01-01-2012, 10:59 PM
#36211 | |
Oddometer: 227
"Endeavor to persevere." |
01-02-2012, 05:43 AM
#36212 | |
Oddometer: 3,070
Oh yes indeed... replaced it with a hardware store spring with a wire running through the middle. On my XR200 I stopped at a trailside bedspring and used 2 short springs, worked as long as I had the bike. Dave
---->>Thanks for the rotor, guys!<<---- |
01-02-2012, 05:47 AM
#36213 | |
Oddometer: 3,070
600R tank mounts with 2 bolts in the front, 650L with one in the back, no?
01-02-2012, 07:24 AM
#36214 |
yeah. The 600 has mounting points where the R/R is on the L. So I had to change the front brackets also.
01-02-2012, 09:28 AM
#36215 | ||
Pig Wrangler
Oddometer: 1,565
01-02-2012, 10:03 AM
#36216 |
The Fireman
Oddometer: 5,795
01-02-2012, 10:07 AM
#36217 | |
Oddometer: 2,763
I always put 2 strands of safety wire... Lost one before. Not a fun thing at all! |
01-02-2012, 11:22 AM
#36218 |
Oddometer: 2,944
Yes.
I'll defer to Red to fill you in on the details. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
01-02-2012, 11:52 AM
#36219 | |
XRated
Oddometer: 810
. If that bike hade one of these guards it may have helped... After seeing that happen in front of my eyes I am making installing my guard top priority when it heats up a bit. Just need to figure out what the best way to fasten it.
01-02-2012, 02:09 PM
#36220 | |
Oddometer: 158
That is amazing! will the pinesol do any damage to the rubber parts? How many different beers will be needed? it looks like that is a critical part of the process. The bike sat for a year and has massive crud in the carb guesing it is from the ethanol.
03 XR650L XR600 JE piston Staintune stainless header FMF Q4 NX 2nd and 5th gears |
01-02-2012, 02:20 PM
#36221 |
Oddometer: 4,790
Mendoteches motor, dialing in the cam...
C-dub...... Powered by CW-Pistons/cams Wizard manufacturing.... |
01-02-2012, 02:22 PM
#36222 |
Oddometer: 4,790
mounting position of the indicator..
01-02-2012, 02:29 PM
#36223 |
earthbound misfit, I
Oddometer: 6,593
I am dying to know which racers use CW motors, can you tell me via PM if I swear not to blab?
http://www.youtube.com/watch?v=PZKIh5aCYCI |
01-02-2012, 02:31 PM
#36224 |
Oddometer: 219
Here's my setup, I'd say they certainly can't hurt the subframe support - 2 of the 3 mounting points are on the frame itself so you could argue that it triangulates to support the subframe. In any case I've run them under a pretty full load and never had any issues.
2008 XR650L, tons of goodies. |
01-02-2012, 02:33 PM
#36225 |
Oddometer: 219
Loaded for bear -
