Old 01-02-2012, 05:43 AM   #36211
XR650L_Dave
Oddometer: 3,761
Originally Posted by mendoteach View Post
Speaking of tethers, has anyone else had the kick stand spring go south? Last year a friend's did, and this fall mine did. I thought the first time was a fluke but perhaps not. I have been thinking about wiring mine. We didn't find his, so he leaned his bike against trees for four days. Safety wire to the rescue!
Oh yes indeed... replaced it with a hardware store spring with a wire running through the middle.
On my XR200 I stopped at a trailside bedspring and used 2 short springs, worked as long as I had the bike.
Dave
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 01-02-2012, 05:47 AM   #36212
XR650L_Dave
Oddometer: 3,761
Originally Posted by truck6driver View Post
Odd. I have had both the XR600R and XR650L The tanks and seats were the same on them and I have interchanged them before.
Ray
600R tank mounts with 2 bolts in the front, 650L with one in the back, no?
Old 01-02-2012, 07:24 AM   #36213
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,516
yeah. The 600 has mounting points where the R/R is on the L. So I had to change the front brackets also.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 01-02-2012, 09:28 AM   #36214
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,562
Originally Posted by 3girlsdad View Post
is there a case saver/guard for the xr650l to keep the shifter from doing it's damage? i can't seem to find one...
I fabbed my own as well. I went "full wrap" to make it look less like a patch.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 01-02-2012, 10:03 AM   #36215
truck6driver
The Fireman
Oddometer: 7,510
Is that an XR600R countershaft with the large splines?
Life has F@#ked with the wrong man. I will come out on top. Just watch.
truck6driver is offline   Reply With Quote
Old 01-02-2012, 10:07 AM   #36216
Wattner
Wattner's Avatar
Oddometer: 5,448
I always put 2 strands of safety wire... Lost one before. Not a fun thing at all!
Wattner is offline   Reply With Quote
Old 01-02-2012, 11:22 AM   #36217
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
Yes. I'll defer to Red to fill you in on the details.
Spud
Old 01-02-2012, 11:52 AM   #36218
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by Spud Rider View Post
Here's a photograph of the stator cover saver I bought from forum member AKARob.
I attached the guard to my stator cover with JB Weld. If Rob is no longer selling these guards, you can make something similar from a small piece of aluminum plate.
Spud
I was at the bike show last month and I saw a KTM go down on its side and the shifter punched out a hole . If that bike hade one of these guards it may have helped... After seeing that happen in front of my eyes I am making installing my guard top priority when it heats up a bit. Just need to figure out what the best way to fasten it.
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 01-02-2012, 02:09 PM   #36219
mx760
mx760's Avatar
Oddometer: 158
That is amazing! will the pinesol do any damage to the rubber parts? How many different beers will be needed? it looks like that is a critical part of the process. The bike sat for a year and has massive crud in the carb guesing it is from the ethanol.
Originally Posted by Barron View Post
Check out this:
Before....
During..
and after...
I let the stuff sit in the Pinesol (no water) for a few days, then pulled it out and gave it a quick once over with the toothbrush. I figured it would work, but I didn't think it would work this good!
THANKS B!
-Barron
2013 Super Tenere
mx760 is offline   Reply With Quote
Old 01-02-2012, 02:20 PM   #36220
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Mendoteches motor, dialing in the cam...
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 01-02-2012, 02:22 PM   #36221
cyclewizard
Oddometer: 4,814
mounting position of the indicator..
C-dub......
Old 01-02-2012, 02:29 PM   #36222
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,820
I am dying to know which racers use CW motors, can you tell me via PM if I swear not to blab?
katbeanz is offline   Reply With Quote
Old 01-02-2012, 02:31 PM   #36223
chipbl
chipbl's Avatar
Oddometer: 288
Originally Posted by kenny61 View Post
Thanks, Do they support the subframe the way they attach?
Here's my setup, I'd say they certainly can't hurt the subframe support - 2 of the 3 mounting points are on the frame itself so you could argue that it triangulates to support the subframe. In any case I've run them under a pretty full load and never had any issues.
2008 XR650L, tons of goodies.
chipbl is offline   Reply With Quote
Old 01-02-2012, 02:33 PM   #36224
chipbl
chipbl's Avatar
Oddometer: 288
Loaded for bear -
Old 01-02-2012, 02:39 PM   #36225
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 769
thanks to this site, I have incorporated a kick stand spring tether as well, using a couple zip ties.
your out of paper towels....
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Times are GMT -7.   It's 03:11 AM.
