Old 12-05-2011, 12:52 PM   #1
the cavalier OP
adventurer
Oddometer: 22
regulator question
HI!
I have recently tested my regulator rectifier after a few weeks of tending my battery every night to get it running. You see, the battery itself was not holding it's voltage over night. Well i spent $200 on a yuasa battery and am wanting to protect my investment.
turns out my regulator is not running perfect...
At 1,500 rpms it's producing an average of 14. volts. great!
at 5,000 rpms it's producing an average of only 13.8 volts... hmmm.
this means that the battery is getting some charge when i'm riding at speed.
My commute is an even mix of about 5 miles on the hwy and 5 miles of traffic lights.
my questions are...
is 13.8 volts enough to keep my bike charged at hyw speeds?
is this a sign of future failure?
Am I at risk of killing my new battery?
can i put this repair off till the spring?
anyone have a spare regulator rectifier?
Thanks for the advice!
the cavalier is offline   Reply With Quote
Old 12-05-2011, 01:17 PM   #2
the cavalier OP
adventurer
Oddometer: 22
more info...
There are no electrical accessories on this bike.
I did check for loss of current and also the generator coils. no problems.
Old 12-05-2011, 02:44 PM   #3
Sumi
Sumi's Avatar
Oddometer: 1,813
Did you turn on the low beam?
Old 12-05-2011, 02:51 PM   #4
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I'm on my 3rd rec/reg........ Just replace it with the latest model. 13.8 is not enough.
New/good reg. runs 14.4/5 at idle no lights
14.4/5 at rpm lights/no lights
Two invaluable gages are a volt meter and oil temp (correct eng. temp)
A lot of people panic that their bikes are overheating because their cooling system does what it is designed to do. With an oil temp gauge you know what is really happening.
I mounted mine on the glove box
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 12-05-2011, 03:39 PM   #5
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
The battery killing issue is not an insufficient charge issue. The batteries get a shorted cell and then will take but not keep a charge. This can be diagnosed on a battery tester. There are disagreements as to the exact cause but spikes from the rectifier, how the starter draws, using a charger at more than 1.2 amps and jumping the bike are all possible causes. The 950 is famous for shorting batteries and seemingly worse with gel batteries. You may have an additional problem of low voltage in which case change the rectifier.
“Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
KTM 950SE, KTM450exc, WR262, XR100
SA Trip: http://profundoenel.wordpress.com
My Spot Page: http://share.findmespot.com/shared/f...VRxGZhKdq5PNll
DeepInIt is offline   Reply With Quote
Old 12-06-2011, 01:38 PM   #6
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Go and price a Rec/Reg, there reasonably priced/cheep compared to all the fucking around. Everyone should should have one handy.
Old 12-08-2011, 12:46 PM   #7
the cavalier OP
adventurer
Oddometer: 22
thanks for the replies!
i am now in search for a regulator...
Old 12-08-2011, 01:25 PM   #8
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I got one of eBay installed it and it worked perfectly for about 10 seconds. Total waist of money. The thing caught fire sort of. This stuff had a big rap through the Yamaha forums.
So I am on my third KTM and forth rec/reg. I've had my bike since new 6 years. Change my waterpump every 15,000km ... now 20,000km. Fitted a vacuum fuel pump..... and recently fixed my starter sprang spring. That was quite funny as I rang the shop and was quoted $1,080 for the part which includes the freewheel. The broken part looks like a spring from behind an oil seal..... reached into my bag of old unused seals and gaskets and found one that fit...... I works perfect. Cost = $0,000 Easy bike to live with. No other problems
Old 12-08-2011, 01:30 PM   #9
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,663
K2m- which oil temp gauge is that and where/how is it hooked up? Sounds like a real good idea. Thanks
unaweep is offline   Reply With Quote
Old 12-08-2011, 09:56 PM   #10
K2m
....58....
K2m's Avatar
Oddometer: 2,238
The gauge is a VDO water-temp from a boating shop ...... a discount warehouse place. I got the sender from the same shop. There is a little lug on the back of the oil tank. I drilled and taped it It's been there nearly 6 years
Old 12-09-2011, 07:52 AM   #11
unaweep
unaweep's Avatar
Oddometer: 20,663
Old 12-10-2011, 10:24 AM   #12
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
I will have to dig for the complete reference, but I believe that a Yamaha R1 regulator will work far better because of the MOSFETs used internally. Requires the harness plug to be spliced but that is pretty easy. The R1 regs run much cooler and as a result typically will last a very long time. Voltage regulation also tends to be more in line with ~14.2Vdc.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 12-10-2011, 10:40 AM   #13
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
Yamaha PN: 1D7-81960-00-00
Requires plugs: FURUKAWA CONNECTORS
From Drop Box
From Drop Box
Old 12-10-2011, 03:07 PM   #14
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Nice one Ken
This is nothing like the Chinese rubbish that I tried
The KTM ones do not last long enough. This looks to be a good solution to an on going problem.
http://www.ebay.com.au/itm/YAMAHA-SH...item588d8645ad
Or maybe the kit
http://www.ebay.com/itm/ws/eBayISAPI...DER:SIMPLEITEM
Might just grab one
Old 12-13-2011, 02:34 PM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,066
Anyone found the OEM connector?
How do you connect to the OEM loom? Did you find the manufacturer of the OEM brown plug the yellow wires connect to?
Times are GMT -7.   It's 04:28 AM.
