01-01-2012, 10:20 AM
#1126 |
me specie in dea ist
Oddometer: 499
The Line
Every Ship Has a load line / Every truck has a load limit./Every item made has a limit.
Does this translate to performence NO. Performing is the factor for weight distribution and Power to weight ratio. When i look at the new BMW the weight has been set higher by the cylinders/ My thoughts new Gear box/ in the box But if you can judge a bike by a photo the mass weight does not go over the overall Tire height. if you draw a line axel to axel. What im thinking now we might have a top of the line track bike with perfect weight all mid way high under axel and not over tire height. The rake and trail factor i can not measure so im sending a picture and i hope some one can tell us the trail rating. I dont have a draw program near me. If some one can do the math please help. http://en.wikipedia.org/wiki/Bicycle...cycle_geometry McFury.
So Close Yet So Far. ![]() ![]() ![]() McFury sending and spreeding out gas fumes inn Islandic Highlands. What´s you gonna do when they come for you. ![]() ![]() ![]() ![]() Whats next ? Man walking on the moon ?. All typing is done with One Finger using a MacPro Computer. |
01-01-2012, 10:23 AM
#1127 |
Ride the World
Oddometer: 5
Yea that can look like the hoses from and to the radiator.
01-01-2012, 12:43 PM
#1128 | |
Smile 4 Miles
Oddometer: 1,375
Bernhard M. Hohne ..so it's his material. Thank you Bernhard, me want to see more Picture source: http://www.motorradonline.de/ |
01-01-2012, 12:58 PM
#1129 |
Oddometer: 499
Mein Herr. Bernard.
Grüssen Dancke.
And Happy new year. Thank you for letting ADV hang on to these pictures. If you care to give a freebee picture we would be head over heals ![]() McFury.
01-01-2012, 05:40 PM
#1130 |
Smile 4 Miles
Oddometer: 1,375
Read the German article in "MOTORRAD" Magazine # 01-2012.
- There is a linkeage mechanism behind the riders foot connecting the rear swingarm movement with the dampening settings, indication for a motorcycle first active suspension system.... - 125...130PS and more if need be in the future... - Weight goal: < 240kg with full tank... - The front control arm (now aluminum) is different than before, the engine was designed to integrate the control arm... - Shorter engine, rider sits farther in the front of the bike and this will help keeping the front wheel on the road.... - Adjustable screen (Electric) - Color TFT, GPS optional tallguy-09 screwed with this post 01-02-2012 at 10:54 AM |
01-01-2012, 08:31 PM
#1131 |
Talks to cats
Oddometer: 5,310
01-01-2012, 08:39 PM
#1132 |
Grumpy Old Goat
Oddometer: 4,360
GS or GSA? That's 528 lbs., FYI. Kinda portly in my book.
I found Jesus. He was behind the sofa the whole time. 1996 M900, "Patience" 2012 GS "Sonar" 2008 Megamoto "Big Blue" 2008 S2R "WTF" |
01-01-2012, 08:42 PM
#1133 |
Hm. That's 1150 country (well, after I changed the exhaust...).
"Everybody's got to believe in something. I believe I'll have another beer." - W. C. Fields |
01-01-2012, 11:02 PM
#1134 | |
Talks to cats
Oddometer: 5,310
01-02-2012, 04:01 AM
#1135 |
Oddometer: 470
In germany the 1250 has been shot, looks nice. Check the cylinder and where the exhaust pipes is fixed....
follow this link and scroll: http://www.gs-forum.eu/showthread.php?p=898895 If you already knew these pics I apologise .... |
01-02-2012, 05:59 AM
#1136 | |
Oddometer: 44
However, i can't find any weight reference, nor sitting position reference (although i'm certainly not disagreeing with what you said), nor rear swing arm linkeage comments. Below quick translation of what it says, and excluding what has been put on here already. Note it indicates the bike has two radiators. Other then my comment in () this it what the article says: New engine with integrated transmission is much more compact. This allows future configuartions such as shorter wheelbase, or longer swing arm Displacement will likely be 1250cc, but future bikes could have more. 1250cc would allow 130bhp with good torque curve. The relative small cross sections of intake and exhaust indicate a torque optimized bike, and Motorrad expects 125bhp. The current 1200cc boxer can handle nearly 10.000rpm, which indicates the engine should be able to get up to 150bhp in future, and stay competitive Exhaust: new exhaust builds more narrow. Allows for more volume in RH side case. Employs the exhaust valve Drive shaft: it just says the wasserboxer also uses the parrallel arm to minimize the torque reactions of the drive line Rear frame: can now be easily removed , and allows for different variants of the bike (note think S/GS/GSA) Instruments: New instruments, round speedo, above it small tacho. Optional TFT display as on K1600 with all kinds of functions. Optional GPS device Radiators: the radiators are mounted unusually tilted backwards, probably due to the limited room and the fact the bike shouldn't be too wide. The underside of the beak fuctions as an aid for the radiator airflow. Brakes: new radial brakes, requiring newly designed forks Engine: Alternator and waterpump are likely in front of the crankcase. Optimal thermal conditions allow using only one sparkplug per cylinder |
01-02-2012, 06:53 AM
#1137 | |
Smile 4 Miles
Oddometer: 1,375
Ref: http://www.motorradonline.de/de/motorrad/865 |
01-02-2012, 07:21 AM
#1138 |
Oddometer: 279
There's been frequent mention of "radial brakes" as a new feature. What are they? Why would they be better than the current style?
'13 K1600GT '08 R1200RT (gone) '04 R1150RT (gone) '05 R1200GS (gone) '73 R75/5 (long gone) |
01-02-2012, 07:28 AM
#1139 |
Oddometer: 44
You're registrered on that site? No matter what I try I keep getting the August article. And it's not like i can't read german, I think I'm still pretty fluent in this language (well except for spelling and etc).
It does say the current mag contains an article about the new GS. The next new mag is out after Jan 4th or 5th, so I trust the article will be available online after that? |
01-02-2012, 07:37 AM
#1140 |
Oddometer: 3,818
I'm not an expert, but basically put a radial brake is one where the caliper is moved so that it sits parallel to the front fork. This allows more braking power, which is the standard arrangement for all new high performance motorcycles. From the photos I've seen the front brake is not a radial system.
"Deeply flawed people make deeply flawed decisions." |
