything I could to make it work. It may work for some but for me its a no go.
I took my screen back to the dealer today. They were great to work with and helped me out! I bought the other Givi adjusteable wind screen. Its the AF6401 model http://www.giviusa.com/My-motorcycle...--Tiger-800-XC
I will let you guys know what I think next week.
fbj913 is offline   Reply With Quote
Old 11-23-2011, 09:38 PM   #57
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
that madstad has a metal baseplate that works well for that too w/ the robobrackets and screen removed.
that shorty above looks way cool however.
Alaska
Old 11-24-2011, 08:37 AM   #58
oilburner07
CUMMINS POWER
oilburner07's Avatar
Oddometer: 34
has anyone seen this shield yet from Twisted Throttle http://www.twistedthrottle.com/trade...view/6972/845/ ...or http://www.twistedthrottle.com/trade...view/6830/845/ , it does look similar to the street triple screen
2011 Triumph Tiger 800 XC LOADED
2010 Triumph Thunderbird 1600 SOLD
2008 Kawasaki KLR 650 SOLD
2003 Kawasaki KLX 400 SOLD
oilburner07 is offline   Reply With Quote
Old 11-24-2011, 08:47 AM   #59
motosickle2000
Oddometer: 187
It looks cool! I don't think it is big enough to be a very effective windscreen. It might keep your navel warm though.
motosickle2000 is offline   Reply With Quote
Old 11-24-2011, 09:09 AM   #60
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
for something that small why bother with the extra wind lip?
if you go that small it should just be like a fly screen so as to flow air onto you say in the summer.
Alaska
Times are GMT -7.   It's 06:40 PM.
