10-20-2011, 07:10 PM
#61 |
Oddometer: 572
No decompression device shown in the parts catalog. I have not checked valve clearance on mine yet, so can't speak from experience.
10-21-2011, 04:55 AM
#62 |
Purveyor of Light
Oddometer: 3,711
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
10-29-2011, 04:31 PM
#63 |
I don't ride much.
Oddometer: 950
Alrighty - sorry for the delay - Went out and did over 3k on the other bike last week up through CA, OR, and WA.
I couldn't check the spark timing earlier b/c the timing gun I have (borrowed) needs a spark plug wire. It doesn't work on my bike b/c there really isn't one, as the coil is a stick type to which the plug is directly connected. The wires are numbered, as are the plug holes, so no way to fuck that up, though I did switch them out just for kicks once (w/o success). sanjoh is right - no auto decomp's. Anyway, like I said, just came home - garage is a mess - I deploy soon and spent a lot on vacations these last 2 weeks, especially since the BMW broke down on the road and needed a fuel pump, so financially, this project won't be getting much else anytime soon. I'll mess with it later on, perhaps.
--------------------- KLRE650 Build thread. Ryca Scrambler Build. __________________ |
11-24-2011, 11:23 AM
#64 | |
Oddometer: 467
Id say trust it. I know its no fun to hear. but hey this was a few months ago anything new? |
11-24-2011, 11:34 AM
#65 | |
I don't ride much.
Oddometer: 950
I've been super swamped with work, and I'm deploying in less than a month, so this will probably sit for a long time unless someone wants to take the reigns. Thinking about it recently though, I think the rings are the culprit. I put it all back together already, but I think I need to pull it all back apart. The rings are basically fused in place - not loose as they should be. I was going to pull them off, but I couldn't even do that. They slid back into the cylinder with no compression at all. I don't know what I was thinking earlier - I should have looked into that more, but I guess I'm a moron, so I'll deal with it later. New rings, and gaskets, and I think that'll do the trick. |
11-25-2011, 01:37 AM
#66 | |
Oddometer: 4,296
You'll be back on the road in no time now you've found the problem |
12-03-2011, 08:06 PM
#67 |
I don't ride much.
Oddometer: 950
Well, I got her to start today after new pistons/rings...
More to come. |
12-04-2011, 01:04 PM
#68 |
I don't ride much.
Oddometer: 950
Well - we're back in business! Looks like the piston rings seized into place and the lack of suction wasn't getting the air/fuel mixture into the cylinder, then not compressing. She's running well now... finally.
Thanks to all for the input and help over the last months. The new intake makes her run better than before, though the fueling above 8k rpm still isn't perfect. A Dyno would fix that, but she honestly doesn't need it and I'm pretty much done with her now as I'm outta time! |
12-04-2011, 01:31 PM
#69 |
Oddometer: 383
[QUOTE=Krasniewski:
The new intake makes her run better than before, though the fueling above 8k rpm still isn't perfect. [/QUOTE] Could you show us some pictures of your intake with air filters? Thanks |
12-04-2011, 02:23 PM
#70 | |
I don't ride much.
Oddometer: 950
Well, I'll show you what I have... Taken from page 2, you have a pic of the spine and throttle bodies - one has a JB Weld stick putty to close the gap, (which is far from optimal as it doesn't allow for flex and vibration absorbtion)... ![]() ...and the other has a 90 degree PVC bend wrapped in a long strip of rubber, so keep it air/water tight. ![]() Sorry - didn't take pics of the finished product. Off the back I welded on a tube, and put a foam filter on the end. Ideally, it would be enclosed in an airbox so the back wheel wouldn't cover it in dirt.
12-04-2011, 04:36 PM
#71 | |
Oddometer: 997
well, we kinda let you down bud, sorry.
Looking back in hindsight, its obvious that the rings are stuck in the picture you posted. We should have caught that. Glad its sorted now, be safe overseas and thanks! Quote:
12-04-2011, 04:41 PM
#72 |
I don't ride much.
Oddometer: 950
Not at all, man. It's so hard to diagnose something from a picture - hard to have any expectations really. The rings didn't look right to me at all - I should have pointed it out.
On the contrary - the only reason this actually got started, let alone finished, is thanks to the interest online. Good times.
12-04-2011, 08:50 PM
#73 |
Oddometer: 467
glad you got it.
and the pics are a dead give away. opps.
08-01-2012, 08:34 PM
#74 |
displaced Jeep guy.....
Any news on this? How's she doin?
Interested in a Charleston, SC ADVdinner? |
08-03-2012, 05:07 PM
#75 |
I don't ride much.
Oddometer: 950
Funny you should ask - just flew off the USS Abe Lincoln today - holed up in NM for the night - should get home tomorrow! So long as she fires up again, I'll keep working on her - I'll post updates as they come.
I haven't been home since December, so I've got lots to catch up on!
