Old 01-01-2012, 12:43 PM   #1126
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Originally Posted by bmh-images View Post
Hello guys!
These pictures are copyright-protected, I am the photographer who took the pictures and sold the German licence to the german magazine "Motorrad"! So if you post them please at least (!!!) also state the correct source of the pictures, which is www.motorradonline.de, or www.bmh-images.com.
For further questions feel free to contact me (info@bmh-images.com).
Regards,
Bernhard
Just noticed the pictures on the "MOTORRAD" website and the picture source: Hohne.
Bernhard M. Hohne
..so it's his material. Thank you Bernhard, me want to see more
Picture source: http://www.motorradonline.de/
tallguy-09 is offline   Reply With Quote
Old 01-01-2012, 12:58 PM   #1127
McFuryMcNugget
me specie in dea ist
McFuryMcNugget's Avatar
Oddometer: 499
Mein Herr. Bernard.
Grüssen Dancke.
And Happy new year.
Thank you for letting ADV hang on to these pictures.
If you care to give a freebee picture we would be head over heals
McFury.
So Close Yet So Far.
McFury sending and spreeding out gas fumes inn Islandic Highlands.
What´s you gonna do when they come for you.
Whats next ? Man walking on the moon ?.
All typing is done with One Finger using a MacPro Computer.
McFuryMcNugget is offline   Reply With Quote
Old 01-01-2012, 05:40 PM   #1128
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Read the German article in "MOTORRAD" Magazine # 01-2012.
- There is a linkeage mechanism behind the riders foot connecting the rear swingarm movement with the dampening settings, indication for a motorcycle first active suspension system....
- 125...130PS and more if need be in the future...
- Weight goal: < 240kg with full tank...
- The front control arm (now aluminum) is different than before, the engine was designed to integrate the control arm...
- Shorter engine, rider sits farther in the front of the bike and this will help keeping the front wheel on the road....
- Adjustable screen (Electric)
- Color TFT, GPS optional
tallguy-09 screwed with this post 01-02-2012 at 10:54 AM
Old 01-01-2012, 08:31 PM   #1129
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,612
Originally Posted by tallguy-09 View Post
- < 240kg with full tank...
If true, I can certainly live with that.
marchyman is offline   Reply With Quote
Old 01-01-2012, 08:39 PM   #1130
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,415
GS or GSA?
That's 528 lbs., FYI. Kinda portly in my book.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 01-01-2012, 08:42 PM   #1131
dmac57
dmac57's Avatar
Oddometer: 3,048
Hm. That's 1150 country (well, after I changed the exhaust...).
"Everybody's got to believe in something.
I believe I'll have another beer."
- W. C. Fields
dmac57 is online now   Reply With Quote
Old 01-01-2012, 11:02 PM   #1132
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,612
Originally Posted by hillbillypolack View Post
GS or GSA?
It's less than the real world weight of a GS (not GSA) with a full tank of gas. http://www.motorcyclistonline.com/pe...lts/index.html measured an '05 GS at 544 pounds. The measured weight of a '00 R1150GS was 586.
Old 01-02-2012, 04:01 AM   #1133
Steveman
Steveman's Avatar
Oddometer: 471
In germany the 1250 has been shot, looks nice. Check the cylinder and where the exhaust pipes is fixed....
follow this link and scroll: http://www.gs-forum.eu/showthread.php?p=898895
If you already knew these pics I apologise ....
Steveman is offline   Reply With Quote
Old 01-02-2012, 05:59 AM   #1134
Gompie
Oddometer: 176
Read the German article in MOTORRAD.
- The front control arm (now aluminum) is different than before, the engine was modified to better integrate the control arm.
I just read that (the Aug 2011 article). Good find. That site also has the "which bike is the best in the Alps" test. 1200GS won it again, but only just before KTM 990 SM T. More info on 1250 in current Motorrad mag, but i don't have access to that. I trust that article is available online shortly
However, i can't find any weight reference, nor sitting position reference (although i'm certainly not disagreeing with what you said), nor rear swing arm linkeage comments. Below quick translation of what it says, and excluding what has been put on here already.
Note it indicates the bike has two radiators. Other then my comment in () this it what the article says:
New engine with integrated transmission is much more compact. This allows future configuartions such as shorter wheelbase, or longer swing arm
Displacement will likely be 1250cc, but future bikes could have more. 1250cc would allow 130bhp with good torque curve. The relative small cross sections of intake and exhaust indicate a torque optimized bike, and Motorrad expects 125bhp. The current 1200cc boxer can handle nearly 10.000rpm, which indicates the engine should be able to get up to 150bhp in future, and stay competitive
Exhaust: new exhaust builds more narrow. Allows for more volume in RH side case. Employs the exhaust valve
Drive shaft: it just says the wasserboxer also uses the parrallel arm to minimize the torque reactions of the drive line
Rear frame: can now be easily removed , and allows for different variants of the bike (note think S/GS/GSA)
Instruments: New instruments, round speedo, above it small tacho. Optional TFT display as on K1600 with all kinds of functions. Optional GPS device
Radiators: the radiators are mounted unusually tilted backwards, probably due to the limited room and the fact the bike shouldn't be too wide. The underside of the beak fuctions as an aid for the radiator airflow.
Brakes: new radial brakes, requiring newly designed forks
Engine: Alternator and waterpump are likely in front of the crankcase. Optimal thermal conditions allow using only one sparkplug per cylinder
Gompie is offline   Reply With Quote
Old 01-02-2012, 06:53 AM   #1135
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
I meant the 01/2012 magazine, not August:
Ref: http://www.motorradonline.de/de/motorrad/865
Old 01-02-2012, 07:21 AM   #1136
Sailorlite
Oddometer: 405
There's been frequent mention of "radial brakes" as a new feature. What are they? Why would they be better than the current style?
'14 R1200GS
Priors: '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5.
Sailorlite is offline   Reply With Quote
Old 01-02-2012, 07:28 AM   #1137
Gompie
Oddometer: 176
You're registrered on that site? No matter what I try I keep getting the August article. And it's not like i can't read german, I think I'm still pretty fluent in this language (well except for spelling and etc).
It does say the current mag contains an article about the new GS. The next new mag is out after Jan 4th or 5th, so I trust the article will be available online after that?
Old 01-02-2012, 07:37 AM   #1138
Kawidad
Kawidad's Avatar
Oddometer: 5,061
I'm not an expert, but basically put a radial brake is one where the caliper is moved so that it sits parallel to the front fork. This allows more braking power, which is the standard arrangement for all new high performance motorcycles. From the photos I've seen the front brake is not a radial system.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 01-02-2012, 07:43 AM   #1139
Gompie
Oddometer: 176
You should try Google on "radial brakes". Really not that difficult. First hit is probably all you want to know about brakes right now. Takes less time than creating the response you did
Old 01-02-2012, 08:31 AM   #1140
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
What does this imply?
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Times are GMT -7.   It's 09:21 PM.
