Old 01-04-2012, 06:04 PM   #1591
natedog39
New Sheriff in town
natedog39's Avatar
Oddometer: 6,478
Originally Posted by Gargoyle View Post
For a dual sport bike it is great. For the tight, rooty, rocky, muddy NE trails I ride sometimes ... for me a 390 would be plenty. I am looking forward to riding the new KTM 350 in those conditions because it will be lighter than my berg.
You rode with me once Nate ... I am old and slow. I know that you can handle the 570 like it's a featherweight.
I did try an 11 390 and I did notice MUCH less engine braking.
That bike was much easier to ride fast than the 570, some of that I atribute to improved suspension settings but some to the smoothness of the engine as well.
2014 FE 501
2012 990Adv
Team Ghetto does a hot lap of America
natedog39 is offline   Reply With Quote
Old 01-04-2012, 07:22 PM   #1592
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 180
HF...
I own an '11FE570S and agree completely with your comments above.
I will be interested in hearing how you keep the Giant Loop straps away and/or insulated from the exhaust pipe.
Thanks for all your input...I used to own a WRR also and your input was greatly appreciated ! And valuable !
Dave
Rider1 is offline   Reply With Quote
Old 01-04-2012, 07:50 PM   #1593
toro618
toro618's Avatar
Oddometer: 966
Originally Posted by Indy Unlimited View Post
If you run Seafoam 1 oz per gallon in you fuel your injectors will stay clean.
Seafoam is basically isopropanol and penetrating oil. Prevents ethanol and water from forming an acid that eats the aluminum fuel pumps and clogs the injectors with aluminum oxide particles that are too small to be filtered.
BMW F800GS has the same small orifices on their injector heads.
I replaced the stock injectors with less than 1000 miles on my BMW and since have added 24,000 miles with Seafoam at every fill up. No Issues. Berg is also doing great on the Seafoam diet with over 2,000. miles
I used Seafoam with great result on my carbed Kawi Brute Force 750 that got all clogged up after sitting for a few years. But on my street bikes I use Strarbrite Startron with every fill up....so far so good.
Do you know what the advantage is in using Seafoam as opposed to Startron?
BTW, your Indy kit works great on my F800GS...thank you.
toro618 is offline   Reply With Quote
Old 01-04-2012, 09:04 PM   #1594
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Originally Posted by Rider1 View Post
HF...
Dave
Glad to help. Regarding the GL, I'm running the Mojave on my 390....which you can see in my photos (above). I'm assuming it has a very similar strapping system to the other models they make, but not certain. Anyway, its no problem near my exhaust; doesn't touch it. There is room between the frame and pipe...enough to wrap the strap and cinch it to the buckle.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is online now   Reply With Quote
Old 01-04-2012, 09:42 PM   #1595
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,163
HF
Just to be sure I wrapped some of that DEI Reflect-A-Gold around the right strap of my GL MoJavi where it goes around the backside of main frame next to the exhaust pipe, and the strap has held up great.
cyborg is offline   Reply With Quote
Old 01-04-2012, 10:07 PM   #1596
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 180
Thanks for the info !
My bike is at the suspension shop for a spring upgrade, revalve and a 2" height reduction. Once it's back I'll test fit my GLoop.
Dave
Old 01-05-2012, 06:21 AM   #1597
ktm950se
ktm950se's Avatar
Oddometer: 1,385
The WRR is simply one of the best true adventure touring machines I've owned, all things considered. I could ride it to Alaska and back....no problem. Bigdog & Dingweed did it just last summer. But, I wouldn't try to do that on my Husaberg.
Greetings HF,
Thanks for your comments!
Could you elaborate as to why you wouldn't use your 'Berg on an Alaska trip like 'Dog's and 'Weed's?
ktm950se
ktm950se is offline   Reply With Quote
Old 01-05-2012, 06:48 AM   #1598
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,636
Originally Posted by ktm950se View Post
Greetings HF,
ktm950se
Took my SE from NC to OK and back on the TAT. With a little more wind protection, I wouldn't hesitate to do the same with my FE450.
Check out this Adventure 570...http://www.expeditionportal.com/vehi...avel-bike.html...talk about a long distance adventure bike.
Carry a spare fuel pump and injector and you're good to go. Valves have been dead nuts on since I bought my 2 Bergs.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 01-05-2012, 11:47 AM   #1599
ktm950se
ktm950se's Avatar
Oddometer: 1,385
That's what I'm saying
Other than possible fuel system issues, the new 'Berg engine seems to be ideal for long distance dual-sporting.
I'm still trying to figure out why more people aren't using them for that...
ktm950se
Old 01-05-2012, 12:18 PM   #1600
Tarheel Wheeler
Around
Oddometer: 3,636
ktm950se
All 5 Bergs entered in Dakar are still running.
Old 01-05-2012, 01:01 PM   #1601
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 368
I did something similar on a week long ride and my improv heat shield fell off. The strap still did not melt. Going to roll with it as is next trip.
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral screwed with this post 01-05-2012 at 04:12 PM
chief_lee_visceral is offline   Reply With Quote
Old 01-05-2012, 06:04 PM   #1602
(sp?)
flaming ahole ;)
(sp?)'s Avatar
Oddometer: 5,352
I'm using DEI Fire Sleeve. I have it on the right hand strap of my Giant Loop bag in the rear and my panniers (strap touches heat shield) in the front. Very durable and no problems.
Blue KTM Forum now!!!
'09 Husaberg FE570
'05 BMW R1200GS
(sp?) is offline   Reply With Quote
Old 01-05-2012, 06:08 PM   #1603
cyborg
cyborg's Avatar
Oddometer: 5,163
One 'Berg down today, Ron on the DakarBerg team. Engine failure after they replaced the head the eve before.
Old 01-05-2012, 06:10 PM   #1604
cyborg
cyborg's Avatar
Oddometer: 5,163
DEI Fire Sleeve looks good for the job. I used the Reflect-A-Gold self-adhesive sheet because I had some left over from a under-fuel tank insulating job. Seems to hold up well wrapped around the straps.
Old 01-05-2012, 07:46 PM   #1605
Tarheel Wheeler
Around
Oddometer: 3,636
We need pictures.
4 outta 5 Bergs still running ain't bad!
Times are GMT -7.   It's 09:15 PM.
