11-29-2011, 11:18 AM
#57481 | |
Oddometer: 2,565
11-29-2011, 11:51 AM
#57482 | |
Oddometer: 139
Curious to know if this is your issue. The Breeze |
11-29-2011, 11:53 AM
#57483 |
Oddometer: 668
so if I get out the metal shell, the rubber seal should go in? It doesn't need a new metal shell? So why does the metal need to be in there? The new seal has no metal piece with it.
11-29-2011, 11:58 AM
#57484 | |
Motorcyle Stuff
Oddometer: 1,792
http://www.manracks.com |
11-29-2011, 12:01 PM
#57485 | |
Oddometer: 2,565
So if the tank is anywhere below half (guesstimate), the bike might stall. Next time it happens add fuel to raise the fuel pressure in the tank (head). There's a video on how to twist the carb inlet, done by someone at Safari. But I'm late and have to leave. This is not the issue if it's happening with a full-ish fuel tank. 205'd
11-29-2011, 12:04 PM
#57486 |
Oddometer: 739
Help!!!
Took the DR for a ride today with the new TM-40 carb. When I first starting the bike, i let it run for a few mins with the choke on, and when I shut it off, the bike died, Just figured it still cold, so I started again, and just rode with choke off, throttle up. it was all street riding, mostly on the highway, only about 20 miles, and died at one light when I bleeped the throttle. I got home and it felt like the idle was a bit low, so i turned the knob in a little bit it while sitting on the bike. I smelled gas, but thought nothing of it. Got off the bike while it was running, and saw fuel spilling out of the vent hose. I followed the vent hose up, and it was the one under the Idle adjustment (see pic). What is this from? When I shut the petcock off, the fuel stops flowing from the vent hose.
I would like some advice before I start pulling the carb apart, Thanks guys..
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
11-29-2011, 12:07 PM
#57487 |
Oddometer: 2,565
The metal shell is rubber coated, it is the seal, that's why you had so much trouble getting the rubber peeled out of the wheel. Try to bend your new seal, it isn't the rubber giving that stiffness.
11-29-2011, 12:13 PM
#57488 | |
Oddometer: 668
Now to get that metal piece out without destroying the bearings.........
11-29-2011, 01:03 PM
#57489 | |
Oddometer: 739
11-29-2011, 01:23 PM
#57490 | |
Taumarunui..Darwin..
Oddometer: 2,110
That wheel bearing does not look to flash either (an easy replacement)
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780. |
11-29-2011, 01:35 PM
#57491 | |
11-29-2011, 01:38 PM
#57492 | |
Oddometer: 50
1981 XS650 - Cafe'd, sorta, 2006 CRF250R mufflers, pod filters |
11-29-2011, 01:50 PM
#57493 | |
Oddometer: 2,110
My TM40 has done this a few times over the last few years for no apparent reason. Once was coming into Top Springs (dirt road in the middle of nowhere) and noticed it exiting fuel from a hose. Stripped the carb but found no obvious signs of the fuel seat not seating. Another time I came out of a large hardware store to find the bike sitting over a '3 foot puddle of fuel. Could the float stick once in a blue moon is still ?????????? I never leave the fuel taps on,if it was to run down the inlet tract that might risk hydraulic ing the engine also.
#57494 | |
Oddometer: 533
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 85 Yamaha BIG Wheel 200 www.drriders.com |
11-29-2011, 02:18 PM
#57495 | |
Oddometer: 50
lol yeah that is pretty lucky. There are lots of techniques for setting the bowl height, I've never done it though.
